Question about Lexmark P3150 All-In-One InkJet Printer
Lexmark printer p3150
Not compatible with my new dell computer with windows vista also dont have printer startup disk
  • Shena Sep 23, 2007
    Dont work not a compatible program to download on my driver
    President:
  • 317 Answers
This is the driver download page for your printer: http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+Photo+P3150 Unfortunately they don't have a driver listed for Vista. This is pretty common, a lot of companies are slow to develop drivers to be able to use their products with Vista.
Posted on Sep 22, 2007
SOURCE:
Driver problem with dell printer aio926
To install the pprinter on Windows 7, you'll need to install the Vista drivers in the compatibility mode. Please follow the instructions located at...
926 Photo All-In-One Printer owners thread (W7)
tablette pc - netbook 10 pouces - apad 10.2
Feb 17, 2012 | Office Equipment & Supplies
Have new computer gateway with windows vista says windows connot find driveon the disk the printer is lexmark x1185
vista , till now does not have all the drivers for all the additional accessories....
for only a few devices and models in printers or cameras are available
Apr 11, 2008 | Office Equipment & Supplies
Is there any possibility of making this printer compatible with windows 7
With Windows 7, I found that installing the Vista software/drivers in the compatibility mode works well.
Right click on the setup.exe file, left click properties, left click compatibility. Change the compatibility to Vista(Try Vista SP2). Then install the proper drivers. You'll be prompted when to connect the printer(powered on).
***To install drivers, sometimes the file unzips and does nothing. You have to look for the setup.exe file, right click on it, then left click run as administrator***
As for scanning, if you have the disk that came with the printer, then insert the Printer disk and stop it from running. Go to My Computer and double click on it. Look for the drive with the Dell disk in it. Right click on it, left click explore. Look for the OCR Folder. In the OCR Folder, there is an Abbyy Folder. right click on setup.exe, that's in the Abbyy Folder and left click run as administrator. This will install the OCR program.
Scanning
Scanning using USB connection, open the Dell All-In-One Center, click on scanning and copying and scan from there.
Scanning wirelessly, use the scan buttons on the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 01, 2011 | Dell A940 All-In-One InkJet Printer
I have a Veratec desktop computer and am having all kinds of problems with it. It is one year old. Will not communicate with my dell printer A920 and is difficult to operate otherwise. Please help.
Well what operating system do you have on it? Windows7 doesnt like some printers. check online for print drivers and update them. Follow this link to help you with that... http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_FA36C542525D975EE030030ABD621881&isLegacy=true
you can also try this approach... First, let's make sure your computer has the latest Windows Updates, especially .net framework, needed to run many applications and the latest Java.
Disconnect your printer.
Download and run this patch (***WARNING*** The patch for this printer also removes other Dell applications, like Dell Dock, Dell QuickSet and other Dell applications)(These applications can be downloaded at Drivers & Downloads and can be reinstalled) to completely remove the printer from your computer. Run the patch(A MUST on Vista Machines) until it prompts you to restart your computer.
If using Windows 7 also try...Manual Printer Driver Removal
Restart your computer.
Download the proper drivers.
XP Drivers
Vista 32-bit Drivers
Vista 64-bit drivers
All other drivers
Install the proper drivers. You'll be prompted when to connect your printer(powered on)
If using Windows 7, use the Vista drivers in the compatibility mode.
Scanning
Mar 04, 2011 | Computers & Internet
Just bought a new computer and my Dell 720printer does not work? Thank you
If you bought a new computer it probably has Windows 7 installed and the Dell 720 may not be compatible. You can try downloading the Vista drivers from Dell here. They may work with Windows 7. If not, you'll need to replace the printer with a later, Windows 7 compatible one.
Jan 09, 2011 | Dell Inkjet 720 Printer
I have a Dell 944 all-in-one printer and just got a new Toshiba laptop. The new laptop uses Windows 7, which is not supported by the printer. Is there an update to the drivers & utilities to make...
Did you try the Vista drivers in the compatibility mode. Drivers and instructions can be found at...
http://en.community.dell.com/support-forums/peripherals/f/3528/t/19306932.aspx
Let me know what happens.
Dec 09, 2010 | Dell 944 All-In-One InkJet Printer
I have a Dell Photo 924 printer & my scanner always worked fine with my Windows XP. Switched to new Dell computer with Windows Vista & scanner, Dell All In One, did not show up at all. I got a...
sometimes there are compatibility issues with windows vista. Uninstall all other exisitng drivers of printers. Install the downloaded driver again and the software too. If it doesnt work then i think you must get it back with xp.
Jul 28, 2010 | Dell 922 All-In-One InkJet Printer
I am considering buying a new computer. I have a
The good news is that your Canon iP8500 printer is Windows Vista compatible. Driver page for them is here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=10440
More good news, the Epson Perfection 1650 scanner is also compatible with Windows Vista.
It would also appear that your HP Laser Jet 5mp printer is compatible with Windows Vista:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=25481&prodNameId=15013&swEnvOID=2093&swLang=8&mode=2&taskId=135&swItem=lj-44462-1
Whether or not to get a Dell or HP is a preference thing. The biggest thing you have to ask yourself is, how much are you wanting to spend on a new system? Both vendors are fairly comparable as far as hardware and support. The biggest thing I should mention is that, ensure that when you buy your system, to tell whomever you are buying it from that you need Windows Vista 32 bit. Not all of your components were compatible with Vista 64 bit.
Best of Luck and hope you have lots of fun with your new system!
Apr 24, 2009 | Microsoft Windows Vista Ultimate Edition
Compatibility between new computer and potential new printer
the x5650 is compatible with XP, Vista and Vista 64
Nov 26, 2008 | Office Equipment & Supplies
Need to download windows vista to install my hp psc 1410 all-in-one printer-scanner-copier to my new computer.
why??? If your computer is New it should have VISTA on it, or Windows XP, which is compatible with all printer scanner types. All you need to do is use the installation disk you got from the all- in -one-printer-scanner-copier and insert it into the disk drive and let it load up and follow instructions. if you do NOT have the disk--go to the website of the maker of the all-in-one and download the thing from there.
Oct 14, 2008 | HP Computers & Internet
Lexmark P3150 All-In-One InkJet Printer Logo
113 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
