Question about Whirlpool LGR5636L Gas Dryer
The dryer will get hot but the drum will not go around
The dryer wll get hot but the drum will not go around
I have a estate gas dryer by whirlpool, it gets hot but the drum will not turn how and where is the belt located
Posted on Dec 18, 2009
The belt is not broken
Posted on Dec 02, 2009
  • 4 Answers
More than likely, the belt is broken. Otherwise, the drum motor is shot. (That's not very likely though).
Posted on May 24, 2009
My dryer gets hot but doest dry my clothes i lifted the top and spun the barrell around and noticed that the seal is torn could that be the cause
Sounds like a belt problem with no clothes in the dryer turn the dryer on for a minute or so open the door if the drum is spinning it not belt if drum is not spinning it's more that likely the belt that turns the drum.also need to check the exhaust hose in back of dryer it could have a blockage check lint screen also.Hope this helps.
Oct 20, 2016 | Dryers
Maytag entenalle dryer the drum stopped turning
Your belt has most likely broken and needs a replacement.
Mar 11, 2014 | Maytag Dryers
Beko DRVS 62 W Tumble Dryer Squeakig
I had a problem similar to this on my Frigidaire dryer. I found that there is a felt ring that goes around the drum inside. This acts like a washer to prevent the drum from rubbing on the housing. On mine, the felt somehow got pushed in some and the drum was squeeking as it rotated. I had to order a whole new drum and replace it since on my model it was part of the drum.
Feb 11, 2014 | Dryers
How to check and replace dryer's heating element for GE 5.8 Cu. Ft. 3-Cycle Extra-Large Capacity electric Dryer -...
unplug the machine from the wall - open the door and look in the top of the door hole - there will be 2 screws there - take them out and you will be able to lift the top off - the heating element is located behind the drum on the rear wll of the cabinet - use an Ohmmeter to test the element for continuity - if it is open - you will need to remove the front of the dryer and then the drum to replace the element - if it is continuituos the problem may be a fuse or thermostat or broken wire or an open timer
Oct 01, 2011 | Dryers
The dryer is hot to the touch inside the drum
two issues the heat thermal relay or the fan motor quit working you can go to www.appliancepros.com and look up the parts list for your model.
Apr 14, 2010 | Amana DLE330RAW Electric Dryer
Heating works but drum doesnt turn.
Try turning drum, or remove top from dryer to confirm if belt has gone. When turning drum there should be some resistance as the belt fits around the drum
Feb 18, 2010 | Whirlpool LER4634J Electric Dryer
Dryer not turning
remove top cover and then front to reveal drum and belt,to repl belt lift up drum and install belt around drum and then on mtr and idler pulley then reinstall frt and top cvrs
Jul 11, 2009 | Whirlpool Dryers
Drum does not rotate
The drum rotates due to a belt that goes around the drum and is driven by a small motor. The most likely answer is that the belt broke. This a common problem on an older dryer. It is relatively easy to replace the belt.
Feb 01, 2009 | Kenmore 62602 Electric Dryer
Hot point dryer
the drum has dropped
the drum is suspended on felt pads to seal the drum edges, nylon guides at the front, and rubber tyred thrust rollers to withstand the torque of the motor and belt at the rear.
the usual cause is the rollers have failed, common fault, easy fix, cheap too
good rollers look like this
1ac2db2.jpg worn rollers like this
try not to run the dryer till the rollers are replaced, the extra strain will break the belt,
  • unplug dryer(220v is Not Fun)
  • remove lint screen
  • undo screws inside lint screen holder, screwing it to case lid (so lid can tilt up)
  • with putty knife or other blunt blade, release spring catches under front corners of case lid
  • raise case lid
  • remove screws 1/3 way down front corners of body holding front panel on
  • remove door switch cable from door switch
  • lift door off set aside
  1. drum motor felts and bearings are now accessible.
  2. pull tensioner fully agains spring
  3. remove belt from motor pulley
  4. lift drum and withdraw fully forwards
  5. with drum removed check support rollers for free movement, check drum slides and/or drum felts for wear
reassemble.
  1. loop belt loosely around drum at wear marks from prior installation
  2. reinsert drum onto rollers bearings slides felts as installed.
  3. loop belt around motor pulley
  4. pull tensioner pulley against spring to end of its travel
  5. loop belt around tensioner pulley
  6. relax tensioner pulley to tighten belt
  7. rotate drum by hand to ensure belt is aligned
reassemble case in reverse order.
Jun 20, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Whirlpool LGR5636L Gas Dryer Logo
261 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
