Question about Bernina Artista 180
Bernina 180 Artista sewing machine
Keep getting a
check upper thread message;
have re-threaded several times;
changed needles
cleaned hook area;
turned machine off and on
no luck
  • Anonymous Mar 17, 2014
    bernina artista 180 replace upper thread sensor
You may have to replace the upper thread sensor
Posted on May 22, 2009
Threading for twin needle how to thread artista 180 bernina
Hi you should have a plastic piece in your tool kit that holds the second spool of thread. It clips on behind the existing thread stand
then thread as normal with one thread on each side of the top tensions now continue to thread down to the twin needle.
the resultant look will be two straight lines on top and a zig zag look on the bottom
hope that helps
wayne buss
sewaway@shaw.ca
Mar 12, 2015 | Bernina Artista 180
Why does the Please Check Upper Thread message keep coming on my 165 Artista?
Though it's not immediately obvious most threads have some wax on them that causes a build up in the tension areas. Get a piece of sturdy fabric, like light weight denim, fold it in half and run it through the thread path at the tension areas a few times. This "flossing" should clear gunk caught up in those areas.
Also when threading make sure you are doing it with the presser foot UP.
Good luck
Sep 09, 2012 | Bernina Sewing Machines
Check Lower Thread message come up repeatedly while sewing and embroidering. Thread is not broken. Why is this happening?
This is usually because there's fluff in the optical sensor that's fixed to the bobbin door, or alot of fluff in the rotary hook. Remove the bobbin case and give the hook a good brush-out with the supplied brush and also get a cotton bud and gently clean the lens on the lower thread sensor. This is a black 'box' attached to the bobbin door ... if you look carefully, you'll see a small lens and an opening next to it; make sure the lens is clean and the whole area is free of fluff. If it's still giving a lower thread breakage indication (not an upper thread breakage - this is a different sensor), it may be a faulty sensor or the sensor may have become disconnected from the main processor board. Get it checked-out by a qualified Bernina service agent.
Nov 06, 2011 | Bernina Artista 180
Thread goobs up underneath.. I have changed needles, changed thread. It still does it. Jaent
The most common reasons for this is when the take-up lever is not threaded or there is a complete loss of upper tension or the machine is threaded incorrectly. After these have checked out ok, then there may be a hook timing issue.
Thread the machine properly ensuring that the take-up lever is threaded. With the presser foot up, pull a few inches of thread through the machine, needle included. Then lower the presser foot and pull again. You should fee the thread get very tight. If not, make sure that the upper tension knob is on the red line (around 5).
Sep 01, 2011 | Bernina Artista 180
"Please check hook system" ?
clean out rotary hook area following manual instructions on how to do this, usually removing bobbin holder and bobbin, then the rotary hook area by undoing the latches each side.
Could be a thread jamming in there causing the error message.
May 26, 2011 | Bernina Artista 180
The needle on my bernina 180 artista is hitting the hook when sewing, causing the thread or the needle to break. How do I fix this
I agree with Rick, it could be several things. It's not something a person can just start loosening screws and trying to line things up, you can do more harm then good trying to fix it yourself without the proper tools, take it to a local dealer for service!
May 18, 2010 | Bernina Artista 180
Bernina artista 180 keeps warning to check top thread and it is threaded right
Refer to your manual for maintenance and clean the machine as indicated. A sensor may be blocked by lint.
If this continues, the machine will need to be serviced by an authorized Bernina repair tech.
Mar 25, 2010 | Bernina Artista 180
Broke a needle
Best scenario is that the needle hit deflected and hit the hook that the bobbin snaps on to. When needles hit hooks they can leave a mark or burr that the thread will catch on when it comes around. Take out the hook and run your fingernail over the edge from the point back. If you find a burr get some crocus paper (very, very fine sanding paper and polish the burr off.
Next would be that your machine is knocked out of timing meaning a trech will have to reset it.
Dec 09, 2008 | Bernina Artista 180
Repeated message: "Please Check the Upper Thread."
The machine stops because the sensor near the check spring(in the tension area) tells it the thread is broken or not there.. You can try to clean it out again but it's probably going to have to go in for service.
sewman7
Jun 07, 2008 | Bernina Artista 180
Sewing Machines Logo
491 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
