Question about Maxon MCB-30 40-Channels Base CB Radio
How to hook up cb with no amp on 02 ford ranger?
I need a manual for texas ranger free spirit cb model tr127fs manual. Can you help me?
I would try using the manual for the TR 127GK or the DX models and see how they work out for you. I did a google search and came up with nothing.
Aug 14, 2014 | Radio Communications
What amp power supply is needed to power ranger rci 69ffb4 radio
I would say a minimum of 40 amp continuous. Watts divided volts equals amps
May 20, 2014 | Ranger Communications RCI69FFC2 CB Radio
Manual de como instalar el sistemas de a/c ford ranger 1993
Look , I don't speak a forign language but I can get what you are saying . ford rangers from 1993 to 2003 should all have interchangeable parts ,Mine does.
Apr 25, 2014 | Cobra 29 LTD CB Radio
What is a 20 amp cb fuse
a 20 amp cb fuse is large fuse usually located in a plastic case in the engine compartment. This fuse is over 1 inch long and I believe the 20 amp is green in color and should say 20 on the top. On a Ranger it is usually located on the Driver side of the engine compartment close to the brake booster.
Sep 30, 2010 | 1994 Ford Ranger Supercab
Lack of receive on a ranger 2950
Bad mic? dirty mic pins? If the mic is bad, you will have no receive.
Nov 10, 2009 | Ranger RCI-6900F-25 CB Radio
Wiring a Silver Eagle six-pin for a Ranger 6900 F150
PIN #1 is common & shield(black&braided) 2 audio(white) 3 tx(red) 4rx(blue) if you knew what it was hooked to before it would be helpful.
May 28, 2009 | Ranger RCI-6900F-150 CB Radio
I need a fuse box diagram for a 1992 Ford Ranger. Any idea where I could find one?
owner manual.
here's the big ones for 1994 ranger. all i have
Section 18-01: Wiring and Circuit Protection 1994 All Ranger, Explorer and Aerostar Vehicles Workshop Manual
SPECIFICATIONS Specifications
High Current Fuses And Circuit Breaker — Ranger 2.3L, 3.0L And 4.0L
Circuit Size Location Electric Fuel Pump 20 Amp Fuse Power Distribution Box Headlamp Switch Feed 40 Amp High
Current Fuse Power Distribution Box #36 Circuit Alternator Output #2 15 Amp Fuse Power Distribution Box Fuse Panel 60 Amp High
Current Fuse Power Distribution Box Power Locks 20 Amp High
Current Fuse Power Distribution Box #38 Circuit Alternator Output #1 12 Ga Fusible
Link Integral with 14305 W/A Powertrain Control Module and Power Relay 30 Amp High
Current Fuse Power Distribution Box 4x4 Electric Shift 20 Amp High
Current Fuse Power Distribution Box Ignition Switch Feed 60 Amp High
Current Fuse Power Distribution Box High Beams and High Beam Indicator 22 Amp C.B. Integral with Headlamp Switch Front Wiper and Washer 6 Amp C.B. In Fuse Panel Power Windows 30 Amp C.B. In Fuse Panel Cigarette Lighter, Flash to Pass and Power Lumbar 20 Amp C.B. In Fuse Panel
May 13, 2009 | 1992 Ford Ranger
O reading for O2 sensors on 98 Ranger XLT
Yes the 98 ranger has 3 02 sensors,they are located in the exhaust system under vehicle,2 of them
are in front of the cataletic converter and 1 behind it.I replaced mine ,reset the codes and the check
engine light still comes on?
Jan 16, 2009 | 2004 Ford Ranger
Maxon MCB-30 40-Channels Base CB Radio Logo
236 people viewed this question
Top Maxon Radio Communications Experts
Steve
Van Allen II
Van Allen II
tvopft
Level 1 Expert
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
