Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Konica Minolta Logo Won't Clear from Screen
When powering up the Konica Logo does not clear and as such this renders the machine unusable. I have tried the troubleshoot reset by holding the utility/counter button to reset and cycle power, but this does not solve the problem. Any Ideas would be appreciated.
  • 167 Answers
It sounds like you will need to have a service Tech stop by, it may be a firmware issue, or if you have a Fiery the controller. A Technician can do a diagnostic to find where the error is occuring
Posted on Jan 08, 2008
2 Suggested Answers
SOURCE:
  • 8 Answers
SOURCE: Screen won't Clear Konica Minolta Logo
Check the contrast in control panel may be it is out of focus, brightness or darkness.
Posted on Feb 02, 2008
How to clear on shown display in konica minolta maintenance call m2 call service
Konica minolta bizhub 215 showing maintenance call(m2) and service callProcedure1. Press the COUNTER. (UTILITY)2. Press the following keys in this order:STOP 0 0 STOP 0 13. Enter the code number corresponding to the function to be used from theKEYPAD.4. Press the START.< Exiting the Mode>
• Press the AUTO RESET until the initial screen reappears.
Utility-stop-0-0-stop-0-1 for service mode. choose clear data, then supply countthen ok to clear. On/ Off the machine it will work as usual.
Sep 05, 2018 | Konica Minolta Office Equipment & Supplies
Konica minolta 282 c2557 code appears after developer was replaced and counters were cleared and f8 was run
After clearing the counters did you touch "END" and then power off the machine. Check your counters again if they did not clear get new developer and drum and start over
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 21, 2016 | Konica Minolta Office Equipment & Supplies
Why is my screen frozen on my Konica Minolta Printer? and it won't print.
The model number would help. Is it stuck on the Konica Minolta logo screen? Have you tried turning the main power off and on? Even unplugging the machine from the wall outlet while it is off?
If its getting stuck on the KM logo then it could possibly need firmware reinstalled or you could have a bad NVRAM board. Either way, a trained technician will have to do it. The board is only available from a dealership.
Nov 13, 2014 | Konica Minolta Office Equipment & Supplies
I have a bloblem with my konica 7055 copier machine. I tried to clear a switch of finisher FS 106 so i took a conector when my copier machine konica 7055 was on. After that my machine don't recognize the...
Never change connectors with power on, might need new control board for the finisher and or the copier.
What do yo mean CLEAR a SWITCH???????
May 15, 2014 | Konica Minolta Office Equipment & Supplies
Konica minolta 521 bizhub
Sir/Mam, To clear this code power on the machine then locate a small cover on the right hand side of the machine located above the door you open to remove papaer jams when you reome this small cover it is also where you plug your network cable into the machine remove the cover loczte a small black button press it with a small pen or penciel. The mache will go in to abort code normal when the KM logo shows up you will see a small dot on the left hand side of the screen when you see that dot press 3 that allow (Trouble reset press OK) machine will go thru same process do not touch 3 when you see the dot. If the code comes back you machine needs a new fuing unit.
Apr 05, 2014 | Minolta Office Equipment & Supplies
HOW CAN I REST SERVICE CODE ON A KONICA MINOITA BIZ HUB C652
Reset the machine. If the code doesn't clear then you either have a fuser code which may or may not be an issue. It has to be set differently. Turn machine off. Hold utility. turn machine on while holding utility. It will bring you to trouble reset screen. Click button on screen and reset the machine. If code comes back, you have a broken part of some sorts. Whats error code?
Jan 23, 2014 | Konica Minolta bizhub Office Equipment &...
Konica Bizhub 200 touch screen doesn't get past the Konica logo screen.
power off the machine and take toner bottle out. Then turn the machine without the toner bottle. let it run it should ask for the toner bottle to be replaced. Please wait is the machine is conducting house chores prior to READY TO COPY. one is to ensure toner in the developer unit is properly mixed. Also might check. Power on the machine while depressing the utiltiy/counter button hold down until you see trouble reset touch ok power off then wait 10 seconds and power on. if neither works get a tech out to look at iti
Mar 30, 2017 | Konica Minolta bizhub 200 Printer
HOW DO I CLEAR ERROR CODE C3B04
Sir/Mam,
Turn off the main power switch located inside front door. Then holding down the utility/counter button turn the main power switch on. Close front door you must keep the utility button down also make sure that the sub power switch is on. This is the switch on the side of the control panel. The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit High Current Device for the fusing unit. Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!!
Feb 02, 2013 | Konica Minolta KONICA BR BIZHUB C451...
How to clear error code c 3421 on konica bizhub c353
While holding down the utility/counter button and turning on the machine go to screen that say trouble reset press it says OK that power off and turn on again if comes back need a fusing unit.
Mar 13, 2012 | Konica Minolta Konica Bizhub C353 Drum...
Konica minolta 1690mf process error belt clear by cover
KONICA MINOLTA 1690MF ERROR:
process error - belt (clear by cover)
SOLUTION: Open and close the scanner unit. Reseat the Image Unit and cycle the power to the machine. If the error persists and the machine is covered by warranty, a printer exchange is recommended.
KONICA MINOLTA SUPPORT PAGE:
https://kb.mykonicaminolta.com/selfservice_bus_anon/microsites/search.do?cmd=displayKC&docType=kc&externalId=TAD-doctad227704html0&sliceId=&docTypeID=DT_TAD_1_1&dialogID=10562139&stateId=1%200%2010556672
Feb 27, 2012 | Konica Minolta magicolor 1690MF All-In-One...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
220 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
