Which flyback should I get and from where?
I've got the same problem as a number of other folks with the GE/Thomson/RCA D52GW12 projection tv: the flyback burnt out (and yes, we're lucky the house didn't burn down). My question is: what is the best replacement part - who makes it, what's the model number - and where can I get one? Ditto for the horizontal whatzamajigger that tends to need to be replaced at the same time. Thanks!
  • 8,617 Answers
You will need the 259296 Flyback and the Horizontal output (HOT) is a 2SC5588 You can get both parts at the following link and they provide free step by step instructions on how to do the repair. Heres the link
http://servicemanuals.vstore.ca/
Posted on Apr 22, 2009
Where can I get a Orega 10799630 40351A-1 flyback for a GE d52w12 52in rear projection tv?
www.tvrepairworld.com has the replacement 265409 flyback kit listed under the RCA repair kits category. The 265409 is the flyback your model uses it comes with detailed installation instructions also.
Oct 11, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
ON our GE D52GW12 52" AFTER TURNING TV ON IT
Try resoldering the flyback transformers connections on the board. Its very common for the flyback pins to develope cracks around the pins which can cause that issue. I would check that first with that model.
Jun 13, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
Power light blinks but will not turn on
The ge d52gw12 is a ge version of an rca itc 222. i have worked on hundreds of these at the shop and found with the ge modle 95 percent of the time it is a bad flyback transformer and a shorted horizontal output transistor. While there can be any number of things at fault. This is the first thing to check in this model. At our shop this repair averages 100 to 150 to repair. this varies depending on your location.
Mar 03, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
Need flyback for GE D52GW12
Tries Tv repair World.com,Ebay.com for the Flyback transformer.
Mar 06, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE Tv, replaced flyback... still nothing.
Have you ck 3 capacitors on deflection board cp150 2200uf 16v, if it is bad other 2 caps are 220uf 35v cp114 cp120 Your TV is really a RCA
Sep 16, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
My tv attemps to turn on sound starts but when picture starts the system turns off.GE model d52gw12
This set shares the same chassis as some of the RCA models so More than likely a problem with the Horizontal deflection or the flyback transformer. Its not really something that the average person should take on and without the proper test equipment you could do more damage than good. But thats a starting point.
Aug 13, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
I replaced the flyback and now I hear a high pitch sound as it tries to come on three times then has to be reset and does the same thing again! What now?
hi, where did u purchase the flyback and was it in an oem box with rca/ge or thomson consumer electronics written all over it ? most generic fly`s such as asti, crc, and hr diemen don`t work for **** in rca/ge tv`s, screen control is extremely fussy and must be set exactly or will do exactly what yours is doing, let us know, video-tek
Jun 05, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12 turns off shortly after being turned on.
that model is famous for bad flybacks. It uses flyback number 265409 you can get a replacement at the following link with free online tech support that will explain how to install the replacement. Here is the link.
Aug 28, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
52" GE tv problem
sounds like the flyback, That model is famous for thr flybacks burning through. If it is indeed the flyback thats a repair which is easy and you could do it yourself for under 50.00 Go to the following link leave them a email with your model number and sympton they have your flyback for less than 50.00 with free shipping and free tech support. Your model uses flyback number 265409
here is the link.
Jun 28, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Need Flyback Part Number
You need flyback number 259296 you can get a replacement at the following link for under 50.00 with free shipping
May 20, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
