Question about Kodak EasyShare C613 Digital Camera
Need to find out how to replace the battery cover
Need to find out how to replace the battery cover it came off and i need a new cover to replace it. where would i look and how much is it?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
About $9. Choose your color: http://uscamera.com/c613.htm
Posted on Jun 14, 2010
How to change the battery
Remove the battery box compartment cover. Disconnect the positive and negative battery leads. Undo the battery holding down clamp screws and remove the battery clamp, now you can lift out the battery.
Place the new battery in the battery box and secure the battery hold down clamp. Connect the battery leads to the battery, the red lead to the battery's positive terminal and the black negative lead to the battery'e negative terminal, then replace the battery box cover.
Mar 16, 2012 | 2002 Suzuki LS 650 Savage
How do i replace the battery in the garmin streetpilot c330
Follow these steps : 1. Determine that you do have a Garmin GPS with a replaceable battery. Find the information by checking the manual or with a close inspection of the back and sides of the GPS unit. GPS units that have a battery that can be replaced by the owner will have a battery cover lock on the back or side; it looks like a small sliding piece of plastic with slots or ridges.
2 Open and remove the battery cover by sliding the battery cover lock and pulling off the battery cover. In some models, you may have to hold the lock up while simultaneously pulling the battery cover off.
3 Remove the battery by sliding the battery out of the battery cavity. You may need to use gentle pressure to get it to slide out.
4 Put the new battery in by sliding it into the battery compartment. Line up the metal contacts on the battery with the metal contacts in the battery compartment to make sure it is properly installed.
5 Click the battery cover back into place. The battery cover lock should automatically lock and secure the cover. If this does not happen automatically, slide the lock back to the locked position.
May 16, 2011 | GPS
I have a Norelco 8865xl. It needs new batteries. How do I replace them?
You will find the correct battery type for model 7865XL at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this yourself, you can have shaveroutlet.com do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Nov 29, 2010 | Norelco Health & Beauty
I have a TI-82 how do you replace the battery.
Push down the tab and lift off the battery cover on the back of the calculator.
To replace the four AAA batteries, simply pull them out and put in new ones, following the polarity indicators. To replace the backup battery, unscrew the cover, pull out the battery, put in the new one, and replace the cover.
Jul 17, 2010 | Texas Instruments Office Equipment &...
MY CALCULATOR IS NOT WORKING ANYMORE BUT IF I PUT IT THROUGH TH LIGHT IT WORKS,,BUT I CANT DO IT ANYMORE,PLS HELP OR MAYBE ILL GO BUY NEW ONE..LOL
Hi:
if puttin it to the light makes it work than what you got is some dead batteries you need to replace . Check the back cover and see what batteries your calculator need to be replace it with; than go to the watch repair dept in walmart or meijers buy two batteries and have them take off the back cover and remove the old batteries and replace them with new put your back cover on and your calculator will work as good as new.
Oct 07, 2009 | Office Equipment & Supplies
98 olds intrigue needs new battery. How do you
The red plastic cover should just pop off, then you will see the head of the terminal bolt. you'll need to remove the braket holding the battery in place, just remember to replace it to hold the new battery still.
Sep 26, 2009 | 1998 Oldsmobile Intrigue
How do I remove the battery door from my ixus 75? I need to replace it as it slides open and powers off the camera - the tiny catch near the hinge point has snapped off somehow. I can get a new door from...
hi..
1. Turn your device off and remove the battery cover and battery
2. Remove the end-cover by pushing the cover away
3. Pull the bumper tabs up to separate the bumper from the device and remove bumpers
4. Snap new bumpers firmly into place
5. Re-attach the end-cover, re-insert the battery and re-attach battery cover..
thank u
rate me!!!
Jul 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Replacing a battery cover
Hi!
I have the same problem with my camera. Mind telling me where you got a new battery cover? :-) I need one!
Maybe you have already found out how to replace the cover, but anyhow, here´s what I think:
I have looked closely at the cover and it seems like you should be able to just loosen the only screw on the inside of the cover and then you should be able to just slide the cover off and replace it with your new one. :-)
Hope this helps! :-)
Nov 07, 2008 | Canon PowerShot S70 Digital Camera
Sony Ericsson Fascias
u just replace battery cover thats easy and safe.
Jun 02, 2008 | Sony Ericsson Walkman® W880i Cellular...
Kodak EasyShare C613 Digital Camera Logo
83 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
