Question about HP Color LaserJet 3500 Printer
Hp lj 8150 error 50.1fuser error
Dear sir, i got hp lj 8150 printer, problem with 50.1 fuser error , for this matter i all ready installed new fuser unit , but still , i received the same error massage. so pls help me to fix this problem, as iseach in net i found problem of law voltage , so found some dry soldering in power board , i fix that also, still received the same masage , pls help me on this which component i need to replace thanks , sanjaya
Replace the LVPS and the fusing unit, you will also need to leave the machine off for 20 minutes to reset the error
(If anyone is in need of a free service manual, send me an email with info to reply and ill send you one)
Posted on Mar 05, 2010
I had the same message in the lj8150 and when I looked up in the manual it pointed me to the LVPS I replaced it and it is working fine
Posted on Jul 22, 2008
  • 363 Answers
Unless someone else replies with the identical fault and remedy, my best suggestion is to get a copy of the service manual. There may be a fee but you will be sure of following the correct diagnostic procedure. It sounds like you are capable of this. Good luck.
Posted on Sep 23, 2007
I am not clear as the whether you put the errant fuser in the machine that was working and put the good fuser in the bad one so now you have 2 that don't work. If that is the case it is possible that the bad fuser has taken out the good machine. There are resistance tests that should be run on the fuser to see if it is shorted out. If it does short out, you may need to replace an internal fuse or link on the board.
Oct 23, 2017 | HP Office Equipment & Supplies
Lj 8150 papr out from fuser door
I have an idea of what the problem is but could you please elaborate.
Jan 08, 2015 | HP LaserJet 8150 Printer
How do I solve this problem? My hp LJ 4345 printer experiences intermittent paper jam in fuser(accordion-like) with half of the paper out of the fuser. We've replaced the fuser with a new one but the
This error can be caused by the following:
1. Fuser that is close to end of life. Maximum print quantity is 225,000 pages.
2. poor quality paper, very thin paper never feeds well and will jam.
3. Printing an image that is almost entirely black can cause the paper to buckle before entering the fuser.
Try different paper to see if that resolves the problem.
Sep 02, 2014 | HP LaserJet 4345mfp Printer
I have hp lj 1300 printer befor problem fuser sleeve damage that is repalacing and fixing but now not working only read light bilnking how can repair sir
red light blinking gnerally for
1.door open cartridge
3.fuser element blown( measure fuser element with volt meater)
4.sensor error
and so many
these are the mejor.
Jan 09, 2011 | HP LaserJet 1300 Printer
Jam in tray 2
This is an update to:
HP LaserJet P4015 - Not Picking Up Paper
HP now recognise this as a manufacturing fault and have released a service note for it and will send you a new fuser free of charge. The description of the fault is:
When a print job is sent to the printer, the printer will display processing job on the control panel, and will continually ramp up and down attempting to print the job. After several minutes the printer will return to ready without posting any error messages. Occasionally, after several minutes the print job will print.
The fix for the fault is:
The fuser needs to be replaced and firmware needs to be upgraded to version 04.060.7 or higher.
The customer will need to download the latest firmware from, version 4.060.7 or higher. The firmware can be downloaded from hp at "" . Select Download drivers and software (and firmware) in step 1 and in step 2 type in the printer name, LJ P4014, LJ P4015 or LJ P4515
It's probably best to update the firmware before you phone HP to report the fault, or at least tell them you have. If you do update the firmware, you will notice some extra numbers and letters on the display when the printer initialises. This is normal, it's probably used by HP staff for diagnosis.
The fuser is a customer replaceable part, and does not require a service technician to install. If the customer requests a service technician to install the fuser the customer will be responsible for the labor. The fuser can be sent directly to the customer with instructions to upgrade their firmware.
What this means is that HP will send you a new fuser to fit yourself.
The models covered by this service note are:
HP LaserJet P4014 Printer series, HP LaserJet P4015 Printer series, HP LaserJet P4510 Printer series.
Start: 2010-01-01
Expiration: 2010-12-31
What this means, is that HP will send you a new fuser for this fault until the end of 2010, although they do sometimes extend the active time period for service notes.
Hope it helps..
Thanks for using fixya......
Nov 08, 2010 | HP LaserJet P4014n Printer
50 .2 Fuser Error in HP Laserjet 4100N
you need an maintenance kit 4100
ACC C8057A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8057-67901 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8058A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 220V, LJ 4100 LJ 4100 Series
Selected Item RG5-5069-000 See RG5-5069-090 Not Available 0
Alternate Item(s) RG5-5069-090 Fuser Film ***'y, 220V, LJ 4100 180.50 2
HP LJ 4100 Fuserkit RG5-5069 HP
Dec 11, 2008 | HP LaserJet 4100n Printer
50.1 Fuser Error on our HP 8150
You should replace the whole LVPS and not just the voltage regulator.
Jun 10, 2008 | HP LaserJet 8150 Printer
Hp 4250 error code 50.3
Apr 15, 2008 | HP LaserJet 4350 Printer
HP Color LaserJet 3500 Printer Logo
257 people viewed this question
Ben Johnson
