Question about RCA R52WM24 52" HDTV Projection Television
My 52inch rca flat screen shuts off can anyone help me
My rca jacks only the yellow for video dosent work
You have to check the RCA cable that use. Try with another one. Also check whether the Cable box's video output is working properly or not.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 11, 2016 | LG 52LD550 52Inch 1080p 120Hz LCD HDTV...
How to bring teletext up on remote control for 2011 plasma Vivo flat screen tv ?
www.avsforum.com/forum/.../1429512-service-menu-code-vivo-tvs.htm..
Aug 26, 2014 | Televison & Video
My rca 52inch rear projection tv would shut off then come back on know it won,t come at all is it possable it is a bulb help wayne
this model does not use a bulb, but has 3 picture tubes. Most common problem for this is bad solder connections under the high voltage transformer.
Nov 29, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52inch DLP TV - D52W17B Lights up, but the...
Your model uses CRTs instead of a bulb. Its usually the deflection board which causes that. Thats about 180.00 for a replacement board.
May 20, 2010 | Televison & Video
Tv will not power up
52inch Samsung tv will not come on right away! It takes about 40 try or days to try to come on, can anyone help!!
Apr 22, 2010 | Tatung V30DMTT 29.6 in. LCD Television
I have a 52inch rca projectin tv model hd52w59 i
Ur convergence it dead,U know how to solder?Buy a covergence kit,replace what in that kit.Tries these Websites,Tv Repair World.com,Ebay.com.
Sep 30, 2009 | RCA Televison & Video
I have an RCA 52inch rear projection tv model No#R52wh74 when i turned on the set the screen went into some concave mode and the color is al distorted what do i need to fix this
DO you have convergence in the customer setup menu? if you do not then check out the article fl231 problem in the tips and tricks section
Apr 28, 2009 | RCA R52WH73 Projection Television
RCA 52inch Big Screen.
On your remote push "Info" then push right or left to get OFF zoom mode, Cinema view looks pretty good.
Jul 20, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA R52WM24 52" HDTV Projection Television Logo
149 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
