Question about Fujitsu LifeBook A3040 Notebook
Wont completley load up just ends up to a blackscreen
I turn on my Fujitsu lifebook a3040 series and it loads till its about to show windows xp loading but it doesnt just light behind a blackscreen
  • Fujitsu Master
  • 32,281 Answers
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Apr 22, 2009
Hp nx8220 starts but will not load windows xp
Hi there, if you have the recovery disc try that first. However, I had to deal with a similar problem on a FUJITSU LIFEBOOK, and after trying many possible solutions it turned out to be - hard disk failure, sorry. Hope this is not the case for you.
Jan 22, 2013 | HP Compaq nx8220 Notebook
Lifebook A6230 sticky keys
This tells you how to turn on/off (if you use the mouse version then uncheck the StickyKeys check box) hope this helps:
http://windows.microsoft.com/is-IS/windows-xp/help/using-stickykeys
Oct 20, 2012 | Fujitsu LifeBook A3040 Notebook
I have windows xp,sp3 on a Siemens Fujitsu Lifebook T4010D. First of all, the tablet and the pen didn't work after installing the OS, also with all drivers installed. A few days ago, when xp was...
All of these drivers must be loaded;
LifeBook T4010D Driver Name Version Size (bytes) Audio V 6.14.1.3916 1,926,959 ACPI Device Driver V.1.21 9,437ACPI_Ext Device Driver (For model with Integrated Bluetooth) V.1.0 8,365 Bluetooth Device Driver (For model with Integrated Bluetooth) V.3.01.03F 15,615,696 Chipset V.4.30.1006 2,374,963 Fujitsu HotKey Utility V.2.30 1,119,189 Fujitsu Button Driver V.1.1.0126.2004 273,237 Fujitsu Button Utility V.1.0.0825.2004 976,478 Intellisonic V.2.0.1 4,077,455 LAN V.7.84.0.0 154,167 Modem V.2.1.41 883,675 MultiMedia Bay V.1.0.7.4 4,964,535 Radio Control (For model with Integrated Bluetooth) V.1.0 853,561 Smart Card Slot V.2.7.3.2 3,110,839 Security Panel Application V.1.2 3,653,534 TouchPad Mouse V.5.4.402.9 1,928,173 Touch Panel Driver V.1.03 22,505 TPM (For Model with Integrated Trusted Platform Module) V.1.7 17,542,125 Video V.6.14.10.3741 7,234,518 Wireless LAN Atheros (For 802.11a/b/g) V.3.1.2.21 3,980,525 Wireless LAN Atheros (For 802.11b) V.3.1.2.13
Jun 13, 2017 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Will not go further than the windows xp logo
you have problem with your window if u have recovry disk then run that or reinstall your wildows
Apr 14, 2010 | Fujitsu Computers & Internet
Where can I get fujitsu c2230 sound drivers?
For Fujitsu C2230 Notebook PC's with either Windows 2000, or Windows XP, right here on Fujitsu Support,
http://support.fujitsupc.com/CS/Portal/supportsearch.do
Whoops FAILED! Tried to give you a direct link to the Drivers page.
(Have you ever seen those vid's of Failed? Like the skateboarder who went down the pipe railing, and wound up straddling it?
Ummm, ..err,...Never mind!)
Let's go the long way instead.
http://support.fujitsupc.com/CS/Portal/supporthome.do
On this page go to the right hand column, and under the white - Mobile Support - heading, left-click on - Driver Downloads
On this page you will see three headings at the top.
Select Product
Select Series
Select Model
Under Select Product click on - Notebook
Now under the Select Series heading, scroll the side bar down, and click on - C Series
Finally under the Select Model heading, click on - C2230
Click on Go, to the right of the arrow in the red square.
You will see the - Windows 2000 Compatible Drivers - heading, and
Windows XP Compatible Drivers - heading.
Go to the operating system you are using.
Left-click on Audio
Click on Accept on the next page.
In the small window that comes up on the top right, left-click on -
Save File.
If you do Not have your downloads, set to save to your My Documents folder, this file will go to your Desktop screen.
(My Documents for Windows XP. Documents for Vista.
Windows XP? Click on Start>My Documents)
The name of the file is C2230_AUDIO_REALTEK_V5.10.00.3696_2KXP.EXE
When you see the file name, Double-click on it.
The Installation Wizard will come up.
Follow the easy instructions.
(Basically just click on Next, Next, and Finish.
If you are asked to restart your computer, do so.
If you are not asked to restart, close all windows until you are back to your desktop screen. Restart your computer.
Start>Turn Off Computer>Restart)
The above, is stated that you are using your Fujitsu Lifebook C2230, to download the Audio, (Sound) driver.
If you are using another computer to download this Audio driver, download it to the computer, then right-click on the Audio file name, and burn it to CD disk.
Take the CD disk, and install it in the Fujitsu Lifebook C2230 optical drive, with the laptop on, and Windows loaded.
If your Fujitsu Lifebook C2230 has Windows XP, left-click on Start, then My Computer.
Double-click on the optical drive that the CD is in.
Follow the easy instructions of the Installation Wizard.
If you have problems, or further questions about this, post it in a comment.
Dec 24, 2009 | Fujitsu AMILO D-7820 Notebook
How I can down load audio driver for N3010?
Follow this link to the driver downloads page at Fujitsu. Choose Notebook PC > N series >N3010 and all of the drivers will be available to download.
http://support.fujitsupc.com/CS/Portal/support.do?srch=DOWNLOADS
Oct 18, 2009 | Fujitsu Siemens LifeBook N3010 Notebook
Adding memory to Fujitsu LIfebook Series A3040
You remove the access cover which is where the power button is right under the screen by sliding it to the left until it comes off.Then you push the keyboard up to the back of the laptop until it will lift up exposing another cover. You remove the second cover and that is where the ram is located.Ram is under the keyboard.
Oct 09, 2009 | Fujitsu Siemens LIFEBOOK A3040 PC Notebook
Restarts before windows loads up.
hey hey chill...simple my friend just have your windows service pack with you inhand.Turn your Laptop on immidiately when your CD-ROM/DVD-ROM starts flashing its light, open it then insert your service pack disc (its the CD/DVD you receive when purchacing the laptop) then let it restart again...then again when it starts press F8 repeatedly until you enter a some menu then re-install the Windows Xp again from the disc and walla your Pc will be fresh again...
Feb 24, 2008 | Fujitsu Siemens Lifebook T4010 Tablet PC
Fujitsu LifeBook A3040 Notebook Logo
252 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
