Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Fuzy color contrast an spidder webs waving in pitcher not sharp
Never had inside clean, not getting sharp bold color, have disk sattlelite HD. Pitcher dose not compair with other philips. I would take the back off an clean the webs an dust out if i know that i will not damage somthing or cause other problums, like something falling or unattched by removing the back cover.
    Novelist:
  • 159 Answers
The best process always starts with the tv unplug from power. after this done have a illuminated room to see what you're doing.
This tv has a back cover really easy to un-screw and actually is light. so take it apart and you are ready to clean the inner area. do so with a soft cotton cloth. the back cover is covering the projection area be careful to control you movements because a back mirror is used that actually is not glass instead is a kind of plastic easy to break it. ones the cleanning in the lenses, don't press hard the glases, that area can miss align easy. other than those conciderations i think is not difficult to do that process.
Posted on Apr 25, 2009
The black plastic screw on bottom of the pitcher is stuck on the base. We can't seem to get it off. Have any hints
Put the pitcher in the freezer for an hour, boil water in a pan bigger than the base of the pitcher, take the pitcher out of the freezer and stick just the base in the hot water up to the top edge of the base.. Remove it after about 15 seconds and have someone with gloves on screw the base off the pitcher
Aug 20, 2015 | Blenders
Pitcher is not very sharp
Without knowing the brand and model number only guesses are possible----does it do it with a dvd hooked up to a rear input?
Oct 26, 2012 | Televison & Video
HELLO , I have sound but no pitcher MODEL #51PW9303/17F
If the picture was somewhat 3d looking before with colors out of line etc--what you have is a convergence problem that has got worse.
Seen a number of sets with this problem--on this model only way to know is locate the two chips, get at them and unsolder all pins on each--if set then comes on (will look bad) you know both chips need to be replaced.
If this is beyond you set is old enough to just replace it--average shop cost for this is over 200 parts and labor.
Let me know if you have questions.
Jun 11, 2012 | Philips Televison & Video
How to use mr coffee tea appliance
First clean the pitcher, lid, steeping basket and steeping basket before you use it the first time. Run a brewing cycle without any tea the first time and discard the water.
With the unit unplugged, fill the pitcher with water to the top water level mark on the pitcher and then pour the water into the reservoir. Do not overfill. Place the steeping basket and lid on top of the machine. Place a tray of ice cubes into the pitcher. Turn the steeping dial to open. Put the lid with the spout open on the pitcher and slide it, spout first, under the machine. Plug in the unit and turn it on. Wait until it turns off automatically.
For brewing, fill the pitcher with water to the line for the desired amount of tea. Pour this water into the reservoir (with the steeping basket and lid removed). Place a Mr Coffee filter into the steeping basket and add the desired amount of tea bags or loose tea. You can add sugar or lemon over the top of the tea if desired. Slide the steeping basket into the unit and put on the lid with the steeping dial set to closed. Fill the pitcher with ice to the desired ice level or with cold water to the same volume as poured into the reservoir. (If you are using water, put the pitcher in the refrigerator to chill.) Slide the pitcher with the lid on under the brewer and make sure the lid is open over the spout. Plug in and turn on the brewer. When the brewing cycle is done, it will turn off. Turn the steeping dial to open to drain the remaining tea from the steeping basket. (Let the remaining tea sit longer before opening the dial if you want stronger tea.)
You can get the manual from http://www.mrcoffee.com/Products.aspx?cid=43 . Click on the link for the TM3 (all the models in a series work the same way).
I hope this helps.
Jan 16, 2011 | Sunbeam Mr. Coffee Iced Tea Maker, TM3PS...
Pitcher has double pitcher and one is in diffrent colors .also have a line about 4" from bottom of screen.
you need new convergence chips, 2 chips stk392-110, they have to be soldered in, very common problem, you also want to t\check for burned resistors around the convergence chips.
Sep 14, 2009 | Hitachi 57F710 TV
Anyone solve the pitchers in puzzle 78
1) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher. (leaves 7 litres in Pitcher 16)
2) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher. (leaves 2 litres in Pitcher 9)
3) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (leaves 0 litres in Pitcher 7)
4) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 0 litres in Pitcher 9)
5) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher (leaves 5 litres in Pitcher 16)
6) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 4 litres in Pitcher 9)
7) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (leaves 0 litres in Pitcher 7)
8) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 0 litres in Pitcher 9)
9) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher (leaves 3 litres in Pitcher 16)
10) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 6 litres in Pitcher 9)
11) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (leaves 0 litres in Pitcher 7)
12) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 0 litres in Pitcher 9)
13) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher (leaves 1 litre in Pitcher 16)
14) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 8 litres in Pitcher 9)
15) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (Pitcher 16 also has 8 litres)
YOU NOW HAVE 8 LITRES IN THE 16 & 9 LITRE PITCHERS.IN 15 MOVES.
Apr 24, 2009 | Nintendo Professor Layton & the Curious...
Cleaning ice tea maker
Try to do that
  1. Pour 1 quart (32 oz.) of undiluted white household vinegar into the water reservoir.
  2. Place the pitcher lid on the pitcher. ...
  3. Push the "on" button to begin brewing cycle. ...
  4. Re-plug the cord. ...
  5. When your machine shuts off, unplug the cord, remove the pitcher.
Feb 24, 2009 | Sunbeam Mr. Coffee Iced Tea Maker, TM3PS...
Glass Pitcher
Replacement pitcher is available at: http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3743&secid=53&linkon=category&linkid=87
Jul 31, 2008 | Back to Basics IT400 TEA MAKER 2.5qt GLASS...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
