Question about HP OfficeJet t45 All-In-One InkJet Printer
Makes noise when loading paper
My HP T45 started making noises like gears slipping when it's loading paper for printing. Is this fixable, or terminal ???
  • junojim Apr 29, 2009
    However, I did find the solutuion to my problem. The cleaner assembly lost a cover, it was jamming the system. I pulled it the other one, and a lot of ink goo out, and it works fine.
My Carriage Return Belt is frazzled and about to break. Where and how can I get a replacement for this thin but until now strong belt? I'm quite sure I can put a new on myself.
Posted on Apr 28, 2009
HP 1315v Printer Makes grinding noise and won't feed paper anymore
It sounds as though a sheet of paper or an envelope bunched up and has jammed inside. Until that is removed from the feed roller, you will continue to hear the 'grinding' sound, and won't be able to print anything. Remove the cover from the backside of the machine, then locate and remove the obstruction. If you don't have any such obstruction then you have a mechanical defect which is not user repairable.
Oct 20, 2014 | HP PSC 1315 All-In-One InkJet Printer
My officejet 4500 is making a horrible noise when it warms up
Where was the pen stuck? All the gears in that printer are plastic and therefore are subject to shearing off or stripping.
Jan 07, 2018 | HP Officejet 4500 G510G Inkjet...
Hp cp3525 printer makes clicking noise when printing and start up
  • Make sure the paper type levers are set right in the tray. When loading paper this can get moved and the printer will think it is picking up bigger paper than is actually loaded and it will click.
  • Locate the fuser, usually just before the paper exits and it should be easily accessable from the back panel. Remove the fuser and inspect the gears, they will get chewed up and may need to be replaced. A good sign will be a lot of white dust which is bits of the gear itself.
Jan 13, 2013 | Vizio Xwr100 Dual-band Hd Wireless...
When i print, the printer makes a grinding noise the paper gets jamed also.
Remove the fuser unit and check if there is a residue on the side of the gears. If so, you 'll have to replace the swing gear assy. Partnumber 5851-2766. It is not an easy job!!!
Gerrit Jan
Oct 28, 2009 | HP 4250 Monochrome LaserJet Printer
Color Laserjet 2550 Loud Noise when starting up and printing
Remove toner cartirdge and check gears on cart as well as all of the gears you can see inside the unit for any signs of wear. You may also need to remove the fuser assembly and perform the same task with the gears back there. MAKE SURE THE POWER HAS BEEN TURNED OFF AND THE PRINTER UNPLUGGED FOR AT LEAST 30 MINUTES BEFORE ATTEMPTING TO TOUCH THE FUSER. IT WILL BE HOT!!! Most frequently these kinds of noises from the printer are due to gears slipping. Sometimes simply reseating the fuser assembly or toner cartridge will fix it. If there appears to be excessive wear on any of the gears, you will need to replace them.
May 29, 2009 | HP Color LaserJet 2550n printer + HP Color...
After starting the PC printer HP psc 1315 makes too much noise.
Hi
My name is Sydney, i am going to help you rectify your problem. Your printer needs a minor service of the rollers, you can go to your printer dealer or a local technician certified in fixing hp printers to service it for you.
At your service Sydney
Feb 10, 2009 | HP PSC 1210 All-In-One InkJet Printer
Printing
Does it feed a length of paper? if so, you may have either the wrong paper, or the paper loaded incorrectly. It needs to be thermal paper, and it will only print on one side, so if you are sure its thermal paper then try turning the paper over and loading it that way.
If it doesnt feed any paper and just makes noise then the problem is probably a broken gear inside the printer. For this you would need to find a place that can repair these terminals.
Nov 06, 2008 | VeriFone (M19755014US1) Magnetic Card...
Warm up noises
the only thing I can think of is the paper tray trying to lift up during warm up and there is a gear slipping but catches itself which is why you dont hear it again??
if you open the trays and close them does it do it??
Aug 27, 2008 | Sharp AL-1642CS Copier
I can't print
Mine makes a noise when turning it off and on and then the light just blinks. The paper does not feed at all. Nothing works! And I've never really had a problem since getting it many many years ago...
Apr 07, 2008 | Lexmark X73 All-In-One InkJet Printer
My all in one hp printer dosent load paper
Dear
This is the common problem of this printer;PROBLEM WITH SERVICE STATION GEAR(SMALL) ;IT MAY BE BROKENED ;
rGDS
jigin
Dec 07, 2007 | HP OfficeJet 5110 All-In-One InkJet...
HP OfficeJet t45 All-In-One InkJet Printer Logo
83 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
