Question about Brother Office Equipment & Supplies
My Brother MFC-7420 printer is not working. yesterday it came up with message "printer is currently off-line", I readjusted the cords and the message disappear. But then when I try to send print, it shows that only 22% of printing is being processed (something like that). It now just have message GenericClass: waiting for device Connecting. I tried re-plug the printer's usb cord directly to the computer (usually plugged into usb extension hub). any ideas? thanks
SOURCE: Refill toner Brother MFC 7420
open front cover, press OPTION button, on the LCD will appear a message "NEW DRUM?" ....DO NOT RESPOND....just type on the keyboard "*00" and there will appear a message "Accepted" and use it in your pleasure.
PS. in any case i blocked with paper labels the viewing windows from transparent plastic on the toner itself....
Mr. Brother, do not try to be smarter than your customer
Posted on Jul 17, 2008
SOURCE: I can't find the back door sensor on Brother MFC-7420
I have the answer. I just fixed mine. The sensor is not really on the door. You have to remove the door by openning it all the way and carefully sliding it out ( one of the pegs holding the door is hourglass shaped. This will slide out first. The other is round. You will see a black flap that covers a red drum. Pull the flap down carefully. There will be a six inch long rod it's about 1/8 of an inch in diameter. It extends from the middle of the flap all the way to the right side. This probably popped out of place. Make sure that it is all the way to the right as this is where the sensor is. There is a little spring on the bar on the left side. This should be straight up and down. if it is not, then you need to fiddle with the bar.
The trick was that the sensor is NOT on the door, but on this inner flap. When the door closes it pushes this flap agains the drum and the little bar activates the sensor.
Please do not applaud so loud, you are ambarrazing me!!! hehehe. Good luck!.
Posted on Aug 11, 2008
jtuminaro
  • 56 Answers
SOURCE: BROTHER MFC 7420 PRINTER SOLID VERTICAL LINE...
Open te lid and look at the glass. You have dirt or white-out or something on the thin strip of glass to the left. Clean that glass!
Posted on Jan 15, 2009
  • 320 Answers
SOURCE: error 2001 on brother mfc 7420
please tell me more! i just checked my brother manual and i do not see a error code 2001????????????
Posted on Feb 16, 2009
the kowalski
  • 86 Answers
SOURCE: Black lines in copies and fax's Brother MFC 7420
If the black lines comes when using the ADF (top feeder), try to see if you get the same problem when using the scanner glass or receiving faxes. If you don't, you simply have to clean the glass strip to the left of the a4 sized scanner glass. Wipe it with a dry cloth piece, no paper and no water/alcohol. If you see some dirt there that you're unable to simply wipe off, try to use a cotton wool to "rub" it off.
Posted on Jun 14, 2009
I can't figure out how to hook up the fax machine on my brother 7420. i have the phone cord and am not sure how to make the fax work.
take the phone cod from the wall and plug it directly to the back of the machine where it's written LINE. And if you want to also receive phone calls, you can run a cable from the EXT. port straight to your telephone
Jun 14, 2011 | Brother MFC 7420 All-In-One Laser Printer
My Brother MFC-7420 still shows "Toner Low" as always and I cannot use the scan tool. Please help me as quickly as you can. Thanks
1) Pull out the cartridge and look on the right side of the it. You will see a small hole that has a glass like window in side (round window).
2) Turn off MFC-7420
3) Cover the hole on cartridge with a duct or a piece of paper. Basically block.
4) Replace the cartride back in the printer and turn on the printer.
5) The message should be gone and you should be able to use the copier functionality.
It worked perfectly.
What an unethical practice Brother is following? They want us to spend more money buying their cartridge unnecessarily.....
Apr 19, 2011 | Brother MFC 7420 All-In-One Laser Printer
Connect mfc 7340 to pc without phone line
The MFC-7420 connects to the computer using a USB cable.
May 10, 2010 | Brother MFC 7420 All-In-One Laser Printer
My MFC-7420 Printer wont scan
We are having problems on scanning documents with our MFC-7420 Printer to send to email?
Jun 23, 2009 | Brother MFC 7420 All-In-One Laser Printer
Have voip and brother mfc 7420. error code 2001 and 2006
Get a new phone wire. Put a phone on the line and listen for static. Too many phones on one line will cause problems. If the phone line is going thru a surge protector, check the quality of the sound with it and without it, it may be damaged. Keep power wires away from phone wires, they cause static.
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Error 2001 on brother mfc 7420
Dec 16, 2008 | Brother MFC 7420 All-In-One Laser Printer
Oct 07, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420
I need to down load driver for Brother MFC-7420
Sep 03, 2007 | Brother MFC 7420 All-In-One Laser Printer
74 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
