Question about Texas Instruments TI-83 Plus Calculator
Light display i turn on my calculator and its barely visible.. the batteries are pretty new. any ideas?
WHAT YOU CAN DO TO FIX THIS IS:
- TO HIT [2ND] THEN
-HIT THE DOWN ARROW
-REPEAT STEPS ONE AND TWO AND YOU WILL BE FIXED
Posted on Apr 23, 2009
Is there a way to change the contrast as two of my units have a barely readable screen as the numbers are too light to read easy
Too light numbers usually indicate weak batteries. If you're sure the batteries are new then the display is done.
Jan 01, 2016 | Office Equipment & Supplies
I get black "lines" going across the screen when i hit the graph button. It will graph also,but you can barely see the graph. Help pleae.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect first.
1. Try a new set of AAA batteries.
2. Adjust the contrast by pressing and releasing the 2nd key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
3. Remove one of the AAA batteries. Press and hold the CLEAR key. While holding CLEAR, reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the CLEAR key and then press it one more time to remove the message.
4. Remove one of the AAA batteries. Press and hold the DEL key. While holding DEL reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Jun 04, 2013 | Texas Instruments TI-83 Plus Calculator
Profit Calculator KS1000, how do I change the dead battery? Where is it?
Turn calculator over
Remove two visible Phillip screws
Gently pry up and remove rubber feet on all four corners-remove screws
Button cell battery (original: VINNIC L1131, replacements: Energizer 389/390 or Duracell D390)
Location: upper right hand corner under metal battery clip
To replace battery: gently pry up left tab and slide new battery with + side facing up (writing visible).
Gently push tab back down
Next: Look at circuit board, locate double arrows
Follow directions: "please press "RESET" after replacing battery"
I just touched the metal flow solder plate (small circle with squiggles) above the words "RESET" with a small screwdriver
TA-DA...it works
Nov 17, 2010 | Office Depot KS-1000 Calculator
The digits are barely visible, too hard to read. how do I adjust this?
Turn the calculator on. Press and release the 2ND key. Press and hold the up-arrow key to increase the contrast. Obviously, if you go too far repeat the process with the down-arrow in place of the up-arrow.
May 18, 2010 | Texas Instruments TI-84 Plus Calculator
TI-89 won't turn on, even w/ new batteries
Try a hard reset:
Press and hold the 2ND, Left, and Right keys.
Press and release the ON key.
Be aware that this will clear all RAM.
Oct 04, 2009 | Texas Instruments TI-89 Calculator
My TI-83 Plus Calculator will not turn on
This is from TI FAQS:
Solution 11900: Troubleshooting a TI Graphing Calculator That Will Not Turn On.
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
Aug 06, 2009 | Texas Instruments TI-83 Plus Calculator
Weak or non-existent illumination of viewfinder information
sending the faulty electronic camera back to seller (eBay) thank you George Birrell
Apr 18, 2009 | Contax RTS III 35mm SLR Camera
Display / LCD issue
Try adjusting the brightness setting for the LCD screen by holding down the "on" key and pressing the "+" key at the same time to make your screen darker or the "-" key at the same time to make it darker.
Jan 18, 2009 | HP 48gx Calculator
Display is so light that I can barely read it, I've replaced the batteries and no change
Have you attempted darkening the display on the calculator through the function keys? Push "2nd" and then push "up" a few times. After resetting the calculator, this setting will always revert to a lower, unreadable setting. I'm sure TI knows about this, but they probably arent too inclined to fix it.
Jun 04, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
67 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
