Question about Texas Instruments TI-5006 II Calculator
The printed numbers are very light. How do I ink the ink pad...if there is one ?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
2 Suggested Answers
  • 23 Answers
SOURCE: Ink is very light when printing numbers. Can you
Yes, you'll need an IR40T ink roller
Posted on Mar 26, 2010
2 lights flashing
What is the flash pattern?
If the red paper light and the red ink light are blinking in an alternating pattern, then you may have a foreign object or piece of paper blocking the movement of the print head. Turn off the printer, open the printer and look for anything in the printhead path. Remove anything that doesn't belong. Some printers have a strip that the print head travels across that can sometimes come out of position. This can be repositioned by moving it up and down as well as forward and back to align in a guide on the back of the print head.
After clearing the obstruction, close the printer and turn it back on. If the error persists, then the unit needs service.
If the red paper light and the red ink light are blinking together and the green power light is off, then the printer has an internal error. Turn it off and then back on. If the error persists, the unit needs service.
One internal error could be the waste ink absorber is full. These pads are below the printhead and absorb ink during cleaning cycles. To reach them is messy and takes disassembling the printer from the top. This may include removing the print head. Pull the pads, blot the ink off them and the places where they fit in the printer. Run clean water over the pads until the water remains clear. Dry the pads (use a hair dryer to speed the process). Then reassemble the printer.
Next navigate to http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp and fill in the model and serial number of the printer (as well as the other required information). You will get a link to download a reset utility for Windows. Run this tool to solve the error. Do not run this utility until the pads are replaced or cleaned; waste ink will get everywhere inside the printer and over your documents.
I hope this helps.
Nov 19, 2010 | Epson Stylus C86 InkJet Printer
Waste ink absorber is full
Hi Good day!!!
Two absorber pads are located on the right side of the printer, under the ink cartridges. With the printer on, lift the top to expose the cartridges. They will automatically move out of the way. You can move them to the left side by hand if the printer is not on. You will probably need a flashlight to see the pads. They each sit in a rubber retainer. The pads can be removed very easily and cleaned. Take the pads out of the retainers with tweezers. They clean up nicely with warm water but you can use something like Simple Green if they are stubborn. It is best to use a spray bottle (on stream) and blast it through the pad until it is white. Sometimes just putting it under a running faucet will do the trick. If there is ink in the rubber retainer after taking the pad out, it can be cleaned up with a paper towel. Put the pads back into the retainers and you have successfully cleaned the ink absorbers. Now you may have to reset the error message so you can get back to printing. This is how to do it.
Following is the procedure to reset the waste ink counter for the Canon Pixma MP150
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 19, 2010 | Canon i850 InkJet Photo Printer
What does it mean when the power light and the printer light are blinking on an Epson c60 model?
If all the Led's/Light's are blinking/flashing on an Epson Printer, that indicates "Maintenance Request Error". The maintenance request error is actually a "Waste Ink Pad Overflow Error". Normally your remedy is to replace the Waste Ink Pads with a new ones and then reset the INTERNAL WASTE INK PAD COUNTER...The need to replace the waste ink pads is measured by the amount of ink uses, which is determined based on the number of Head Drive Pulses, accumulated in the waste ink counter. When the total quantity of ink deposited onto the waste ink pads, during cleaning and flushing, reaches the set limit, the printer generates a maintenance request error and stops printing. If you just reset the counter and don't replace the pads, then your printers old pads will eventually overflow and normally start leaking ink out the bottom of your printer.I know this information is not much help, but at least you will know what your ERROR is.
Feb 26, 2010 | Office Equipment & Supplies
Can't print with Epson stylus C67
It means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from http://www.ssclg.com/epsone.shtml and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service
manual is available from a number of sellers - just Google "Epson C44 Service Manual". You will often find them for sale very cheaply on E-Bay. If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Nov 06, 2008 | Epson Stylus C67 Photo Printer
Epson 1280
The ink jet printers have ink absorbing pads to catch and accumulate ink used to clean the printheads. The counter on MB counts number of head cleanings and printer startups (at every start up the heads are cleaned) and at preset number of cleaning alerts the operator that "printer needs maintenance" and sets the red light. You probably need a change ink absorbing pads (or wash them and dry 'em up) and then make a reset the count using printer Service Utility (can be downloaded from the web). To get to the ink absorbing pads is not easy - you need to remove the printer case - I am not familiar with 1280, but I did that on Epson 3000 & 5000 printers. In many cases the pads are actually OK , but the MB reaches the count and flags the pads.
Nov 06, 2008 | Epson Stylus Photo 1280 InkJet Printer
Printer problam
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C43 Service Manual". You will often find them
for sale very cheaply on E-Bay. Note, however, if you can find or borrow any of the C40,42,44 etc service manuals, as far as ink pad replacement goes, they are the same.
Sep 24, 2008 | Epson Stylus C43SX InkJet Printer
I have an epson photh R300. The ink and paper light blinks. i put all new ink in it and it says "printer parts at end of service life." It won't move or do anything after that all I can do is...
the printer's counter shuts the printer down after "x" number of prints, since the ink-pad is typically saturated with excess ink at that point. You won't have to take it to get serviced if you simply blot the excess ink from the ink-pads and reset ther counter. To reset the counter, download this program and install.
http://inkjetprinterhelp.us/epsonSSC.html or http://www.ssclg.com/epsone.shtml remember to blot excess ink off the ink-pad, and then follow the instructions to reset the counter. Good luck!!! JohnsGroovyWebsite.com
Aug 02, 2008 | Epson Office Equipment & Supplies
Epson C43SX communication error
It is presumed the 6 posts in this problem are all from the same person. If one (or more) isn't, and my response below doesn't help, would you you start a new separate post on your particular problem.
A solitary blinking red light means that the ink level in one of your cartridges is low, but printing can continue normally until the ink runs out, at which point the red light becomes permanently on. You must now change the ink cartridge before the print will work again.
If the green light is flashing at the same time as the red one, this means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C43 Service Manual". You will often find them for sale very cheaply on E-Bay. Note, however, if you can find or borrow any of the C40,42,44,60,62 service manuals, as far as ink pad replacement goes, they are the same.
The reference manual is at
http://support2.epson.net/manuals/english/ij/stylusc43/REF_G/INDEX.HTM
which provides good information on the meanings of the error lights.
Please report back with further information if the above advice doesn't help.
Jul 05, 2008 | Epson Stylus C43SX InkJet Printer
Canon s400 doesnt print only blinks eight times
The tank is situated on the RHS.
The Print Head rests there when not in use.
Open the flap to expose the Print Head,slide the Print head across to the left.
On the area where the Print head rests, there is a black plastic square of plastic which contains 2 narrow vertically positioned ink pads.This is also spring loaded.from underneath.
The pad on the left is for BLACK the other Color.
These become saturated with ink during the cleaning process.
I suspect the Print Head has a built in sensor to detect overloaded waste tank.
The pad can be removed this by hooking it out, sideways.
Unless the pads are leaking ink everywhere I wouldn't remove it.
Use Cotton Buds to soak up the excess ink. I used about 15.
Then.....
Turn off printer
Hold down RESUME button and press POWER button.
Keep holding down POWER button and release RESUME button.
Press RESUME button 2 times, then release BOTH buttons.
The GREEN light will flash and stop flashing.
When the GREEN light goes out, press the RESUME button 4 times.
Press the POWER button and the printer should turn OFF
If not press the POWER button once more.
My experience was when turning the printer on at a later date the POWER and RESUME lights still flashed.
All I did was press the RESUME button and the printer operated as normal.
Jan 06, 2008 | Canon S400 InkJet Printer
Texas Instruments TI-5006 II Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
