Question about LG LRSC26920TT Side by Side Refrigerator
How do you install water filter in LG Model LSC26905TT
Where it says the filter says to go there is no place to put it
BIKER T
  • 909 Answers
SOURCE: Filter bypass for lsc26905TT
locate water filter bracket(normally in fridge compartment), then use screwdriver to remove from the frame. You will see two plastic pipes connected to this bracket. one will be water in and the other water out. pull the two off the bracket and join them together. (be inventive). Connect your RO system to the main inlet after original water supply is removed. Remember, your "filter to be replaced" light will still flash after a period as the fridge has its own software, counting depressions for cartridge replacement. (you would painstakingly have to reset.}
Posted on Jan 30, 2009
catriver
  • 878 Answers
SOURCE: Water filter replacement
Fm, it's not threaded, turn it counter clockwise until it stops (should hear a click), then pull it out. Push the new one in all the way and turn it clockwise, you should hear it snap in. You may have to use a little force. If you are still having trouble, give them a call at 1-877-714-7481. Catriver.
Posted on Jun 29, 2007
  • 489 Answers
SOURCE: I have an LG LSC26905TT side by side fridge
When the filter freezes up, the outside casing may have cracked and will leak water when you dispense water through the door.  You will need to have the filter replaced and that should take care of the problem.  But the filter should never have frozen in the 1st place.  You will need to call a qualified LG technician to see what's going on inside the refrigerator.
Posted on May 11, 2008
Kewyn
  • 103 Answers
SOURCE: fan makes noise on LG lsc26905tt. defrosted and
Sounds like ice is building up near the fan blades. Try defrosting it longer to melt out all the ice and see if that helps.
Posted on Nov 09, 2009
jyackle5
  • 8197 Answers
SOURCE: Where a can buy the
You can get the filter on the links below.
http://www.bestbuy.com/site/LG+-+Replacement+Water+Filter+for+Select+LG+Refrigerators/6817484.p?id=1118840200017&skuId=6817484
http://www.purewatersite.com/lg-lt500p-refrigerator-fil500.html
Good Luck
Posted on Nov 08, 2010
LG side by side model# lsc26905tt, won't dispense water. I can hear the pump trying to pull water but the water is sitting in water line just outside of filter on the outside of fridge.
Sounds like the dual solenoid water control vave. Located in the back it will have two wire connectors going to solenoids. They are replaced as a pair and most local appliance dealers have universal replacemants. http://www.lg.com/us/refrigerators/lg-LSC26905TT-side-by-side-refrigerator
May 31, 2015 | LG Refrigerators
Lg refrigerator leaks water inside
Probably water reservoir is leaking. It or tubing going to it probably is cracked.
Sep 28, 2017 | LG LSC26905TT Side by Side Refrigerator
I changes my water filter on an lg fridge now i have white particles in the water
When you put in a new water filter on you should run the water for about 5 min.Hope this helps
Feb 21, 2011 | LG LSC26905TT Side by Side Refrigerator
Water overflows from icemaker & freezes in the freezer. Makes three ice cubes in a day & the water is extremely slow to fill glass from freezer door!
If both the water in door and ice maker are experienceing slow water problems the common point is the water supply itself.
This can be caused by:
1. Water supply shut off valve is partially closed or blocked with debris.
a. TURN water supply OFF
b. Remove the water line from the rear of the refrigerator ABOVE the in line filter (if one is installed)
c. Place the removed line into a bucket.
d. Turn on water supply and check flow. It should fill an 8 Oz glass in about 8 seconds.
If it passes this test then the water supply is fine. If it FAILS this test either cflear the obstruction in the line or replace the water supply valve from the house connection.
Test 2 (Water supply is OK
Reconnect water supply to external in-line filter (If installed) or water valve assy connection.
Your unit has a Verticle filter that if it is clogged will cause slow water flow.
Test water thru the door for the same amount of water flow. It should fill an 8 Oz glass in 10 seconds or less.
If it does ot do this then the VERTICAL internal water filter is clogged. (5 months or 500 Gallon change interval)
REPLACEMENT filter is PN LT500P but there are several like / suitable aftermarket replacements for the LT500P number.
As for the ice maker freezing up. There is only one cause for this and that is the water valve assy itself is bypassing water when it is supposed to be closed. The only remedy for this is to replace the water valve. They are not repairable.
The valve is available through sears parts direct:
http://www.searspartsdirect.com/partsdirect/part-number/LG-Parts/Refrigerator-Parts/5221JA2006D/0046/795/Model-LSC26905TT/3204/0165000?keySuffixId=NA&productTypeId=x&searchModelNumber=LSC26905TT&subCompDesc=Ice/water%20parts&brandDesc=LG&modelDesc=REFRIGERATOR&blt=11
Thanks for choosing FixYa.
Kelly
Sep 19, 2010 | LG LSC26905TT Side by Side Refrigerator
Do all ice maker refrigerators have filters on the water line
Most refrigerators dont have one, Usually you can install on in the supply line. If there was on it might be behind the frig
Jun 11, 2009 | LG LSC26905TT Side by Side Refrigerator
Insall water filter
there are lots better filters then the ones that go into the fridges install an inline filter into the water line before the fridge that way you filter both the drinking water and the ice maker any hardware store will have them usually your water supply is tapped into the cold under your kitchen sink this is a good place to put the filter if you are connected there
Apr 22, 2009 | LG LSC26905TT Side by Side Refrigerator
Install water filter
the filter is in the refrigerator side not the freezer side. It is next to the light bulb.
Customer service is 1-800-243-0000 for LG
Using without water filter
The effort it would take to eliminate filter would be too much. Just leave filter in place. If new house filter is working right you should never have to replace fridge filter and your water will be double-filtered :)
Jul 02, 2008 | LG LSC26905TT Side by Side Refrigerator
LG LRSC26920TT Side by Side Refrigerator Logo
264 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
