Question about Alpine Car Audio & Video
Subwoofers work with radio and not cd player
My amp and sub work good with the radio but when i turn the cd player on the amp turns off
  • 15,935 Answers
You have mistakenly used the power antenna remote wire for the amplifier remote wire. When the FM/AM source is de-selected, the signal drops from that wire so the power antenna will go down.
Switch the 2 blue wires and you will be problem free.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 22, 2009
I hooked up my 2 dvc 12in subs to 1100 w interfire ib2900c 2ohm stable amp..however after hooked up subs make very loud bababababa sound when turned on ..what don i do to fix this?
It's in your rca lines or you are missing or don't have good enough ground to your amplifier or CD player. To check this simply unplug your RCA's at the radio it's your radio. If it dosent it's in your rcas
Oct 22, 2015 | Car Audio & Video
SUBS NOT WORKING WITH THE CD OR aUX
Since the subs work with the radio, then there is nothing wrong with the speakers themselves. The issue must lie with your radio or control unit.
Jan 20, 2014 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
I put an after market cd player in my 2003 acura 3.2 tl type s. all the speakers are working fine but i am not getting any sound out of the factory subwoofer, it is not working. any idead what i did wrong...
You got to connect the blue amp turn on wire. If still dont work. then you got to find the factory amp find the two wires that sends frequency signals to the amp. You will see a total of 7 wires. So you've got to use process of elimination. Use a multimeter.
1.Constant 12 Volt
2. Ground
3. Amp turn on
4. + output wires going to the + of the subwoofer
5. - output wires going to the - of the subwoofer
6 + input wires going to the radio harness
7 + input wires going to the radio harness
6 & 7 are like the rca's you plug in at the input of an aftermarket amplifier and and on the other end plug in the output subwoofer of the Radio.
So on a factory amp you wont see any RCA's its all wires. Once you find the first 5 just remember the last 2 wires.
If you want your radio to control the gain and volume of the Subwoofer get a long RCA plug it on the back of your radio that says sub output and then cut the other end of that RCA and connect the positive the + input wire on the amp and the negative to the negative input wire on the amp.
If you dont know whats positive or negative just go ahead and connect it and experiment. You will know if your in phase when the subs sound boomy. Then the connections are correct. If it sounds Tinney then the connection is out of phase. solder then tape all connections with black electrical tape. Dont leave any power wires exposed or else cause a short and blow fuses.
Good luck
Apr 07, 2010 | Car Audio & Video
The woofer wont turn off
The only wires that should be going to the subs are the Speaker wire, The power, goes to the amp, Blue the remote wire should only go to the remote spot on the amp wich is usually labeled rem. and the ground all goes to the amp.
Nov 19, 2009 | Vibe CBR10 Car Subwoofer
Jensen uv8 sub works with radio an dvd but not with cd
quiero instalar mi dvd car radio y violar el codigo de parqueo se que hay opciones para poder estar el vehiculo rodando y poder verse el dvd gracias
May 19, 2009 | Jensen VM9510 Car DVD Player
Troubleshooting in car cd player
that is very strange but it could be that when you put the cd in the radio it maybe sending out a quick shot of amplified power I would try disconecting the subs put in a cd let it play a little then plug the subs in while the cd is playing and see if they work if this works you may to get a new radio or put in a switch to turn the subs off or some type of momentary circuit breaker I'm just trying to help I never saw anything like that before good luck........
Nov 06, 2008 | Sony Xplod CD Player w/MP3 Playback...
My amp only powers the subwoofer when the radio is on but wont when the cd player is on
The person(s) who hooked up your system made a boo boo. They wired your remote turn on lead to the power antenna lead instead of the amp turn on line (both are blue and easy to mix up). Thus when your radio is on it sends a signal to the amp and the amp turns on, but when you set to CD the signal goes away and your amp shuts down. Easy fix, just re-wire the amp turn on lead and the problem will be fixed.
Jun 24, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Subwoofers not working While listening to CD
The remote turn on lead for the subwoofer amplifier has been connected to the power antenna lead (solid blue) of the radio. It just needs to be connected to the radios amplifier turn on lead (blue with white stripe).
Jun 14, 2008 | Kenwood DNX7100 Car Video Player
No Subwoofer output
the connections to the amp seem to be all wrong .check the wiring again.Does your deck have a seperate sub woofer output ?If it does , just connect one sub, i repeat, just one sub,and see the output.
OR
check the GAIN control on the amp.it should be 2/3rds of the max volume of the cd player.check it is not zero!
AND
Set the amp to the L.P.F. position.
bye .happy listening.
May 26, 2008 | Alpine CDE-7856 CD Player
Kenwood receiver/sub problem
The amp's remote turn-on wire is probably connected to the blue wire coming from the back of the stereo - this is intended for a power antenna, which is why it only works when listening to the radio. Disconnect it from the blue wire and connect it to the blue/white wire coming from the back of the receiver and you should be good to go.
Sep 21, 2007 | Kenwood KSC-WD250 Car Subwoofer
Car Audio & Video Logo
183 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
