Question about Car Audio & Video
I can hear voice out of my subs but they want through out bass
My kicker sub woffers have voice but no bass
  • 323 Answers
Check to make sure your amplifier is set to LOW PASS FILTER, not HIGH PASS. Make sure your settings on your head unit are set for full range, meaning 0 balance/fader.
Posted on Apr 22, 2009
What is the best way to wire two kicker comp r 12' s to a two channel amp for max bass?
First, you need to know whether you have the 2 ohm DVC subs or 4 ohm DVC subs. Second, you need to know the minimum impedance the amp can handle (most are 2 ohm, some are less). Putting two voice coils in parallel will cut the total impedance in half (e.g. 2x 4 ohm voice coils in parallel = 2 ohms total). Putting subs in parallel will also cut the impedance in half.
At one end of the spectrum, you could put the 2 ohms DVCs in parallel, then parallel the two subs, and bridge the 2 channels of the amp. That would put 0.5 ohms impedance on the 1 bridge amp channel. If the amp can do 0.5 ohms x 1ch, do it. Otherwise, you may have to run the subs on separate channels.
Oct 23, 2015 | Kicker Car Audio & Video
I just bought a cvr kicker 10' sub, hooked it up in my car replaceing a polk audio sub. The kicker keeps blowing my fuse. i have checked the wireing. i have an 800watt sony xplode amp. Please help
i am assuming that you bought this sub used? their could be a problem with your voice coil. the voice coil moves the cone of the speaker in and out. the problem with the voice coil is that it has become lose and is doping the impedance of the sub. A lose voice coil can be cause by over powering the sub. this problem is not fix able.
Aug 01, 2011 | Kicker 01C8VR4 Car Subwoofer
What does sub sonic mean on my Kicker kx1200.1 amp? Do it need to be off or on?
Subsonic refers to frequencies too low for the human ear to hear. Generally humans can hear frequencies in the range of 20 to 20000 hertz (cycles per second), but we hear best in the range of 1000 to 4000 hertz. High amplitude subsonic frequencies can cause damage to your speakers so many amplifiers have an electronic filter in them to reduce the amplitude of these very low frequency signals.
May 21, 2009 | Kicker KX1200.1 Car Audio Amplifier
I plugged int he rca's but he the lowest sounding bass possibe
kicker subs arnt ment to hit the lowest bass, unless you go spend a **** load of money, im talking 3000 wat amp, ant some 15' or bigger subs. the most commen kickers are 12' subs, so im asuming you have 12' subs, if not, this (said lightly) should work. try turning the bass boost screw on the amp to the middle of its turning range. this will offer the greatest balance between high and low bass. if you want more low bass, turn it past half. if you want more high bass, turn it down. i have mine set to mid range, but i also recently purchased 2 18' kickers. with every new set of subs, you should spend at least 15 min tuning the amp to get the best performance. every sub is different. hope this helps, good luck.
Jun 27, 2008 | Kicker KX800.2 Car Audio Amplifier
12" kicker solo baric L7
WHAT DOES DRAGGING MEAN?
I USE TO BE AN CAR AUDIO INSTALLER ,WHATS YOUR QUESTION?I NEED MAKES AND MODELS AND HOW ITS SETUP AND WITH WHAT..IF THE WOFFER IS MAKING A STUDERING SOUND WHEN A VOICWEE IS BE PLAYED ITS BECAUSE YPUR NOT SENDING LOW FREQ> SOIUND TO SUB ONLY,.
Jan 25, 2008 | Kicker Solo-Baric L7 12'' Car Speaker
Kicker solo l7 12" 2004 model
common problem of this subs are in the litles cables that goes to the voice coil. few times brock....check those. another .....if you heard the music too hihg with many bass..and your amp ..i think is big block... may be you blow off!!!!!!!!! the voice coil and the little wires...im calling trencillas...are the aquiles talon of this L7 and a manny others kickers. check the ¨TRENCILLAS¨ FIRST.
Feb 16, 2007 | Kicker Solo-Baric L7 04S12L74 Car...
Car Audio & Video Logo
63 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
