How do I hook up a VCR to a small Sanyo TV? Thank you
  • KarenRB53 Apr 22, 2009
    Sorry, I'm so technically challenged....to clarify...I take the cable wire that was hooked up to TV and connect that to the output on back of VCR? Then do I connect cable back to TV? I'm really not as dumb as I must sound! Thanks for your patience.
    President:
  • 2,992 Answers
How you hook up the VCR depends on the connections available on the VCR and the TV.
The simplest method is to use a cable from the VCR's RF (antenna) output connector to the TV's antenna input connector and tune the TV to the VCR output channel (3 or 4). You might need to purchase an adapter to switch from the standard plug on the cable to whatever kind of external antenna connector is on the TV. If the set only has a built-in antenna and no external connection at all (which would be quite unusual), you need a "balun" transformer. This has a connector on one end for the cable from the VCR and a flat wire with two terminals on the other end. Attach one of the terminals to the set's antenna with a clip-on jumper wire. Radio Shack sells the parts.
If your VCR does not have RF output but just audio and video jacks, connect those to the TV's a/v inputs if it has them. Again, an adapter cable might be required.
If the TV doesn't have a/v input available, you need an RF converter. This takes the a/v signals from the VCR and produces a channel 3 or 4 output that you can connect to the TV as described above.
It sounds more complicated than it actually is. Once you look at the VCR and TV, and remember that outputs always go to inputs, it's usually pretty clear what needs to be done. If you still have troubles please post a follow-up comment and I'll try to help more.
Posted on Apr 22, 2009
How can I hook up my sanyo VWM-800 to an old tv with out av plug ins thank you.
Well think about it it needs a signal in ,so the antenna is the signal in which is usually coax or older screw jacks
Feb 18, 2011 | Sanyo VWM-800 VHS VCR
Codes
Hi, Take a look at this link, I hope it helps you, if not let me know.
http://www.remotecodelist.com/remotes/
Regards - Anthony
Feb 08, 2010 | Emerson Televison & Video
Why won't older Sanyo VCR playback VHS tape on new HD-LCD TV?
The problem is not with your TV. I have had this problem as well and the older the VCR gets the harder it is for it to turn the tape. Does your VCR react the same way with other tapes? Try Fastforwarding the tape about halfway and then test it again.
Jan 06, 2010 | Sanyo Televison & Video
My sanyo vcr model vwm 690 won t run auto setup when connected to
the sanyo 690 is the best vcr out I have had mine for 10-12 yrs!
just make sure you are in the vcr mode and not tv or cable mode it will do everthing for you!!!!!! columbo
Mar 22, 2009 | Sanyo Televison & Video
Hook up instructions
has this problem been solved yet? hookup is easy
Nov 08, 2008 | Sanyo VWM-800 VHS VCR
How to Hook Up Sanyo DVW 5000
TRY A DIFFERENT TYPE OF VIDEO OUTPUTS LIKE S-VIDEO, OR COXIAL
Jul 21, 2008 | Sanyo DVW-5000 DVD Player/VCR
Dvd/tv hook up
plug in dvd player direct to tv yello red white for sound into a input ok vidieo one ect then change input on tv to that input ch2 hit ch down to go into inputs
Feb 10, 2008 | Sanyo DS31590 31" TV
Sanyo TV
I too just bought an RCA remote for the same television. The button to access other video screens is the A/B button on mine (next to the last channel button).
Jan 08, 2008 | Televison & Video
Sanyo TV
If I understand your posting/description right, you have:
1, a Sanyo TV with only 1 video input;
2. you have a DVD player with only video output; and
3. you have a VCR (which I will assume to be with both video input and output).
Your query, if I may clarify, is how to hook them up so that you need not connect/disconnect any video cable when you want to switch video source from either DVD or VCR.
If that is what you want, then connect:
a. audio/video OUT of your DVD to audio/video IN of the VCR;
b. audio/video OUT of your VCR to audio/video IN of the TV.
The above described connection would allow you to:
i. watch DVD movies on your TV (your VCR must be powered ON and set to Video INput, your TV must be powered ON & set to Video INput);
ii. watch tape movies from your VCR without disconnecting/connecting cables.
Additionally, this arrangement would allow you to record DVD movies in your VCR. Further, connecting your cable/aerial to the RF INput of your VCR would allow you to do the same with a TV/Cable program.
Incidentally, if one of your units (TV, VCR, DVD) would only have a single audio input, it is still possible since some models uses the white audio RCA connector as either left or mono, the red is right. You can also use a 2 female RCA to 1 RCA male adapter as shown below to joint the red/white audio.
Hope this be of some idea/help. Pls post back how things turned out or should you require additional information.
Good luck and kind regards.
Nov 19, 2007 | Sanyo DS32224 TV
How Do I hook up my Sanyo DVW -7000 To my Dishnetwork Box to record?
Connect the "Out to TV"video and audio on the DVR box to the "Video in and Audio In" on the VCR ...unless it's a single screw type connector on the DVR then hook THAT to the "In from ANT/cable" on the VCR
Sep 08, 2007 | Sanyo DVW-7000 DVD Player/VCR
Open Questions:
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
Electro Med Services...
