Question about Toshiba Satellite Pro L300 Notebook
Frezzin laptop the laptop i got now it keeps frezzin and runing slow it a toshiba L300 help pls
  • paddleboats1 Apr 26, 2009
    No notifocation that anything is about to happen before the FREEZE. Can work for quite a long time or just after I turn on my Computer. Also have a blue line thru the screne appears when opening up new page or in email. Does anyone know the problem.
  • Toshiba Master
  • 19,396 Answers
The laptop can be freezing for a system problem or for luck of resources.
The most common reason for slow processing speed is insufficient RAM memory.
Increase the RAM, if RAM available is no more than 512MB, then it must be upgraded.
If RAM is enough then a way to test RAM for faults is removing one module at the time.
Check also your hard drive state. If you have less than 1GB free, that will slow down the system. Go to Start>>Programs>Accessories>System Tools>Disk Defregmenter and do a Defrag of the hard disk.
If you have at least 1 GB RAM, and you took care of the hard drive, then you can check the process starting up on their own and remove the useless one, or spot mala-ware that can affect speed. You can use a software like Hijack This, and search on google te function of each process started on the list reported by the software.
You can download Hijack this here MajorGeeks | If download does not start, then click at the top of the page, where it says Click Here If It Does Not.
Be careful if you delete the wrong files using this software you can harm the system, and Windows may not work properly.
If you think you have malaware you can also install Spy Bot, and do a system scan. Download Spybot from The home of Spybot.
If all the above does not work, and there is no malaware, then you usually reinstall the system.
Check also the bios settings, BIOS can downgrade the CPU speed on default , even if this is uncommon on recent BIOS.
If a computer is still slow with a fresh system and enough resources then it is one of those rare occasions when you have an hardware fault.
Hardware that can cause slow down is: RAM CPU Motherboard HD Video card.
Some tips on procedure can damage your windows installation. Do not download Hijackthis software and do not change BIOS settings and do not touch hardware unless you are sure of what you are doing.
Posted on Apr 28, 2009
Toshiba Satellite l300 1ap windows 7
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Oct 15, 2012 | Toshiba Satellite Pro L300 (L300-EZ1502)...
I updated my toshiba l300 pslgbe's bios from the 1.80 to the 2.2, now everytime i turn my laptop on, it shows a blue screen with an error. my laptop is now completely useless
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
May 18, 2011 | Toshiba Satellite Pro L300 Notebook
Hi i have a toshiba satellite l300 the battery
For Award BIOS' try these backdoor passwords:
AWARD_SW
j262
HLT
SER
SKY_FOX
BIOSTAR
ALFAROME
Lkwpeter
j256
AWARD?SW
LKWPETER
syxz
ALLy
589589
589721
awkward
CONCAT
d8on
CONDO
j64
szyx
For AMI BIOS' try these backdoor passwords:
AMI
BIOS
PASSWORD
HEWITT RAND
AMI?SW
AMI_SW
LKWPETER
A.M.I.
CONDO
For PHOENIX BIOS' try this backdoor password:
phoenix
Jan 14, 2011 | Toshiba Satellite Pro L300 Notebook
Laptop toshiba l300 series always shutdown less than 1 hr.
This is due to the machine's overheating problem. You may have to purchase a good laptop cooler in order to keep it cool underneath. There is unfortunately nothing else you can do.
Mar 17, 2010 | Computers & Internet
Cant type @ key in toshiba satellite L300 laptop
you need to change the layout of your keyboard. "Regional Settings" in windows.
Check on http://en.wikipedia.org/wiki/Keyboard_layout what your layout is and configure the correct one in the operating system you are using
Aug 11, 2009 | Toshiba Satellite A60 Notebook
My toshiba L300 keeps freezing and shutting down
How many MB YOUR RAM/ may you have lowest of Ram 256MB/ or 512MB only.....that why freezing your laptop. make it upgrade your RAm ...now adays all programs are updated to new versions.. if you using os xp -- sp2 or sp3 or higher than.. atlest you have minimun of ram 1 or max. 2gb..if VISTA min. 1 max 2 or 3GB
also alot of viruses.spyware or all unwanted programs. programs can make slow of operating system....., check first your programs then hardware .. change it if nessesary.
May 26, 2009 | Toshiba Satellite Pro L300 Notebook
How do i set back to factory default for toshiba l300
yes actually this conficker april fool virus have struck thousands of systems
pls try to restore it from the Os partition like this
Toshiba: BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
if u successfully restore ur Os like this otherwise let me know
Apr 08, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite Pro L300 Notebook Logo
89 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
