Question about Akai LCT2785TA 27 in. LCD Television
RCA input suddenly changed to black and white.
My RCA input suddenly changed to black and white. It is also grainy. the component input looks fine. what happened? how do I fix it?
Mine is doing the same thing. I have a 2 year old RCA 27" and I was told to do a "hard reset" I am trying it right now. All you have to do is unplug the power cord to the TV for 4 hours. See if that will help.
Posted on Sep 26, 2007
N64 colors do not work when hooked up to Vizio TV.
You probably have the RCAs in the component video hookups. Its easy to confuse them as they are similar ports. They are usually red, blue, and green. Look for the yellow, white, and red hookups. Those are for RCA connections as they don't work in the component hookups for HD video. i.e. blue-ray, PS3 That will cause the video to look grey and grainy.
Sep 14, 2012 | Nintendo 64 Console
My xbox 360 is showing in black an white regardless of the wire i use
Most likely it is your tv that is showing in black and white. Teste the inputs on the tv and try changing the xbox to a different input setting...e.g. coax, rca, component, etc. Please rate this solution for me.
Jan 22, 2011 | Microsoft Xbox 360 Console
Have satelite as AV1, Wii as AV2 - hooked DVD player up as component 1 using RCA plugs but it is only black and white and very grainy.
Connect the yellow RCA jack, which is actually called composite video, not component, to the DVD. If it's component, it's the wrong jack and you'll need the additional 4 cables to satisfy a component connection for HDTV.
Dec 23, 2010 | LG 32LG30 32 in. LCD HDTV
No colour
Hi, Definitely a TV issue for me. Changed Wii to another input on TV and resolved situation. Need now to check how to get my TV to recognize colour on AV2 & 3 because I prefer to keep DVD input as AV1!
I had to use the (RCA) video inputs and not the component inputs. These are the ones made for video games. If you want to use the component input (Component cables are Red,White Red, Green, Blue). If you don't have any, you should be able to purchase them at your local electronics store like Radio Shack or Best Buy. Hope this helps, read below:
TV (This is your cable connection or TV; coax)
Component 1 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
Component 2 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
HDMI 1 (HDMI Cable)
HDMI 2 (HDMI Cable)
Video 1 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Video 2 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Sample of Component Cables:
Oct 07, 2010 | Nintendo Wii Console
JVC 32" D series TV is suddenly black and white
Wow that's interesting, was there anybody watching your home while you were gone? There is a possibility that someone simply turned down the color level with the color control? Check that first. It's an unusual symptom. With composite video, component video or HDMI it's not usually possible to experience that defect. Since the color (chrominance signal) is usually inseparable from the luminance (black and white signal) I would check the color setting first. Other wise your set has become unable to detect that color signal... I bet it's a setting rather than a defect.
Happy Viewing
Jun 28, 2010 | JVC AV-32260 32" TV
Sharp Aquos LC-37D44U only shows B&W images from DVD & VHS source
First thing- why not just use the HDMI instead of standard def cables in the first place? Anyway- If the RCA-video (yellow composite cable) is not producing color, 1 of 2 things may be wrong: 1. You accidentally connected the a/v cables [yellow white and red] to [red green and blue] component inputs or vice versa, or.. 2. Your TV or DVD player is somehow set to the wrong video format. Check the DVD settings for video output format and video connector type. Format should be NTSC, and connector should be composite and/or s-video for the cables you're using.
If this is only happening when connecting the DVD player through the VCR, then check to make sure the same cables connecting the DVD player to the the VCR are also connected to the TV from the VCR.
BTW- if this is just to record DVDs to a VCR, I'll tell you it's not worth it. If your DVD player has an HDMI port, your picture quality will be so much better than if you're watching a VCR copy of one. Your new HDTV will look worse than an old standard def TV. Worse; I'm not kidding.
I hope some of this helps.
Jun 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
the yellow rca input jack( not the output one ) is for video in (by itself ) and the red and white rca jack inputs are for the right and left audio that is also required when using the yellow video jack
the red and white audio jacks are also required when using the component video inputs ( BLUE , GREEN & RED ) rca jacks
but only one type of connection is required ( yellow video jack , red and white audio jacks ) or ( the blue , green and red component video jacks and the red and white audio jacks )
you will need the yellow video input and the red and white audio inputs
Jan 05, 2009 | RCA F20632SE 20" TV
DVD plays in black and white
Which type of cable are you using to connect the DVD to the TV?
Composite video - yellow RCA?
Component video - red / green / blue RCA?
This problem could occur if you are using composite video and have it plugged into one of the component video inputs.
Alternatively it could be that you are trying to play a PAL (European DVD) source into the NTSC input.
Mar 16, 2008 | Philips Magnavox 42MF521D/37 Television
Wii gone black and white, no colour
I bought a wii a few days ago and like everybody else mine too was in black and white with a grainy picture. I have a Panasonic lcd flat screen and thought I had connected it corrected, I got somebody out to have a look at it and found out there are some connections on the side of the TV which I hadn't even noticed before, once I put the red white and yellow leads in these and set the TV to AV3 everything is in perfect colour. Hope this works for some of you.
Dec 11, 2007 | Nintendo Wii Console
Picture is in black and white
If you are using the component video inputs, check your component video connections. You may have the Pb and Pr connections reversed or not plugged in at all. All three (Y,Pb, and Pr) are needed for it to work right. Also make sure that you have the component cables from the home theatre going to the component inputs on the TV. You can get the manual at the link below if you need it.
Hope this helps, and please rate my advice, good OR bad.
Good luck!!
Dec 03, 2007 | RCA RTD120 System
Akai LCT2785TA 27 in. LCD Television Logo
128 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
