Question about Car Audio & Video
When i turn up the volume on my head unit my amp goes into protect mode or when i turn up the bass
  • Dean
    Dean May 11, 2010
    What amp have you got and how many subs?
    This could be a number of problems, starting with incorrect wiring, to not enought power so please state exactly what you have got :) thanks
  • Dalynn Turner May 11, 2010
    Is this at really low volume and have you tried another set of patch cables?
    Genius:
  • 1,039 Answers
You likely have a speaker with a swollen voice coil. Voice coil becomes hot due to under powered amp being clipped. Voice coils swells and rubbs. shoteing amp output causing amp to go into protect. replace speaker before amp is damaged. The more capacity an amp has wattage rating. the easier it is on speakers. Most speakers are damaged by underpowered amps being clipped rrather that too high of amp reting.
Posted on Apr 25, 2009
No sub woofer output or very little
Your sub amplifier is detecting an overdrive condition and reducing volume to prevent the output stage from burning up. When reduced volume doesn't work, output is cut completely for 10 minutes until things have cooled down.
Mar 27, 2017 | JVC KD-R740BT
So i have installed my amp, epicenter, all wiring is done, hace great ground.. But once i turn my car on to sound check everything starts fine but after turning up the volume a bit.. My amo goes into...
It sounds like you have your gain to high. best way to solve this is by turning the gain way down to - or lowest number , then turn everything on and upto the volume you desire, then slowly up the gain. also avoid using bass boost, I agree it sounds great but it puts strain on the amp and shortens life in the amp. with the bass boost off, you can adjust others (not the gain) to get bass.
Hope this helps
Jan 26, 2013 | Car Audio & Video
My ph5000d plays until i turn it up then it cuts in and plays then to protect mode back on why dose it do that its just when i turn radio up
Ok because your wattage is too high for the amp when adjusting a amp with speakers always start like this turn amp gain all the way down head unit bass all the way down and treb all the way up then turn on ur highest listening volume that u like then ajust amp to that hight if will stop protect from happening if continues ur sub is too many watts for amp ok
Dec 13, 2012 | Car Audio & Video
Alpine 9845 cde head unit car stereo i Cannot figure out how to access the Fader not the balance,altho i havent seen that function either. ive been to the alpine site and they dont even mention it. im sure...
Press the Rotary encoder (CDE-9845/CDE-9843
only) or press MODE (CDE-9841 only) repeatedly
to choose the desired mode.
Each press changes the modes as follows:
BASS → TREBLE → SUBWOOFER* → BALANCE → FADER
→ DEFEAT → VOLUME → BASS
BASS: -7 ~ +10
TREBLE: -7 ~ +7
Subwoofer : 0 ~ +15
Balance : L15 ~ R15
Fader : R15 ~ F15
Defeat : ON/OFF
Volume : 0 ~ 35
Feb 11, 2010 | Alpine CDE-9845 CD Player
I got a pyle 1800w amp and a 1500w kenwood subs but as i increase the volume in the headunit it goes on protect mode why the other problem i got is as increase the volume in the headunit the bass of the...
The protection modes in these units ****. Most new units have them. What I do is turn down settings on deck and turn up amp as much as possible. Then the protection won't turn on because you won't have to turn it up as high.
Sep 30, 2009 | Pyle PLA1200 Car Audio Amplifier
Kenwood amp kac-x401m
How long will the bass play before the amp kicks into protection mode and how loud are you listening to it? I've noticed with my amps that if they don't have enough air flow they will get hot and kick into protection mode. They will also kick into protection mode if you are running it at more than it can handle. Check your adjustments on both your amp and the head unit. Make sure you are not running more bass than the amp can handle.
Nov 04, 2008 | Kenwood KAC-9152D Car Audio Amplifier
STR-DE445 Works, but goes into protect when you turn up/down volume
This is a piece of **** unit. Mine only works on the left side, sometimes. When those times are I have NO idea. It doesn't seem to play 5.1 correctly and it goes into speaker protect mode for NO reason. It is TRUE lemon !!! ..let me know if you have any other problems with this JUNK .....schafe1001@aol.com
Aug 28, 2008 | Sony STR-DE445 Receiver
Bass sounds flat when volume is increased
probably your power is too short, increase your gauge wire, and your ground wire of the amplifier has to be shortly as possible, and the positive has to be enough to support peak power, you can also put a big capacitor on the positive wire to give some more power while the bass peak.
Apr 26, 2008 | Earthquake Sound PH-D2 Car Audio Amplifier
Amp went into protect, but front speakers sound distorted too
If the amp still goes into protect mode, the easiest thing to do is disconnect the RCA cables from the amp and see if still goes into protect mode (after turning off/on). If it does, the issue lies in the amp or the wiring to/from the amp (most likely case). Check to make sure no speaker wires came loose and touched +12V or ground (car body). From the sound of it, my guess is something internal to the amp died and will need repair.
Mar 22, 2008 | Car Audio & Video
Peavey Bass amp 115
HI Subicbay,
ADjust your Gain setting to limit just enough so the amp does not go into Protect mode. Turn your Gain all the way down, then crank up the bass from your system. GRadually turn up the gain until you trip on protect. Turn the gain back a notch and your set for no more protect.
Oct 27, 2007 | Jensen XA4150 Car Audio Amplifier
Car Audio & Video Logo
191 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
