Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Water hooked up but not comming out of door
Just hooked up frigidare frs23r4aw8 side by side. conected water line and no ice or water on the door?
    Problem Solver:
  • 19 Answers
It may take awhile for ice to make. do you hear the water going through the fridge when you put the button for the water to come out into your glass?
Posted on Apr 22, 2009
I just bought a used kenmore elite side by side refrigerator and hooked up the water line to the back of the fridge. My question is where does the long water line the goes to the fridge and comes back...
Where you hook the house water line is to the water inlet valve which is a one in two out solonoid controlled valve. One side goes to the water dispenser in the door and the other hooks to the ice maker connection.
So I suspect the long water line you are talking about has had the lines switched at the valve and needs reversed. The long line probably goes up the back of the unit and connects to the ice maker. The one for the water dispenser should hook to the water chiller resevoir and then to the water dispenser.
Sep 14, 2011 | Kenmore Side by Side Refrigerator
Power to the ice maker/water dispenser seemed to have shut off. Ice maker is still making ice, but the dispenser is not working. Is there a fuse or something?
frigidare 36' side by side. makes ice, nothing comes out of the door dispenser, auger truns. prior to this it would only give crushed ice even if set on cubes
Dec 06, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ge s/s icemake floods water
Icemaker generally has only about a 6 second fill time. Most likely a particle made it past the screen in the fill valve and would not allow the internal diaphram in the valve to seal. You can't get to the internal parts of the valve. Replace the valve. Consider an in-line filter installation before the refrig hook up to prevent this from repeating.
Jun 14, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
Frigidare did get water out or make ice
Since both functions are not performing, check your water supply, a clogged filter, a bent supply line, a supply line that is turned off. Internally it could be that every thing is frozen up or your water valve is bad. Joe
Apr 17, 2010 | Refrigerators
Water dispenser does not work, ice maker does work. This is a used Whirlpool side by side. I hooked up the water yesterday and the water dispenser worked. Overnight, something went awry and I do not get...
Icemaker is in line with the water and runs from the icemaker threw the door and up to the water valve. So that is why the ice maker is working and the water is not working, most likely the water has frozen inside, And this can be caused by many different reasons, if it has been humid or the door was left open then shut it would cause the moisture in the air to be drawn to the warm water and flash frosted the pipe, try to see if you can defrost the line with a hair dryer. If that does not work post here and I will tell you the next step to try.
Aug 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water from the icemaker shoots down the back of the freezer
are you sure the water comming from the icemaker or the defrost drain line clogged
Apr 07, 2009 | Refrigerators
Ice maker not making ice
We do not use our ice maker. But all of the sudden water is leaking from it. Can you tell me how to fix this? Calling a plumber wil cost a fortune.
Mar 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice Maker connection
Yes , the hose runs from the valve in the rear where the water line hooks up then under the unit to the lower corner of the freezer door up into the door to the water and ice in the door. you must have the hose together at the freezer door conection if it has been taken apart. This will fix your problem , let me know how it works.
Phil
Mar 06, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire is freezing everything
Make sure the light is going off when the door is in the closed position. Find the switch that the door makes contact with when it closes. If the light is not going out the heat from the light being on could cause such a problem.
Aug 25, 2008 | Refrigerators
HOOK UP OF ICE MAKER TO THE WATER LINE
The ice maker is not making any ice, or water or crush ice. The wheel that crushes the ice will not spin. Please help
Apr 22, 2008 | Refrigerators
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
119 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
