I'm a new plumber. I was asked to restart a burnham gas fired steam boiler in a fire damaged apartment. The boiler was drained last winter along with the radiators but was not winerized. I am their plumber but I don't know how to clean, test or restart the boiler to see if it works. Please help.
  • 854 Answers
1. You need to fill the entire system with water before you fire it, boiler AND radiators... Then, you would normally vent as much of the trapped air in the system as you could... It's not like you are only going to fill just the boiler and then pump that water through the pipes.
There is a temp setting on the boiler, but I don't think that's a solution. Remember that the water in the system is going to begin circulating as soon as you start the boiler. So, it will start circulating when it's cold, and then gradually warm up.
Your problem is not the sudden rush of hot water, it's going to be filling the system in the first place, and getting the boiler started before the system freezes up ...
I don't really have any suggestions for you though, other than perhaps renting one of those construction heaters ... and bring the building temp up a bit. But there's certain dangers associated with them too... Carbon Monoxide for one, fire is another (if used improperly).
Just thought of something: Fill the system with glycol based anti-freeze solution that's designed for heating systems. That oughta do it...
I'm guessing there's not a functioning water heater either at this point, is there ? If there was, you could possibly rig something up to fill the system with lukewarm water, and fire it before it freezes up.
2. You don't have a lot of choice. You have to fill the system, fire the boiler & wait.
It is going to take a long time to get the system up to temperature. Instant circulation is a double edged sword. The upside is you get a little bit of heat into the water & have it moving making freezing less likely. The downside is, it's hard on the boiler with that much cold water coming back you are likely to have condensation.
Posted on Apr 22, 2009
Boiler,heating and water all working OK but manual override to turn heat on before preset time caused dripping under boiler.Cause and solution?
Did the boiler winter over with the heat turned off and no winterization? If so, then the boiler may have frozen and cracked. Replace it.
If it WAS drained down and winterized, and you just filled it with cold water before firing it, it may be condensation.
May 05, 2017 | Water Water Heaters
Why does my alpine boiler beep
Did you ever find out? Because ours is now beeping and there are NO answers online that we can find.
Jun 19, 2014 | Burnham Alpine Gas Condensing Boiler Wall...
Boiler on hot water radiator system wont work
This is both a complex and dangerous system. There are many factors which can cause this. I will need more information. I will ask some basic questions... Was the thermostat changed out with the a/c unit or does it have a separate one? Did the gas valve get shut off? Did the breaker get shut off? Is the water on? They have low water lockouts. 99% of the time, it is where work was done. Did they hook up the stat correctly and establish the proper type of heat on the stat? Is the circulation pump on? Is the flame control board reset tripped? Leave feedback and we can go from there.
Nov 13, 2013 | Water Heaters
Hi, I am a caretaker in a 12 suite apartment block. The building has an old gas-fired hydronic Weil McLean boiler (maybe 10-20 years old). The gas pilot switch was regularly flipping (about 2 times at...
IS ANYONE CHECKING GAS PRESSURES? A BLOWING PILOT COULD BE UNSTABLE AND LIFTING OFF.IF IT IS WIND RELATED TRY A PIECE OF TIN FOR A "WIND SHIELD" AROUND THE PILOT
Jan 05, 2011 | Heating & Cooling
I have a 5 -7 yr old burnham gas burner for steam heat. I am frequently needing to put more water than normal and notice the pipes bang now also,what do you think could be wrong? thank you
When was the last time the unit was drained and flushed? Also the feeder may be stuck closed if it has one. Check all the steam vents to make sure thay are letting steam out of them. If not, replace the ones that are not. The banging is thermal shock (Steam hitting cooler water in the pipes). For some reason all the water may not be draining back to boiler.
Jan 15, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Burnham Boiler, no constant ignition.
Is there a pressure switch you can jump to see if it is defective? Is the inducer fan blowing out exhaust? You could also have a dirty pilot.
Dec 01, 2009 | Heating & Cooling
Heating & Cooling Logo
153 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
