Question about Quantaray 500mm/1000mm Preset Telephoto Lens
Auto focusing problem
My Nikon D40 will not auto focus with the quantaray lens...when I bought the lens...they assured me it would be compatible with the d-40...where did I go wrong?
  • Anonymous Dec 28, 2007
    purchased a 420-800mm lense plus T adapter (manual only) on fitting T adapter to lense and then onto camera body the results were
    a/ monitor indicated Lense not attached.
    b/ could focus lense but would not take picture.
    c/ difficult to remove T adapter from camera body.
    The camera is a Nikon d40x the other lenses which have motors are ok.
    Was informed that it is normal to indicate not attached due to no electrical contact in lense and does not prevent it operating.
On a Nikon D40, set the control knob on top to M for manual. The lens will work just fine. This is for a manual focus only. I use a D40 with a Phoenix 500/1000 mm manual focus with great results.
Posted on Mar 04, 2008
    Champion:
    Scholar:
  • 216 Answers
The D40 is like all Canon EOS bodies.
Autofocus motor is in the lens, not in the camera.
You can look if it has a pin at around 5 O'Clock from the front of the camera body. Looks like a small screwdriver's tip.
[email protected]
Posted on Jan 22, 2008
Technically it is compatible... just you have no autofocus. You can still use it as a manual focus but I can't imagine it being much fun over that sort of range. I'm getting a 70-300 macro af lens that is manual focus only for my d40, but for macro i prefer to manual focus.
In the end their definition of campatible was different to yours.
Posted on Dec 13, 2007
  • 37 Answers
Your camera is only compatable with AFS-type lenses because it has no screw-drive motor.  You can only use AFS Nikkors and Sigma HSM lenses (the lens actually has a motor inside).  You were misinformed.  Bring the lens back and ask for a refund. Take that money and purchase a compatable lens somewhere else.
Posted on Oct 23, 2007
SOURCE:
I have a quantaray 70-300mm f4-5.6 lense for nikon mount mounted on a nikon D-40 and wish to use auto focus but cant seem to set it to it. Any help would be nice.
The D40 body can only autofocus if the lens is equipped with it's own in-built autofocus motor. If you have an AF lens which relies on the camera body having the AF drive motor then you have to use MF only. To cut cost and weight, the D40 relies on using lenses with their own AF motors.
Quantaray is a Ritz badge-engineered product, usually based on a Sigma/Tamron design but not always identical to those brands internally. As Ritz don't have a UK/European presence they're unfamiliar to me, but if it's the same as the one shown on this website, then it definitely lacks a drive motor, the second photo down when enlarged clearly shows the mechanically operated AF coupling at the six o'clock position. Again, to cut cost, the lens shown does not have a built in AF drive motor.
If so, your only fix is to either upgrade your body or lens to versions which aren't cut price models, or to simply focus the good old fashioned way, knowing that what you've focused on is what you want and not what the camera thinks you want... ;-)
Mar 03, 2011 | Quantaray Cameras
I have just recived a quantaray 70-300mm f4-5.6 lense for nikon mount, and have mounted it on my Nikon d-40. I can take nice pictures using manual focus but, can not seem to turn it to auto focus. Any...
As far as I can tell, this lens does not have the focusing motor and thus will not autofocus on the D40.
The macro functions should work fine, though of course you'll have to focus manually.
How to use auto fouse
The D40 does not have a focus motor, instead relying on a motor in the lens. This lens does not have such a focus motor, and thus will not autofocus with the D40.
Dec 25, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Best Auto focus Tele For Nikon D40
hi ! iam too a D40 holder,u can opt for AF-s versions or HSM sigma,both of them autofocus on d40,can go for 18-200 AFs VR or if u need still longer end go for 70-300 but it is costly than the sigms 70-300APO DG HSM MACRO..,its a much better reviewed lens and dont forget the cost..anyway do some research before considering..good luck
Mar 14, 2009 | Sigma f/NIKON- 28-90/3.5-5.6 Aspherical...
Quantaray lense
Yes, the Quantaray Autofocus lens will focus automatically on the D80.
Sep 27, 2008 | Quantaray 135-400mm f/4.5-5.6 for Nikon AF
Nikon D40 help?!
I assume the lens had the impact. The 18-55 lens has the built-in motors for auto-focus.
Try switching to manual focus (on the lens). If this works, the lens may not auto-focus anymore.
Try it and let me know.
cheers,
Sep 01, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D80 Autofocus problem
sir, replace ur lens image reading sensor
Apr 06, 2008 | Nikon D50 Digital Camera
The D40 will only autofocus with the Nikkor AF-S lens...look for the AF-S in the lens title. For 3rd party lens, only SIGMA with the USM title will autofocus.
To use the T-adaptor...you will need to use the "Manual" mode of the camera.
Dec 28, 2007 | Cameras
New Vivitar 100-300 f?5.6-6.7
If your lens is like the one here:
http://www.slrgear.com/reviews/showproduct.php/product/329/cat/49
It should auto focus on your D40
Dec 25, 2007 | Vivitar 100-300mm /5.6-6.7 for Nikon
Quantaray 500mm/1000mm Preset Telephoto Lens Logo
263 people viewed this question
Top Quantaray Cameras Experts
Doberman
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
