Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
I was changing my filter in the ge filtration system, and it says to turn off the water and press the red button. Then it says to unscrew the filter take the old one out and clean the filtrstion system then put the new filter in and put the filter system back together then turn the water back on. When I do this the water starts to leak out where the red button is and will not stop?
  • Fresh Water Systems
    Fresh Water Systems May 11, 2010
    What type or model number is your GE Filtration System?
    President:
  • 3,433 Answers
Before putting cover on, chk the button to make sure it isn't staying depressed and see what the button is doing when depressed. The cover may have to be in a certain position. with the cover in place, gently rotate untill button pops up
Posted on May 07, 2009
HOW TO CHANGE A GXWH20S FILTER
You need to cut water supply to filter, you may want to put a bucket or something to catch water under it, then, press the button on filter to release pressure in filter. If you have a wrench for it, the wrench should slide up from bottom and engage ribs on side of filter. Turn counter clockwise to remove, sometimes you can do this by hand. You can also use a strap wrech, just don't break canister. You also want to try not to strain your pipes if they are not supported. Any way, you may have to figure a way to grip canister to twist off. You do not want to overtighten for this reason. After you change your element, make sure the o-ring in the lip inside of canister is in place. Twist back on, clockwise. Turn your water on and check for leaks.
May 07, 2011 | General Electric GE SmartWater Household...
I have no hot water in my home i can not locate the reset button
The reset button is located on the top thermostat, on the heater you will see a acess panel with screws in it to remove the thermostat and element is behind this panel. Once removed the top thermostat should have a red button to press to reset heater.
If it resets then wait for a little time for hot water. If this doesn't work then it could be the elements are in need of changing.
Apr 09, 2011 | General Electric GE SmartWater Household...
Canisters on my ge smart water filtration system gxsv10c model are stuck tight. How do i get them open
Make sure the water is turned off to system. Open the faucet to system to drain any water and keep the faucet turned on to keep pressure off filter housings.
1.Use the wrench to take housings off.
2. If they still won't budge take a small 2x4 block of wood and hammer, set the block of wood on the RIB for the housing and tap with hammer.
3. Change the o-rings in both housings, lubricate with silicone lube and lubricate the threads on housings with silicone also.
3. Rinse housings with small amount of bleach and clean thoroughly.
4. Replace filters and housings.
5. IMPORTANT: Only tighten housings by hand. NEVER tighten housings with wrench.
RJ
Nov 10, 2010 | General Electric GE SmartWater Household...
The red pressure relief button on my GE Smartwater GXWH35F whole house water filter system doesn't seem to be relieving pressure. As a result I cannot turn the filter cartridge in order to replace the...
To replace the filter cartridge. Do the following;
1. Assuming that you have a pump in your water filter
system, shut it off.
2 Close the intake valve before your filter system.
3.To relieve the pressure, open the faucet after your
filter system. Any of your faucet for that matter.
4.Once the pressure is relieved, you can of course
replace the the filter cartridge.
Nov 26, 2009 | General Electric GE SmartWater Household...
I was changing my filter in the ge filtration system, and it says to turn off the water and press the red button. Then it says to unscrew the filter take the old one out and clean the filtrstion system...
The red button is a pressure relieve valve. If the system is leaking from the valve, try pushing the valve up from the underside of the cap where the valve is located. If this does not work the housing needs to be replaced. You do not have to replace this with a name brand like GE. All you need to do is make sure the housing that you are purchasing is the same size.
Example of Replacement Filter Housing: http://www.freshwatersystems.com/c-107-filter-housings.aspx
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Apr 27, 2009 | General Electric GE SmartWater Household...
Slow water flow from GE SmartWater under sink water filter.
I solved the problem! The system's manifold (the plastic base you put the filter in) has small black conical shape button. When you tight the filter in, one of the two small triangle-shaped cams (located close to the filter's central hole) pushes the manifold's button, and this opens the water flow. The problem is that the cams are too low and do not push the button all the way in. Take a pliers and squeeze (not too much!) the cams, so they will raise a little: it will be enough to push the button to open the flow completely.
Mar 11, 2009 | General Electric GE SmartWater Household...
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
219 people viewed this question
Top General Electric Water Heaters Experts
paulcarew
Donni Steen
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
