Coffee and Espresso Makers
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Boiler heats up but water only comes out...
By allgreen141 on Apr 22, 2009
futumat manuel 2 group machine
Solution #1
posted on Apr 24, 2009
Not Rated)
EsWorld
Rank: Guru  Kitchen Appliances  Expert
Rating: 86%, 326 votes
If you remove the top panel of the espresso machine and look at the groupheads, there will be a large nut on the top, within that nut there is a microfilter and a small jet(make sure the water to the machine is turned off and the machine is cooled before removing nut).The jet might be clogged(I have actually seen sand in some models), use a paper clip or pipe cleaner to clear, then slowly turn on the water valve to flush out chamber, or use a wet/dry vac. After you have cleared jet if you still have no water flow, move to the solenoid(black electrical box connected to group, on your machine I think it is under the group you might to remove the front panel to reach it). Place a finger on the box and run the group you will feel the magnet activating, this tells you that the solenoid is working. Remove box it has a 14mm nut on the discharge, once again make sure water is turned off, using a wrench remove the silver pipe fitting that is connected to the square brass fitting(brass fitting sits on the group with 4 screws holding it in place some manufactures uest 2 screws at opposite ends). When you remove the silver part of solenoid turn on water slowly, if no water shoots out then use a paper clip to clear out the middle hole in the square brass connection.
Was this helpful?
Yes
No
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
i need the instructions for back to basics model IT400 tea maker
Answer
my odea giro is pumping well after the 3 expresso. The first few cups have the pump going, then... (More)
Answer
need an instruction manual for the 42 cup coffee urn
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coffee and Espresso Makers:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
