Question about Panasonic Televison & Video
Panasonic TV TNP4G073 chassis (MX-5 or MX-5A) TV model is TC-51M80A. Lost Vertical sync while connected to the external AV inputs. They were working ? I'm in Australia and we use the PAL colour system. The TV receiver works OK still. The AV inputs are set to Auto colour systems setting. I have tried all other manual settings also, PAL, NTSC etc. The A/V sources work OK on other TV's ? Any idea what this could be ?
techman
  • 3130 Answers
SOURCE: NO CATV working on Curtis RT700
Yes if the unit is capable of picking up cable, there is a channel setup menu in the main menu. You half to switch it over to the cable mode. it should be in the owners manual. Good Luck
Posted on Jun 28, 2007
Slinteriors
  • 8617 Answers
SOURCE: Snoy model KV-21GMR1
Check the horizontal output transistor and the 12v regulator Q608 on the power supply module.
Posted on Jan 04, 2008
Slinteriors
  • 8617 Answers
SOURCE: horizontal white line
Verticle output transistor. It will be mounted to a heat sink. t should have Verticle stamped on the circuit somewhere near the Transistor. Locate the numbers on tht Tansistor and let me know what numbers and letters are, and i will post a link to where you can buy a replacement.
Posted on Jan 22, 2008
  • 3 Answers
SOURCE: Vason 10.4 inch portable tv tuning problem
I returned my original TV/DVD to the suppliers who then sent me a new one.
I experienced exactly the same tuning problem with the new TV.
The only way I could tune it, was by using the fine tune facility to find and store the missing stations. This took a lot of time and continuous button pushing, so patience is essential.
Once found and stored, the previously missing channels are perfect.
It would appear that the DVD player doesn't like DVD- recordings from my home recorder. If they are re-coded they work.
Anything recorded on DVD+ is fine.
In my opinion this is a good unit let down by a couple of niggling faults.
Posted on Mar 23, 2008
larkin71
  • 38 Answers
SOURCE: NEED HELP ON PSP CONNECTION ON TV
try to search on you tube - kr2008 for more details on how to play psp games on an interlace,non-progressive crt tv using composite or component av cable.this is now possible and thanks in no small measure to the plugin that was develped for this purpose.hope this helps.
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/_DFSfPkCd1Q"></param><embed src="http://www.youtube.com/v/_DFSfPkCd1Q" type="application/x-shockwave-flash" width="425" height="350"></embed></object>
Posted on May 05, 2008
How can I connect my PC to Panasonic viera tc-p50x1
OK, I have no idea if you want to connect a laptop or a desktop, but either way, I'll try to make as simple as possible.
I believe your tv model is not a smart tv. I own one. To connect any external device to the tv, you must set up the external device, not the tv. In this case is a PC, your PC must be equip with an HDMI output, just like a BluRay or mobile device. If it's a laptop, you need to find out which hotkey combination to use to enable the mirroring of your laptop. You can find that out by reading the owner's manual or visiting your laptop's manufacturer website.
If it's a desktop, all you need is an HDMI video or graphic card.
Then just connect the HDMI cable to any of the HDMI input in the TV. Now, with the RC, press source or input to the connected HDMI slot from the TV, in this case there are 3 of them, you must choose HDMI 1, 2 or 3.
Oct 08, 2016 | Panasonic Tc-P50x1 50inch Class Viera X1...
Panasonic tv hdmi inputs not working
It appears that during the storm there may have been an electrical surge that damaged the electronics of your tv. If the tuner is working fine then the affected area (board) is the one that has the HDMI input sources.
Aug 30, 2015 | Panasonic Viera TC-P58S1 58 in. Plasma...
Why I have a thin line across the screen in my TV model Panasonic TC 21. After replacing the vertical IC the horizontal line across the screen reduced to few inches and not as it was earlier. vertica
First, You should to replace by original part, then you should check the voltages on power supply, and check the voltage for vertical IC based on datasheet, also check the voltages on vertical section including yoke and last you should check the ESR capacitors on vertical section.
Oct 13, 2014 | Panasonic TC-21PM10RQ 21" TV
Can I hook up this receiver to a Panasonic Viera tv tc-L32C3
U need to get a digital to analog converter for the tv digital outputs on "tv mode." Connect the analog outputs to the audio input of receiver. I had same hassle with my Viera till I got another receiver that would take direct digital input - no more need for converter.
May 14, 2014 | Pioneer VSX-D458 Receiver
I just bought a Panasonic TV model TC L37E3 and I do not know how to coneect my external speakers. Please help me as I feel very frustrated by now. Carlos
Carlos, I just bought an LCD tv too. To connect external speakers to mine I had to buy some high end 5 channel pc speakers and connect them through the headphone jack(I know how stupid that sounds considering we spend $1000.00 on a TV and thats my only option for external speakers.I looked at your owners manual and didn't see a headphone jack though so you may have to opt for speakers that plug in with through the usb port. Some new tvs won't support external speakers unless you use complete home theater surround sound system which will connect through the rca cables (red,white)
May 22, 2011 | Panasonic Televison & Video
HOW TOO CONNECT AUDIO OUT?
hi,
u can connect the digital audio output (optical) to ur av receiver or any amplifier wich have a digital audio input(optica).
ok
Dec 21, 2010 | Panasonic VIERA TC-P54Z1 54 in. Plasma TV
No picture
have you connected up correctly, have you selected correct EXTERNAL inputs, you do NOT "tune" a Channel to see picture, you choose external AV input on set. Must connect color to color. 3 for Composite Video AV.Yellow, Video, Red & White Audio. and 5 cables for Component 3 for Video , & 2 for Audio Blue, Green, Red, Also Red & White, Audio.
AV
Mar 18, 2010 | Panasonic DMR-ES10 DVD Recorder
I need to connect my Panasonic DMR-E85H DVD to an old HMV TV. I need to know what the frequency of the out pout would be for the A1, A2, A3 output channels from the DVD and what the input frequencies...
It doesn't use TV channels, it uses AV, Audio Visual, input. That means you hook up, to the, whats called the EXTERNAL Inputs, A1, A2, A3, these are the external inputs that relate to the Jacks on the rear/side of the unit. You use the output from the DVD, and hook it up to the AV input on TV. Press Play on DVD and Select, correct external input on TV. Usually it;s Yellow to Yellow Red to Red and White to White.
Mar 02, 2010 | Panasonic DMR-E85H DVD Recorder
Is this tv model number HD-compatible?
that tv has 3-inputs digital comb filter
component video input
tv,vcr,and dvd
and also a S video input which can be connected to hp for video transfer.
yes it is compatible.
Apr 07, 2009 | JVC AV-36D303 36" TV
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
524 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
