Question about Goldstar M1004R 10 000 Btu Window Air Conditioner
Unit doesn't turn on at all. Used to work and just quit
I have an M1004R 10,000 btu a/c unit and it doesn't even turn on at all.
  • 128 Answers
Pls check power supply then check the unit switch (selector)
Posted on Apr 25, 2009
My LG Model LP0910WNRY2 will not get cold even though the compressor turns on
check the outside and see if its blowing cold air out of condensor otherwise low on freon.
Jun 28, 2014 | Amana AH123E35AXAA 11,600 / 11,200 BTU...
Window air conditioner cools (very icy cool air) for a minute or two then switches to fan. Will then stay on fan for about 10 minutes and then once again get "very cold", but only for a minute or two
Before I even read that far into your post, I was thinking "thermostat" replace it...It seems to be failing badly. If you take it into logical perspective...normally the unit gets turned on, then takes a bit to get cold, then once it reaches its pre-determined temperature, turns the unit either "off" or just blows the fan...by kicking off the compressor. This unit you have is getting this cycle done within 5 minutes instead of a few hours...replace the thermo and you should be fine. Now if you could post the exact model number here I can go look up the part for you.
Jun 20, 2012 | Amana AH123E35AXAA 11,600 / 11,200 BTU...
I have a Emerson Quiet Kool Model # 12JW42K that is 13 years old. It doesn't seem to cool the apt. anymore. I assume that it would be smarter to get a new "energy saving" unit than invest in...
I know that a Island Air units come in all shapes and sizes and they make a ton of different units. They are made in new york thats who I would use. I would definitly go with the 12,000 btu unit 500 square feet needs 12,000 btus 10,000 is under sized. 500 square feet divided by 500 = 1 ton of cooling. let me know if I can further assist.
http://www.islandaire.com/
Jul 23, 2011 | Heating & Cooling
I have a Danby Silhouette 10,000 BTU portable A/C.. it has recently stopped turning on. The panel with buttons lights up and works, but the unit itself will not turn on. Any ideas on what the problem is?...
If the unit was set in Automatic Timer Mode, it will not turn ON until the set time is reached. Try deactivating the Timer Mode. If that doesn't work. Turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes. During this timeout, the unit should have time to reset itself, so that when you plug it back in and turn it ON, it will have reverted back to the original factory settings.
If you have misplaced your Owner's Manual, I have included a link to a Danby Model that is similar to yours, in the way that it functions. You can download and print the manual for future reference if you like.
http://www.danby.ca/cms/uploads/products/en_manual/DPAC10011_DPAC10011BL_EFOM_v2.pdf
I hope this helped you. Please let me know. Thanks.
Jun 28, 2011 | Danby DPAC10031 Silhouette 9,000 BTU...
I have a Haier ESA406K 10,000 BTU's that just
sounds like you have a small refrigerant leak which would at first result in the evaporator coil freezing over, then eventually not working at all.
Jun 11, 2011 | Haier Heating & Cooling
AC was cooling fine. Now, won't cool room even though cool air comes out. Exhaust hose is extremely hot.
Check filter, if you have a 5000BTU unit (small) and it is extremely hot, then it wont work great for a big room. BTU is the rate of what the AC will put out. 5000 BTU is good for a small single room. 10,000 will cool a bigger room and 18,000 btu is meant to cool a home.
Jul 07, 2010 | Whirlpool ACP102PS Portable Air...
I need an idea of square foot coverage
There are more factors than sq ft. You have to factor in window surface and R factor of insulation.
Aug 18, 2009 | Heating & Cooling
The 10,000 BTU portable room a/c unit is not running cold enough
Make sure your vent is closed. check the filter to see if its clean. If you run the a/c you can check your evaporator to see if you have condensation or does it freeze up?
Make sure you have your unit on early in the morning. If you turn it on in the afternoon the humidity might be too much and it will take along time to cool down.
Try those things if that doesnt work then you need a service call.
Jul 10, 2009 | Whirlpool ACP102PR Portable Air...
How large a room does a 10,000 btu air conditioner cool
What size unit do I need for my room? Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
if this helps please vote me a fix ya
Jul 21, 2008 | Heating & Cooling
Heating & Cooling Logo
275 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
