Question about Kenmore HE2 Plus Front Load Washer
We cant get the door opened kenmore he2 plus we got it for free and for some reason the door wontt open
    Problem Solver:
Unplug the the machine for a couple of minutes. This should unlock the door. If not, you should remove the lower panel under the door. Simply unsrews 3 hex nuts. Pull the door tab (latch) from underneath. Is there any code error displaying on your LED?
Posted on Apr 22, 2009
What could be the reason that my Kenmore HE2 Plus Front Load Washer won't start?
Hi, Could be the door switch, make sure the door is shutting completly then try to start.
Aug 15, 2014 | Kenmore HE2 Plus Front Load Washer
Kenmore he2 plus front load washer: the front rubber gasket is moldy even tho i leave the door open when not used. someone said it is because i have used downey
You can use awsome to spray on let it soa, make sure you get in th cracks ,atfer it soak for awhile use a tooth brooth an brush it. when done with wash open door an d one cup of vinger right in the middle of the tub, that should take of it.
Oct 31, 2011 | Kenmore HE2 Plus Front Load Washer
The door is locked and will not open, please advise
Hello.
The most typical reason the door will not unlock is because not all the water has drained due to the filter on the pump being clogged. This tip i wrote will help ya to open the washer and check the pump filter to see if its clogged.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Sep 21, 2011 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore washer HE2 plus and F26 is flashing
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%%%
May 14, 2010 | Kenmore HE2 Plus Front Load Washer
Our Kenmore HE2t reads F26 and stops running half way through cycle
DOOR SWITCH ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
Mar 09, 2010 | Kenmore HE2 Plus Front Load Washer
Can i reverse the door opening direction on this model? thanks
no you cant but if you have the matching dryer swap machines and reverse dryer door .hope this helps .please rate my response :)
Dec 09, 2009 | Kenmore HE2 Plus Front Load Washer
Switching the door swing opening?
only if there are capped off screw holes on other side, look for caps mirror image to other side.
Sep 02, 2009 | Kenmore HE2 Plus Front Load Washer
Change door opening on Kenmore HE2 washer and dryer
yes - there is a hinge kit to do so.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Washer is stuck on spin and the door wont open. It is locked.
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
May 16, 2009 | Kenmore HE2 Plus Front Load Washer
Front door is locked and I can't get it open
Hello shoya_garris,
There is a manual release tab you can use to open the door. Make sure you unplug it first. Remove the bottom front service panel. Carefully reach up and pull the manual release tab on the bottom of the door lock assembly until you hear it click. Wear some gloves there can be sharp edges on the inside of the machine panels. Hope this helps.
Thanks,
edgin96
May 12, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
346 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
