Question about Dishwashers
Dishwasher does not rinse clean
My maytag dishwasher is not rinsing the soap off the dishes properly. There is a white film on most of the dishes after the cycle is completed.
  • 1,889 Answers
Run the dishwasher empty: use 1/2 the amount of soap you usually use in the soap dispenser close it then put white vinegar in the open dispenser and, run the dishwasher
Posted on Apr 22, 2009
I noticed dishwashing detergent residue on my dishes and then I discovered the dishes were not being rinsed. I've discovered it will not fill in the normal or rinse modes. It only fills in the auto clean...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101';;;;;;;;;;;;
Apr 22, 2011 | Maytag MDB7100AWB Dishwasher
White residue on dishes, white smears on inside of dishwasher door. Roughness on plates when cycle is done. Have tried all dishwashers soaps. Usually Casade and a rinse worked when dishwasher was new. Have...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Jan 29, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
GE TRITON dish washer. Utensils are stained after wash. I tried all that suggested solutions like cleaning with white vinegar, make sure hot water flows before it starts. I donot think we have hard water...
heatman101
Jan 21, 2011 | Maytag Dishwasher
I have a Kitchenaid dishwasher Model KUD101lLWH6 - Serial number FR4205761. I have not changed soap or rinse product since I got the dishwasher but I am getting a white looking film throughout the...
The white film that you are talking about could be two things. First is the quality of your water, having sediments either through the water system or from the water heater because the water that goes into the dishwasher is taken from the hot water supply. Second is the build up of soap residue and even with a rinse product it is not able to remove it. A simple remedy is to due a wash and rinse cycle without dishes and put vinegar in the dishwasher about a cup full (8 oz) and see if that will help. If not I would check the water and going in and out of your water heater. Good Luck
Jan 06, 2011 | KitchenAid Dishwashers
Dishes are filmy at end of cleaning cycle. decreased amount of soap.. believe the rinse aid is not being properly dispensed...
heatman101
Dec 20, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
There is a white residue on my dishes when the cycle ends. I have switched soap brands and made sure the rinse aid container is filled. The residue is hard to remove, even with hand washing/scrubbing and...
heatman101
Aug 29, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Soap not fully rinsed from dishes, maytag quiet series 300
heatman101
Mar 12, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
My dishes come out with cloudy film on them.
From Whirlpool:
*Film is due to either etching or silica film. Silica film is a milky, rainbow-colored deposit and etching is a cloudy film. Sometimes there is a water/chemical reaction with certain types of glassware.
o Silica film and etching are permanent and cannot be removed. Both can occur in any automatic dish washing machine and result from a water/chemical reaction with certain types of glassware. They are caused by some combination of:
+Soft or softened water.
+Alkaline washing solution.
+Insufficient rinsing.
+Dishwasher overloading.
+Heat of drying.
+Long/hot cycles.
To slow the down this process:
*Use a minimum amount of detergent but not less than 1 tablespoon per load.
*Use a liquid rinse aid.
*Under load the dishwasher to allow thorough rinsing.
*Do not use heated drying.
*Wash glasses by hand.
Do the following:
1. do you use a rinse agent
2. clean out the drain.
3. if you have a food disposal, run hot water through it and turn it on to clear it out before you turn on the dishwasher. The dishwasher drains into that sink. If you notice food or dirty water backing up into you sink when the dishwasher is draining, then the sink could have a minor clog and is backing up and being re-sprayed onto your dishes.
Source(s):
Use SANIVAC to clean lime deposits and extend the life of your dishwasher. If you have heavy water.
Run your dishwasher empty and pour in a cup of bleach and a cup of white vinegar to get the residue out.....run a regular cycle.......How hot is your hot water tank set on? The hotter the water the better a dishwasher washes and rinses, be careful it's not to hot as your shower and other sinks also will get this hot water......cut your dish soap down and make sure to use a Jet Rinse Aid. Again, be sure to use a liquid soap, and rinse agent, powders will cause a caustic reaction. Hope this helps. Let me know if there is anything else I can help you with.
JimmyC
Sep 30, 2009 | Bosch Dishwashers
Dihes not clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
382 people viewed this question
Top Dishwashers Experts
