Question about LG LSC26905TT Side by Side Refrigerator
Insall water filter
Instrctions say to put it in next to light and there is no place next to light to put it
  • 245 Answers
There are lots better filters then the ones that go into the fridges install an inline filter into the water line before the fridge that way you filter both the drinking water and the ice maker any hardware store will have them usually your water supply is tapped into the cold under your kitchen sink this is a good place to put the filter if you are connected there
Posted on Apr 27, 2009
Where do I begin when replacing sand filter with something great, very updated, but also user friendly & shiny & new. next what do i do about decor tiles falling off by handfuls daily?
Why replace a sand filter in first place. What is the last time you put a bag of sand avaluable at any pool dealer. I added a bag of approved filter sand and it was like I had a new sand filter.
You can also buy a bottle of sand filter cleaner. Put a bottle of it overnight with pool off overnite. Next day backwash and you will be amazed at green algae Walter coming out for first 30 seconds - then nice clear water!
As for why your tiles falling off, need more detaild
Nov 05, 2017 | Pool & Spa
Can the water filter housing be the cause of slow water when the filter is in place?
Even a new filter will reduce the flow some what. I think the pressure to the filter is low or restricted . that will cause a reduction in flow, no it should not leak, check on the seal.
May 27, 2015 | Whirlpool Refrigerators
I put a new filter in my Sansung Refrigerator and the water taste worse than the old one, why?
I agree with Gramps... the system needs to be flushed, but one question... why did you change the filter in the 1st place... was it cause you had a smell or taste in the water AND ice, or the filter light came on?? I would remove water line going to ref from house plumbing... run water in bucket for 2 min, then take a small taste to see if good..If water taste good, then hook water line back up to ref, and run water at the door for about 1/2 gal, then taste and smell water to see if it passes... If still have problem, you are going to have to replace filter head and/or water reservoir.... But before i did that i would contact Samsung to get their take, depending on age they might send parts at no charge to you the consumer....... Ken Hawk
preferred Samsung servicer
Jan 20, 2015 | Samsung RF265AA Bottom Freezer French Door...
I replaced the water filter and the light is still on. What should I do next.
Have you held down the reset button which is usally right on the front on the refrigirator. Please give your model to help you out more. I just have to hold down my filter icon and it disappeared.
Dec 14, 2014 | Samsung Refrigerators
No water being dispensed from my Insinkerator hot water tap following insallation of new filter
Probably debris from old filter got trapped in the line.
If the insinkerator has aerator, take that off and flush out debris.
Otherwise, the line will have to be taken apart and blown out.
Aug 11, 2012 | Water Heaters
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Install water filter
the filter is in the refrigerator side not the freezer side. It is next to the light bulb.
Customer service is 1-800-243-0000 for LG
Apr 22, 2009 | LG LSC26905TT Side by Side Refrigerator
How do I make coffee with a Grindmaster Pourover Coffee maker?
COFFEE PREPARATION PROCEDURES
1) Place filter into brew basket.
2) Put the proper amount of coffee into the filter.
3) Slide the brew basket into holder.
4) Place empty decanter on warmer located directly under the brew basket and turn corresponding warmer switch ON.
5) Pour decanter of fresh water through pour-in opening at top of brewer.
6) Hot water will be delivered through the sprayhead. This distributes the hot water evenly over the coffee bed within the brew basket. The coffee will drain from brew basket into the container below.
7) Red light indicates warmer is ON.
8) Before brewing next pot, remove brew basket from brew rails and dump filter into waste basket.
Please rate this a fixya
Feb 08, 2009 | Grindmaster Pourover Brewer - 18
LG LSC26905TT Side by Side Refrigerator Logo
138 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
