Question about Kitchen Ranges
Door became locked by accident and I don't know how to unlock
How do I unlock my frigidaire self cleaning oven door? It became locked by accident
  • 113 Answers
Hold in the lock button and try to unlock it
Posted on Apr 23, 2009
I accidently locked the oven door and I can't get it unlocked. What do I do?
Disconnect power for a few minutes then retry.If this doesnt work put it into self clean again start then after a few seconds hit cancel. Give it a few minutes and the door should unlock.
Apr 02, 2010 | Frigidaire FEF336BC Electric Kitchen Range
When cleaning the stove i touched my accident the
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 25, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
The lock on self cleaning oven door will not release
Once the cleaning button on the oven is pressed it take 15 minutes for the uven door to unlock.
Jul 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
Cannot unlock oven frigidaire electrolux gallery series
Hello, what to do is to start another self clean cycle let the unit clean for about 3 minutes then push the cancel button.This should unlock the door if not a tech will have to come to advance the lock motor . good luck
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire self clean electric stove 'f9' message comes on when self cleaning
I had the same problem. All I had to do was clean around the door lock. A small bit of burnt food or something had gotten into the hole around the lock and prevented it from moving all the way into position. Took a tooth pick and 30 seconds of probing to clean it out. Works fine now.
Oct 13, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Self-cleaning gas oven
Door lock motor has probably failed.....Self clean on many
ovens can be a self destruct mode. Door latch motors, sensor
probes and even the electronic controls can be destroyed by
this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
Jun 02, 2008 | Frigidaire Ovens
Frigidaire Electric oven model # GLEB27S7C
If you unplug the range and remove the lower rear cover on your left side you should see the motor with 2 switch's on it. There are 3 possibilitys with it. One of the switch's on the assembly is not working or the light switch for the door is not good. You also can disconect the lead to the motor and connect a power cord to it and that will unlock the door so you can check the dor switch also. if you do not feel comfortable powering up the lock motor then you should call a repair man. But one of the switches is not letting the computer know the dor is locked.
Jul 24, 2007 | Frigidaire GLEB27S7A Electric Single Oven
Kitchen Ranges Logo
419 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
