Question about Toshiba Satellite Pro L300-EZ1004X Notebook
Runnin slow and keep on frezzing
My laptop L300 is runnin slow and it keeps on frezzing
  • Richard Finney
    Richard Finney May 11, 2010
    Where does it freeze on you ?
    is in the same programme everytime ?
    when online ? when booting up ?
    Running slow could be a few things, so cleanup, disc clean, defrag. Temp files, cookies, cleanup the desktop, empty recycle bin, increase the page file size, delete duplicates,
    update O/S, update anti-virus, run full system scan, backup to external hard drive, remove old/unwanted programmes, remove data to the external drive if you don't use it, but still want it.
    add RAM, use less applications at once,
    MSCONFIG in the run box, untick programmes you don't want to start at start up time IE: instant messaging,
    Checkout RAMBooster free software.
    I.M. takes alot of RAM/CPU cycles off you.
    close I.M. if not in use.
    Hope this helps
    Richard
Cant get on facebook
you need to understand the problem which causes it to become slow. Once you restart, see if the hard disk light is continuously showing some activity. It is possible that you don't have enough RAM and in that case PC becomes slow as all the time hard disk keeps spinning. Open Task Manager and check which process is consuming high CPU/Memory. There is Resource Monitor in performance tab which show the processes consuming high Disk/memory/CPU. CHeck what that process is and uninstall that application or switch off that process. Keep searching based on what you find doing this.
Dec 09, 2013 | Facebook Social Network
Why is my computer runnin so slow and freezing can this be fixed
If we knew the Make, Model of laptop and the OS we could help you.
Mar 05, 2013 | Computers & Internet
What do I need to do to speed up my Dell E1505 Laptop, it's running slow
A slow Dell laptop can be caused by many many reasons such as outdated hardware, overload start up programs, corrupt registry issues, too many junks, virus attack, poor security software taking too much system resources, remnants of uninstalled applications etc. The fact is, you should keep some system maintenance job regularly. If you don't want to do the job manually, try the Dell speed up solution available here: http://www.speedupslowdell.com/ best regards!
Feb 27, 2012 | Dell Inspiron E 1405 E 1505
Everytime I play video clips on YouTube I keep having buffering problems like play then stop then play then stop then play then stop continuously.
Once the page has loaded and the video is starting to play, pause the video and let it load completely before playing. The problem is either youtube and some specific videos and/or you have a slow connection and are having difficulties with streaming content.
Feb 27, 2011 | Toshiba Satellite Pro L300 Notebook
Drivers
Hi There you should be able to find all the drivers you need from here http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
that is the good thing about Toshiba they keep drivers for all their laptops even ones that would now be over 12 years old
Jul 24, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite Pro L300 keeps locking up for no reason. After turning it on for awhile the mouse won't scroll anything or select anything and the only thing I can do is turn off the power and take the...
Open the "Task Manager" by (right ) click in the Statusbar, located in the same (level as the start button). Next see how many Processes are running? If the (number) of processes running are between 75-80, the Computer is running very slow, this could be a ("Low") Memory problem, you can check the "memory usage" in the "Task Manager" as well. Try to "Shut-down Non-essential programs from "start-up."
Jan 22, 2010 | Toshiba Satellite Pro L300 Notebook
My toshiba L300 keeps freezing and shutting down
How many MB YOUR RAM/ may you have lowest of Ram 256MB/ or 512MB only.....that why freezing your laptop. make it upgrade your RAm ...now adays all programs are updated to new versions.. if you using os xp -- sp2 or sp3 or higher than.. atlest you have minimun of ram 1 or max. 2gb..if VISTA min. 1 max 2 or 3GB
also alot of viruses.spyware or all unwanted programs. programs can make slow of operating system....., check first your programs then hardware .. change it if nessesary.
May 26, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite Pro L300-EZ1004X Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
