Question about Linksys BEFSX41 Router (DHBEFSX41)
Router/playstation 3 okay...I have connected the modem to the router, computer works, but when we connect the Playstation 3 to the router, it will not connect to the internet. I am not sure if this is a router issue or a Playstation issue. Any help with this will be appreciated.
    Scholar:
  • 61 Answers
I reckon that you may need to configure your router to open ports to allow the internet traffic access. If you go to this link it will help you to configure the necessay "Port Forwarding" settings. http://portforward.com/english/routers/port_triggering/Linksys/BEFSX41/BEFSX41index.htm Are you connecting with a wired or wireless setup? Hope this helps - let me know if it does not
Posted on Sep 23, 2007
SOURCE:
Can not connect wirelessly to the internet
Can you connect with a wired connection?
Are you using a third party modem/router or the official modem/router from your Internet Service Provider?
Are there multiple devices using a 2.4ghz or 5ghz frequency in your home/apartment?
How far away from the wireless modem is your Playstation 3?
Add more Details
Dec 24, 2013 | Sony Playstation 3 (PS3) Console
I've changed my modem, I have a 100% connection with my PS3 to the router, IP address and Internet Connection is successful. Playstation Network = FAILED ... how can I fix this???
you can try doing a factory reset on your modem/router also try to hard wire it and see if that gets the PSN to pass, you might even have to set your PS3 up as a DMZ host in your modem/router configuration this will put your PS3 outside the Firewall which can sometimes fix the problem. You can also ty this:
On your router settings, open TCP port 80, port 443, port 5223 and UDP port 3478, port 3479, port 3658.
Disable the media server connection option found under the Network Settings menu option on the Playstation 3.
Feb 19, 2011 | Sony Playstation 3 (PS3) Console
I need to connect my play station 3 to the internet wirelessly
Your RCA DCM425 modem is just that, a modem. you need to buy and plug a wireless router into it. That will broadcast your internet connection for your playstation to find.
Sep 29, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Cant get online when i run a test it fails on playstation net work then afterwards says you have been disconnected from media server
If you are using a router, the problem probably has to do with the router. In order to find out, disconnect your PS3 from the router and plug it directly into you modem. If your modem is not near your playstation 3 then move it close to the PS3. The modem plugs directly into your cable line so there is a good chance that the television you play your PS3 on has a cable connection. One you have connected your PS3 to your modem, press the reset button on the modem. Turn your PS3 on and go directly to your network settings. Click on Internet Connection Test (do not bother trying to set up a connection manually) If you are getting a connection then you are ready to go.
Thank you!
May 18, 2010 | Sony Playstation 3 (PS3) Console
Connecting router to PC and Playstaion 3
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 26, 2009 | Linksys WRT610N IEEE 802.3/3u IEEE...
How do you connect to internet via Ethernet cord, do you go to computer tower or directly to router modem?
The best thing to do is connect it directly to router modem. If it is too far away then computer tower.
Here you have the instructions on how to set this up:
Dsl Modem and router
Cable Modem and router
You can find all this info here:
PSN
Hope it helped.
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
Connect router to playstation 3
You need to first plug the DSL modem into the router. log on to the router. Configure the router byusing the user name and password as supplied by your dsl provider. once the router connects to your dsl provider, you should be able to connect your playstation to the wireless network.
Jun 02, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Playstation 3 networking problem with belkin n1 router
To REDUCE NAT ON PS3 /Xbox
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the PS3/Xbox
Step 7: Get the IP Address of the PS3/Xbox
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the PS3/Xbox in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Jan 05, 2009 | Belkin (F5D8231-4) Wireless Router...
Okay,i manually setup an internet connection on my PSP but for some reason when i try to get on the internet with it it says:Communication with the server failed. A DNS error has occured (8041040F). I dont...
From what I understand you are trying to get online with your playstation and to do so you want to share the internet connection with your computer but two things you mention make me believe the problem might be one of these two solutions.
First in order to start an online gaming session, at least on Xbox live, you need your own DNS which is a Domain Name Service and unique address associated with your gaming device. Since your computer already is using that unique address which you put in manually it comes back as an error. You don’t mention if you have a router or not but I will assume you do, if this is the case you need to set up your playstation to have the network setup complete automatically which will enable your router to supply the playstation with another address which will be unique to it thus no error when trying to connect to a gaming session. If this fails on the automatic setting you will need to reboot the modem that connects your computer to the internet and then reboot your router with both the computer and the Playstation connected to your router at the same time, the modem will then supply the router with a new DNS and then the router will supply both the computer and the Playstation with a new DNS and its own unique address. Once the router has rebooted get online with your computer to check to see if your router completed its tasks. I f you can get online with your computer then now go back into the Playstation setup and make sure all of the network parameters are set for automatic such as DNS, no proxy, ect.. This should get you online unless you also have a firewall problem.
If you do not have a router, only a modem from your internet company, then you will need to disconnect your computer from the modem, no sharing, connect your playstation directly to the modem, then reboot the modem. All network settings still need to be in the automatic mode in Playstation to work properly. If that still does not work that would suggest your IP gives you a static address and you will need to call them to get your network logon info and then with that info in hand set the playstation up manually with that info.
Aug 27, 2008 | Video Game Consoles & Games
Can't connect ps3 internet
Try entering the WAP code or whatever security you have correctly. If it still refuses to work try plugging in your brain by sticking your index finger and middle finger in the socket.
Jan 01, 2008 | Sony Playstation 3 (PS3) Console
Linksys BEFSX41 Router (DHBEFSX41) Logo
100 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
