I can not see secondary hard drives in my computer. If I click on the primary card drive " c " then properties, then hardware I can see them there. But not in the my computer icon window. therefor they are unaccessible. Whats wrong?
  • xusical Apr 22, 2009
    I thank you verry much for your help. I truly appreciate it.
    Novelist:
  • 153 Answers
Your additional drives are not partitioned in a manner that Windows can recognize. How to deal with this depends on your operating system. Assuming XP, right click my computer, select manage. Select disk management. Right click on the drive, I forget the wording for the choice you want, but what you are doing is creating a partition and formatting it. It will be pretty obvious. Then it will appear in my computer.
Posted on Apr 22, 2009
Iomega select portable external 320GB 2.5" Hard drive not being detected on the PC with windows 7
  • Hi, there are (3) three areas that you can search to find: Hard Disk Drives. 1. From the Desktop, click on the Computer Icon to open the "Hard Drives (window)," next find the Hard Disk Drive (1), this is the "Primary" (C:) Drive. 2. Next, in the Devices with Removable Storage (1)below is the "Secondary" Drive, this will be the (CD or DVD Drives (D:), for "External Drives" the drives locations will be (E: or F:). 3. "If the CD, or DVD Drive is present in this area?" Right click to open, select the Properties "icon" the window opens; in the "All disk drives" (block), select, and "highlight" the CD or DVD Drive, next click on the Propertie's button below! 4. In the Device Status (block), see: if the device is "working properly?" Next, click on the Drives button, select to "Update Drivers." Note: The computer screen may "blink' (3-5 times), this means the update has taken place, Click on the "Apply and OK buttons, to finish. "You may be ask to "Restart the computer, if not? Restart the computer." *The "Second" area is the "All Programs" in the Start Menu, scroll to find: Media Disk Player. Select to open, click on "Setup, and Install." Follow all instruction carefully! *The "Third" area is in the Control Panel from the Start Menu; find in the (right pane). Open the "Contol Panel" go to, and select Hardware and Sound, in the next window, click to open the Device Manager; scroll to find: DVD/CD-ROM drives. Click to open; do the same as above instructions, step by step. "Did this solution help? If so, Helpful Ratings Feedback is appreciated, thanks paul7of9"
  • Feb 17, 2010 | Electronics - Others
    It will come on but it says primary hard disk drive 0 found and secondary hard disk drive 1 not found
    Feb 15, 2010 | Dell OptiPlex GX110 PC Desktop
    Windows 7 won't start up when I try to install my dvd1260i . I followed the 5 step installation guide, and when I turn on the computer, it tries to run problem solver and says that there might be a...
    You should remove your new hard drive out from your computer. Check your dvd drive jumper configuration. Make sure that if you use it as secondary drive for your primary drive like hard disk or etc., the jumper configuration is set to slave.And if you use the drive as a primary master, make sure that the jumper settings is set to master. Dont join both primary drive into one data cable, it will cause a drive error or one of them will not work. After that, install back your dvd drive into your computer.
    Dec 23, 2009 | Electronics - Others
    Still needed solution of problem
    Go to Control Panel - click on System - Click on Hardware - Click on Device Manager - click on IDE ATA/ATAPI Controller.
    Then right click on Primary IDE Chanel - then click on Properties - Then Advance Settings - For the Device 0 in Transfer Mode select DMA if available. Then Click OK.
    You can also select DMA for Device 1 too
    Feb 09, 2009 | Compaq Presario Notebook
    Can't burn an audio cd on my dell inspiron 1525
    do one thing
    go to the my computer > right click on the burner drive > properties > recorder > and than chk if that the recording option is checked or not
    if not check it
    if it is alread there
    right click on my computer > properties > hardware > device manager > click on cd /dvd drive and uninstall the options there
    than click on the IDE / ATA
    and uninstall the secondary chanel first
    and uninstall the primary channel .... but be sure that you do this in the same sequence coz if u have a ATA hard drive thats normally connected to the primary channel and if u uninstall that first it will freeze the system... after that is done restart the system and issue resolved
    Dec 06, 2008 | Dell Inspiron 1501 Notebook
    Slow burning
    ok, please elaborate your situation what dvd model do u have u can check this my going to my computer right clicking on your dvd drive and then properties and going to the harware tab and it will tell u
    on away to fix this would be to go to my comp then right clik on an empty space and hit properties then the hardware tab then then device manager
    then click ont he plus sign on ide ata controlers then right click primary ide controllerss and go to properties and then go to advanced settings then look down and make sure it says DMA if available on transfers then hit ok after c cahnging it to dma
    and then go on seconadary ide channel properties advance setings and also make sure that it syas dma if available and not POI if it says POI thts a problem just change it and ur speed will improove dramatically
    another solution
    make sure that ur hard drive isnt connected to the same ribbon cable (IdDE cable) as the dvd rom
    u can check this by oening up ur pc and if they share a cable put the dvd drive as secondary master and the hard drive master
    Sep 25, 2008 | Computers & Internet
    Sony VAIO laptop; DVD-R not reading disks
    Check the status of the device in Device Manager to make sure that the device driver is working correctly. (If you need help doing that please ask.)
    If no joy then:
    Change the transfer mode for your CD drive in IDE Channel Properties loadTOCNode(2, 'resolution'); loadTOCNode(2, 'resolution'); 1. Click Start, right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. On the right side, expand IDE ATA/ATAPI controllers. 4. Right-click the channel where your CD drive is connected, and then click Properties. Typically, this channel is Secondary IDE Channel. 5. On the Advanced Settings tab, in the Transfer Mode box for the device that represents your CD drive, click PIO Only. Typically, this device is Device 0. Then, click OK. If the issue is not resolved after you change the transfer mode for the secondary IDE channel device 0, your CD drive may not be located there. Use the same procedure to change the transfer mode back to DMA if available. Then, repeat these steps to change the transfer mode for IDE devices in the following order until the issue is resolved: • Primary IDE channel, device 1 • Secondary IDE channel, device 1Note Primary IDE channel, device 0 is connected to your boot disk. This is the hard disk that typically contains your operating system.
    Jul 05, 2008 | Computers & Internet
    Help
    to know the type of hard drive your computer uses. if u r using windows os, click on start--all programs--my computer. then right click on local disk c, then click on properties u will see some info about your hard disk. or
    u click on start-all programs--right click on the my computer icon then click on properties, click on hardware at the top of the window,click on device manager then click on the + sign at beside the ide icon,u i'll see list of hard disk drive right click on the primary ide then click on properties. there u go all about yr hard disk will be displayed.
    im xerick
    May 23, 2008 | Dell Latitude D600 Notebook
    Dvd rom won't work
    You forgot to check the jumper settings of the Hard Disk and the DVD Drive found at the back near the IDE and power cables. If you are using one IDE cable, then one jumper should be a Master, that's the Harddisk, and the DVD drive a Slave. If you are using two IDE cable then both must be Master.
    You should check also the Harddisk jumper help settings printed on them, some harddisk needs the jumper settings for Slave presence on the same IDE cable.
    If it doesn't work then It's either the cable or the DVD drive has a problem.
    Oct 31, 2007 | Compaq Presario 5000 PC Desktop
    Computers & Internet Logo
    23 people viewed this question
    David Payne
    David Payne
