Question about Dryers
Heat goes off after a min. in use. Whirlpool Model # LGR4634JQ2. Took apart back and cleaned exhaust.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 123 Answers
If it's gas it could be that the pilot is not close enough to the gas sensor and when the drier is in motion the extra air motion shuts it off.
if its elect it could be that one of the fuses are not set shut both fuses down and turn them BOTH back on
Gas clean the elect pilot and be sure it is close to the sensor that looks like a little tube
Posted on Apr 22, 2009
Dryer timer won't shut off at end of cycle. Dryer runs, but no heat. It is a Whirlpool model number LGR4634JQ2.
Since you say that the dryer runs but have no heat, plus the timer won't shut off the odds are the timer is bad. The timer would tell the burner when to be on and when to shut down.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265840&diagram_id=28265980#d28265980
21 partimage.aspx?imgid=z3bqljbfahrfndg1njc5my9mufcvc290b2hwdhjhcc8%3d
Enlarge Photo
Timer
Part Number: AP3037407 made by WHIRLPOOL $91.55 In Stock
Order now and it will ship Today
Jun 09, 2011 | Dryers
Whirlpool gas dryer blows cold air. took back panel off cleaned lint out. Took front cover off, turned dryer on gas igniter does not heat up, or glow model # lgr4634jq0
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 09, 2010 | Dryers
Whirlpool gas dryer. Only few min.( less than 5min) heat work.
there is a thermal fuse inside the dryer it is a one time fuse also there is an ignitor that could be bad
Jul 03, 2009 | Whirlpool WGD5300S Dryer
Have a Whirlpool gas dryer, model #LGR4634JQ2, that will not heat anymore and has a rattling noise every now and then. Any ideas?
The rattling noise is maybe a sort of buzzing only more metallic? Sounds like the coils on the gas valve making it flutter. Causes are the coils and/or the ignitor.
Eric
Jun 07, 2009 | Whirlpool LGR7646E Dryer
Whirlpool gas dryer runs but won't heat
hi stella. yes the problem is with the thermal fuse. when you were cleaning the vent at the left. the thermal fuse is right there, on the air duct, a small piece of plastic with 2 blue wires to it . replace the thermal fuse . thanks the appliance doc
Oct 06, 2008 | Whirlpool LGR7646E Dryer
No heat gas dryer
hi look for the thermal fuse at the back where you cleaned . its a small plastic piece with 2 small blue wires . replace this part thanks
Oct 06, 2008 | Whirlpool Dryers
Autodry cycle never stops
hi thanks for the question ther is a thermostat on the air duct at the back of the dryer it has 2 wires at ends and 2 wires in the middle smaller ones this thermostat opens to turn off heat and the small wires on this thermostat when the heats shuts off then power goes to the timer and not before if it shuts off on timed dry timer is ok i would vacuum the dryer make sure all the vent right to the outside is clean as air flow restriction can cause this problem thanks the appliance doc
Sep 15, 2008 | Dryers
NOT BLOWING WARM AIR
Most dryers have a thermal cutout, a non-resettable overheat protection, take the model and manufacturer details to your local repair store and you can buy one easily.
then its, take off the rear plate, and trace the exhaust air ducts back till you find an identical item screwed to a duct, unplug its connectors screw the new one in place, plug in the connectors.
Exact info cant be given as you did not tell what make and model the affected dryer is
May 18, 2008 | Dryers
Whirlpool dryer with no heat
Is the igniter glowing yellow? Look inside the pilot access hole and see if it lights up. If it lights up then goes off, it may be the thermal fuse. Once this blows, it has to be replaced. There are pictures all over the internet on the location of this part.
Good luck.
Apr 16, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
160 people viewed this question
Top Dryers Experts
