Question about ViewSonic VX2025wm 20.1" LCD Monitor
Can't find driver to download
I can't find driver for viewsonic vx2025wm monitor
  • iamdogman May 11, 2010
    Can u see a picture on this device right now?
    Problem Solver:
  • 5 Answers
Http://www.br.viewsonic.com/support/drivers/drivers.cfm?category=1&formName=monitor
Copy this into your http line repacing what ever is there, download and install the driver properly and that will solve it
Posted on Aug 31, 2009
    Problem Solver:
  • 5 Answers
Try http://www.yournewdriver.com/v/viewsonic_corp/ or try downloading an application called Everest, you can get a 30 Day trail period. The application will identify your device and give you a link as to where you can download the driver or choose that the application update the driver for you. Be sure to make a back up of your drivers and write them to cd to keep them for future help.
Posted on Apr 22, 2009
Viewsonic monitor manual
Yes. The base stand may be removed. The unit is VESA mount compliant with 4 holes. 100mm x 100mm.
Aug 24, 2014 | ViewSonic VX2025wm 20.1" LCD Monitor
Viewsonic VX2025wm just went dead. No power light, nothing.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC VX series monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 23, 2010 | ViewSonic VX2025wm 20.1" LCD Monitor
Resolution set too high ..no picture cant get safe mode to work up down arrow buttons wont move ..computer wants to start normal...cant get into computer with no monitor display ...help...brand new...
Sounds like you need to boot up in VGA mode instead of Safe Mode
Step 1. Power Down your computer.
Step 2. Powwer on your computer and press F8 to enter Safe Mode
Step 3. Instead of selecting Safe Mode, Select VGA mode.
Step 4. Once in Windows, uninstall your graphics card for your Monitor.
Step 5. Restart your machine, when you log back in Windows will reinstall the drivers for your monitor.
Apr 21, 2010 | ViewSonic VX2025wm 20.1" LCD Monitor
I have a ViewSonic VX2025wm who works for only 2 sec after going black when it's working with VGA. I ordered a cable for DVI to see if it works on DVI. my question: is the whole monitor damaged or just...
First I will try it on another PC using the same VGA cable. The problem will more likely to be failure in the power supply due to bad caps, or bad inverter circuits, or worst case will be bad lamps. See example of failed VIEWSONIC due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 05, 2010 | Computers & Internet
Suddenly my viewsonic vx2025wm went blank with streaks of vertical colors. All inputs. HELP!
sounds like it burned out. there is no easy way to repair this. best solution is to get a new one or if you still have under warranty, check it out. it's too costly to repair it. it's cheaper to buy one.
Oct 16, 2009 | ViewSonic VX2025wm 20.1" LCD Monitor
Need viewsonic vx2025 repair manual
only way to get one is to know/contact Viewsonic repair person. They are unlikely to just give you one.
Aug 30, 2009 | ViewSonic VX2025wm 20.1" LCD Monitor
Monitor is blinking out
Hi...there,
It's seems you got a busted backlight inverter problems...
Dec 17, 2008 | ViewSonic VX2025wm 20.1" LCD Monitor
ViewSonic vx2025wm
Check the cable for bent pins try the monitor on another computer using THAT computers cable. Then come back
Jun 01, 2007 | ViewSonic VX2025wm 20.1" LCD Monitor
ViewSonic VX2025wm 20.1" LCD Monitor Logo
1,900 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
