Shrinking picture Everything else is working fine on the tv, sound,color,inputs,etc...However the picture is starting to curve in from the sides like the shape of an hour glass. Is the tube shot? or is it something less costly?
  • luis42008 Oct 10, 2008
    se distorsiona del lado derecho unicamente
  • ddempdd Jan 13, 2009
    RCA F32632SB 32" TV Hour Glass picture.
    I have read it is in the pincushion circuit.
    Could you guide me to a fix?
    Thanks,
    Dan D
    Genius:
  • 1,694 Answers
Please provide make and model for specific info.T.
Posted on Oct 11, 2007
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Picture is starting to curve in from the sides like the shape of an hour glass. Is the tube shot? NO. is it something less costly? YES YOUR PROBLEM is in pincushion correction circuit.call skilled tech to fix it. it will not take much time. good luck.
Posted on Sep 23, 2007
SOURCE:
Sony Wega TV lost color now only B/W KDF-42A10 born 6/06
Sounds like it's something more than the lamp. Double check all your connections...it might be something as simple as needing a new cord (RGB, HDMI, Component Video, etc) Does the problem exist with all inputs? (For example, DVD player, cable, etc) If the problem is only from ONE input source, try replacing that cable. If it's on all input sources...might be something more internal on your TV.
Good luck
Jason
Oct 04, 2014 | Televison & Video
Tv works fine, but no color
try to play a DVD movies etc to see if the problem is on TV or the signal reception..
Aug 27, 2012 | Zenith Z52SZ80 TV
No picture
have you connected up correctly, have you selected correct EXTERNAL inputs, you do NOT "tune" a Channel to see picture, you choose external AV input on set. Must connect color to color. 3 for Composite Video AV.Yellow, Video, Red & White Audio. and 5 cables for Component 3 for Video , & 2 for Audio Blue, Green, Red, Also Red & White, Audio.
AV
Mar 18, 2010 | Panasonic DMR-ES10 DVD Recorder
No picture, last night color was going away, then today no picture
If your TV is shrinking and expanding you can get a repair kit from www.TvRepairKits.com for less than 50.00
Comments: May 19, 2009- If your TV is shrinking and expanding you can get a repair kit from www.TvRepairKits.com for less than 50.00 May 22, 2009- Here are the most common symptoms and example photos of this problem.
  • Video Shrinks and Expands - Over and Over - After warming up it typicaly works.
  • After a few weeks the shrinking stops and you loose all video and audio.
0667c5f.pngSOLUTION
Its a fairly easy DIY job. Check the site www.TvRepairKits.com
Their kits include a photo instruction guide, parts, email/phone support, etc.
Nov 26, 2009 | Philips Magnavox 9P6034C 60" Rear...
Toshiba 51h84 "Crooked Picture"
Still the convergece prob.The FL231 fuse near the FBT transformer it dead.The square fuses 3 rectangles fuses.One in the middle.
Aug 09, 2009 | Toshiba 51H84 51" Rear Projection...
Sony KP46WT510 picture goes back and fortto horizontal color bars
The pictures show the result of a bad terminal input board. You can verify this by checking the inputs. Connect devices to the board and try different inputs. You will most likely find this problem on the tuner and component input were your DVI and composite video will be ok. If it is the same on all inputs replace the A board
Jun 24, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Projection tv
Check the site www.TvRepairkits.com . They have a kit to fix the shrinking and expanding video problem for this model.
Mar 25, 2009 | Philips 9P5034C 50" Rear Projection...
Picuture shrinking color fading
I have the same Tv.. Repair tech said it was the deflection board. Cost $395.00 to repair.
Feb 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
No picture or sound
Put the old chip back in...does the shrinking/expanding problem return? If so the new chip may be faulty.
If the problem stays the same - no audio/video  - check your soldering, cables, etc.
Nov 02, 2008 | Televison & Video
Latest version. DVD Shrink. Nero8 (Todays downloads) On two Laptops. Didn't have this problem with PC's.. Shrink working ok. Nero 8 Burning dvd's. Lap tops read /Play fine. Home dvd players to home TV...
try not to do anything or open other program while its dvd shrinking or burning....bcoz dvd shrinking and burning occupies lot of memory cache and cpu usage.
GOOD DAY
Sep 15, 2008 | Computers & Internet
Televison & Video Logo
682 people viewed this question
Top Televison & Video Experts
Ekse
