Question about LG LSC26905TT Side by Side Refrigerator
Install water filter
The instrctions say to install next to light but there is no place next to light to put it
The filter is in the refrigerator side not the freezer side. It is next to the light bulb.
Customer service is 1-800-243-0000 for LG
Posted on May 26, 2009
I just installed the water filter in the fridge but the light on the front door panel still shows red
This is another one for the user manual! Always check it first. It would seem likely that the system is either time or water flow controlled. By this I mean that somehow your little red light is caused to light up. For example by a little device which can measure how much water you've used. This device could need resetting.
Try contacting manufacturer
May 06, 2015 | Jenn-Air JCD2295HES Side by Side...
I replaced the water filter and the light is still on. What should I do next.
Have you held down the reset button which is usally right on the front on the refrigirator. Please give your model to help you out more. I just have to hold down my filter icon and it disappeared.
Dec 14, 2014 | Samsung Refrigerators
I'm trying to find out if a 10 yr. old subzero 590 has a water filter built in somewhere ? if looked its seems like everywhere ? did they put water filters behind freezer panels.
This model didn't have a filter, you could have one installed in the water supply line under the unit behind the toe grill though. The next series after this model did have filters but this one didn't have a factory installed water filtration system.
Good Luck
Dec 11, 2013 | Sub-Zero 245
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
The water taste gross and smells, does this refrigerator have a water filter? i cannot find one
Normally there will be a filter in the refrigerator side of the unit. If there is a place for a filter, and no filter is installed, there will be a filter plug installed. It can be removed and a filter put in its place.What is the brand and age of the fridge? You can also try looking up the manual online for it if you don't have one.
Jan 24, 2011 | Refrigerators
Insall water filter
there are lots better filters then the ones that go into the fridges install an inline filter into the water line before the fridge that way you filter both the drinking water and the ice maker any hardware store will have them usually your water supply is tapped into the cold under your kitchen sink this is a good place to put the filter if you are connected there
Apr 22, 2009 | LG LSC26905TT Side by Side Refrigerator
How do I make coffee with a Grindmaster Pourover Coffee maker?
COFFEE PREPARATION PROCEDURES
1) Place filter into brew basket.
2) Put the proper amount of coffee into the filter.
3) Slide the brew basket into holder.
4) Place empty decanter on warmer located directly under the brew basket and turn corresponding warmer switch ON.
5) Pour decanter of fresh water through pour-in opening at top of brewer.
6) Hot water will be delivered through the sprayhead. This distributes the hot water evenly over the coffee bed within the brew basket. The coffee will drain from brew basket into the container below.
7) Red light indicates warmer is ON.
8) Before brewing next pot, remove brew basket from brew rails and dump filter into waste basket.
Please rate this a fixya
Feb 08, 2009 | Grindmaster Pourover Brewer - 18
I need to bypass a filter in RS267LASH Samsung refrigerator
From the Samsung Online FAQ for my RF266AASH
Can I Use the Water Dispenser Without a Water Filter? spacer.gif The water and ice dispensers will work without an AquaPure water filter installed. The water filter housings are designed as rotary valves that allow the water to bypass the water filter whenever there is no filter or the filter is not in the lock position.
Models designed for use with the AquaPure water filter are shipped with a cap in place to cover the opening and keep it free of debris prior to the installation of the water filter. It is not necessary to have this cap in place for the unit to bypass the water nor is it intended to plug the housing to prevent leaks.
Note: This does not apply to the Quatro Convertible models. The filter must be installed on this model.
Nov 21, 2008 | Refrigerators
Test Page Prints Everytime Printer Cuts On
this is happen when you install an new catridge or refill one printer is automatically adjust the catridge by alingment so you do one thing when you switch on printer and it will print something just read the instrction and follow them bcoz you need to setup the alingment thing . when the print is come out just place it in to the scanner and just press the scan button the printer will store the setting and next time not print the extra page bcoz the setup is completed.
bye
Nov 02, 2007 | HP Photosmart C3180 All-In-One InkJet...
LG LSC26905TT Side by Side Refrigerator Logo
118 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
