Question about Black & Decker Husky 750w Power Inverter
Power hook up
I have a Husky 750 watt power inverter, can I buy an adaptor that will plug into an interior power outlet and or cigarette light vice hooking up to the batteries. I plan on powering a laptop, cell phone and DVD player while traveling.
    President:
  • 710 Answers
This type of inverter has large alligator clips on it because the amperage that comes through a cigarette lighter is insufficient and can result in blown fuses and overheating of the socket. Hook this one up directly to the battery without splicing a longer wire to it.
Posted on Apr 22, 2009
I have a 3000 watt inverter,with 3 plug in outlet..how much power do I get from 1 outlet..this equipment is hook to 6 12 volt battery charge by a 60amp controller and 3 solar panel of 265watt each???
You didn't mention what make or model of inverter. Lets assume you are in the USA and your inverter has standard the US 15 Amp three pin 125V NEMA 5-15 AC outlets. based simply on that you would have a max of 125 x 15 = 1875 watts per outlet.
Dec 07, 2016 | Solar Electronics - Others
What's your problem?how many amps on a 1/2 horse sump pump
750 watts is pretty close to one HP. However, the pump will have a much higher current draw on start up which may be too high for the inverter. (The accurate number is 745.699872 Watts per Horsepower)
Discounting any losses, 750 watts from a 120 volt supply will draw 6.25 Amps. so 1/2 horsepower should draw 3.125 while running. Startup current may be much more. Check your pump for its current draw (should be printed on the pump) and check it against the inverter's limits. It may be that the inverter is too light for the pump.
Apr 28, 2012 | Black & Decker Husky 750w Power Inverter
Will a 750 inverter run a sump pump off of a deep cycle marine battery for a short period of time?
Looking at this, how many amps does the pump normally draw? Take this and multiply by 3 for start up current draw. Now, multiply that by 120 (volts) and this will give you the watts. Start up current is what will knock your inverter down. It won't kill the inverter but it will overload it on startup and turn off the unit. Since I do not know the size of your pump, this is my caution. You could always try it, the most that should happen is that the inverter will shut down.
Feb 05, 2011 | Black & Decker Husky 750w Power Inverter
I just bought a power inverter for use with my pc.
There are two possibilites: the first is the over 400W power draw, the other is how you have the inverter connected. Do you have the inverter connected directly to the battery terminals (the clips) not the outlet plug (cigaretter lighter)? This is needed for any load over 80W and under 400W. (the inverter can handle a load demand over the 400W limit but only for short periods (800W).)
What is the load that your PC pulls (Is it a laptop or a desktop)? The laptop in my home has either a 65W or a 90W load (depending on the battery and the AC adapter we are using). Desktops take much more power (usually).
I hope this helps.
Jul 15, 2010 | Black & Decker Power Inverter PI400AB
I bought two Victor 750 watt inverters ,and was led too belive i could stack them and get 230 volts. This did not work ! why.
In order to get 230 volts out of any 115 volt inverters you would need to be able to hook the outputs up in series with each other. If your inverters have outlets there is no way to do this other than completely dismantling both units and then I wouldn't advise it. As a licensed electrcian and electronics tech I've sometime done things like that but only as experiments or in emergencies.
If your units came with a power(+) and ground(-) you could then hook them up in series by fastening the (+) from one unit to the (-) of the other, then tape them to insulate them. You should then show 230 volts from the two leads still available. On the battery side you will still hook both postives(+) to the positive(+) and both ground(-) to the negative(-).
Notes:
* Depending on the internal wiring of your units the above description may not work and could damage or even ruin your inverters.
* Although you may get 230 volts this way you will not have more power(watts,Amps) than listed for one unit and you may even have less.
* You need to also beware this could VOID any warantees and shorten the life of these units.
May 31, 2010 | Victor Power On Board 1500 Watt Power...
Overloaded my inverter -now only works when hooked to car battery
It sounds like the fuse that protects you cigarette lighter is blown.
After you have replaced the fuse, check the voltage again. 0.015vdc would not have powered anything that in manufactured to operate on 12vdc.
When powering anything over about 250W, I would suggest connecting directly to the battery to avoid overloading the lighter circuit.
Nov 07, 2009 | Vector VEC1024 400 Watt Power Inverter
Need new car charger for the LMD model for my true tech portable DVD player
What about a small, light power inverter, that plugs into your cigarette lighter in your car, and has 100 Watts available?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3970959&CatId=237
(Your laptop won't EVEN use 100 Watts! Look at the Ac adapter. (Charger)
Read the specifications on it.)
Aug 07, 2009 | TruTech PVS12701 Portable DVD Player
Appropriate size inverter for sump pumps
First...you need to find the amperage on the pump...your inverter is rated for 6.25 Amps...(750/120)...you will need an inverter bigger then the pump..I would suggest at least 1.5 times the size of the pump..bear in mind,..the inverter wasnt designed to start motors...so oversizing is needed..
Hope this helps
May 05, 2009 | Black & Decker Husky 750w Power Inverter
Power inverter pc 500 once u put power to it the red light comes on and beeps but no a/c power
Hi there
Not a great solution but makes sense.
the ac adaptor for your alienware probably says input 240V ac 1.5Amps whilst the inverter can output 175W= 240V ac at 0.73Amps.
I am surprised it actually worked, i had to buy a 300W inverter to run my laptop. would suggest you do the same.
inverter is probably toast now anyway.
Feb 25, 2009 | Alienware PC Systems 175 Watt Power...
Is this inverter powerful enough?
You are right. This is not enough to operate this freezer. You are going to need a bigger invertor it get it to work properly 900 or 1000 watt should be efficient even though it is not the best way to run the unit. If the unit has a problem you would be replacing the inverter all the time. Just FYI
Feb 20, 2009 | Black & Decker Husky 750w Power Inverter
Black & Decker Husky 750w Power Inverter Logo
412 people viewed this question
Top Black & Decker Electronics - Others Experts
PNiss
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
