Question about GE Spacemaker JVM1640SJ Microwave Oven
Damaged door on microwave
My daugther cooked popcorn in a metal bowl in the microwave. There is noticable damage to the inside of the door. More specifically the inside of the door has burn mark and small section (maybe 1/8'') is actually burned out. The exterior of the door does not show any signs of damage. The microwave does appear to work properly,but I am concerned that there maybe some leakage of micrwave energy if I us it.
Carl
    Scholar:
  • 126 Answers
The glass if you look at it has a screen sandwiched inbetween glass that dicapates the energy from exiting through glass. If it is burned to that depth then concern would be a priority. The screen should still work as normaly would,but if it is bare to the interior then it might get heated when unit is operating.Replacing glass is not to bad to do,the inner side has plastic insert that snaps in and can be removed by prying it out < using small flat tool such as slim puddy knife and then ther may be a few retainers for glass> it snaps in from outer edge.
Posted on Apr 22, 2009
  • 10,865 Answers
Buy a detector to test your microwave to be sure it is not leaking radiation. The detectors range in price from ten dollars to about thirty five dollars and can be purchased in most hardware stores. If you discover that the microwave is leaking radiation, never try to repair this appliance yourself. Take the microwave to a professional for repair. All things considered though, the microwave oven is fairly inexpensive these days it may be a better idea to just purchase a new one.
Shut's off after cooking popcorn, only popcorn, won't restart for 15 too30min.
Sounds like the magnetron is over heating. Try putting a 4 0z cup of water in the oven along side the popcorn bag. See if this helps. Usually, the oven only runs 2 to 2.5 minutes for a bag of popcorn. You may have to experiment with the slightly different cooking time...
Oct 29, 2013 | Magic Chef CMV1000B Microwave Oven
Arcing sharp carosel microwave when i put orville redenbacher mini popcorn bags in i found oil on outside of bag
Arcing will occur if you have any metal inside the microwave, or if the powder paint on the inside has been damaged. If the paint is damaged dispose of the microwave
Oct 24, 2013 | Sharp Microwave Ovens
Sharp R305KS Stainless Steel 1100 Watts Microwave Oven problems:1.5 years old. We put in a microwave popcorn bag and had bright flashes going off as though there was metal left in there and gurgling...it...
unplug microwave.
Take ALL dishes out of the microwave and do a proper check of the inside the cooking area. If you are sure that's ok put the glass dish back in if it has one.
Test that the oven and grill are still functional.?
Do they heat up? If they do then get one of those microwaveable bowls or dishes and put some water into it. Place it back into the microwave and do the check again on microwave heating.
Does it bang or spark again?
If it does and the other heating is OK then the Magnatron to me sounds as it's on it's last legs.
That does not mean you have to scrap the microwave if it is the Magnatron. as a new one can be purchased and installed.
Apr 12, 2017 | Sharp R305KS Microwave Oven
While cooking in our Whirlpool GH5184 microwave an arcing appeared near the L/H lower corner of the unit. After shutting it off we observed a black arc mark on the inside of the door and a small hole from...
This is caused by either carbon arcing from carbonated food deposits or metal dish or bowl being used inside the machine causing a track. Even a recycled paper towel can cause it as the towels have metal traces in them.
Dec 13, 2010 | Whirlpool GH5184XPQ Microwave Oven
Viking professional vmoc205ss convection Cooking POPCORN
You need to use one of the metal racks that came with the Viking microwave to raise the popcorn bag off the bottom of the microwave. It works great!
Apr 06, 2009 | Microwave Ovens
No homegrown popcorn in a microwave? why?
Popcorn is a food that has a very low moisture content, and microwave ovens rely on moisture content (water molecules) in order to cook.
If there is not enough moisture to absorb the microwave energy, much of the the energy is reflected back to the magnetron and damage it.
This is also what damages a microwave when it is run empty.
A simple solution is to add about 1/2 to 1 cup of water in a microwave-safe container in the back corner of the oven and cook your popcorn a little longer.
You'll have to experiment a few times to get the combination right for your particular model.
But allow our microwave about 15 minutes or so for the magnetron to cool down between popcorn cooking sessions.
Also, I would suggest putting a paper plate upside-down on the turntable tray, then putting the popcorn container on top of that.
This does two things: It keeps the extremely hot popcorn off the tray, reducing the chances it will crack, plus it raises the popcorn up so it will heat more efficiently.
Dec 23, 2008 | Microwave Ovens
Viking microwave oven
If you mean that the automatic popcorn cooking is not working properly, it's probably a bad humidity sensor.
If it's still under the one year warranty, they'll replace it free. Otherwise, they can steer you to a Viking-authorizes servicer.
You can contact Viking customer service here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 30, 2008 | Viking DMOC205SS Microwave Oven
Dacor Microwave/Conv Oven DCM24S
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
Apr 15, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Leaking microwave oven???
The steam is perfectly safe, as with any other oven it has vents. Just as long as the door is shut and intact your safe.
Mar 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave ovens
The cover is probably the magenetron. That is where the microwaves come from. If the bread was moist, it might have left condensate in the unit which is causing the sparking. Unplug the unit, leave the door open over night. If you can remove that cover, do so. Be sure to carefully replace it before using the unit. Never turn on a microwave with nothing in it.
Dec 16, 2007 | Sharp R-1480 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
443 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
