I have a Panasonic sa-pm39d dvd system, I get the code f61, but I know it's not the speakers. It's a power supply issue, what does the audio amp switch look like? can some help me pls.
  • 4234 Answers
SOURCE: Panasonic SA-HT940
F61 is a problem with the output amplifier pac. It is the equivalent of "protect" mode. The output pac needs to be replaced. I'll look up the part number for you.
Dan
Posted on May 15, 2008
tech48
  • 624 Answers
SOURCE: POSSIBLE FAULT CODE
Yes, it is possible. The F61 error is a failure in the power supply or the amplifier. I repair these every day and it will require good soldering and troubleshooting skills to fix this yourself.
If you would like to try, let me know, and I will give you more information. But the best thing to do is take it to a service center and let a professional technician check it out for you.
Posted on Jul 01, 2008
sleepy_user
  • 140 Answers
SOURCE: I have an issue with Panasonic SA-HT545 Surround sound system
I have a similar unit about 18 months old...just wouldn't start and gave me the F61 code. I opened it up and found that the fan on the back was not running properly...the fan's circuit feeds back info to the cpu that it is running...when not it shuts the system down. I powered the fan externally with a 20v power source and ran it for a while off the red and black wires (the yellow wire must be the feedback)and re-installed it. All is working fine...but I'll go out and buy a new FAN.
Posted on Jan 29, 2009
  • 4234 Answers
SOURCE: power supply problem in a pmp 3000 behringer miker
I am not familiar with the particulars of your specific model, but with switch mode supplies in gereral, look for defective filter caps on the output side or a defective Zener Diode. If you can post a few photos of the power supply section, I may be able to guide you to the likely parts. Dan
Posted on Jun 08, 2009
VOTIT
  • 2071 Answers
SOURCE: power supply problem in Behringer pmp 3000 mixer
Just try to resolder all component parts in power supply section,maybe there is a loose connection or cold solder joints that causing of abnormal voltage or missing voltage.Also check the resistor for cange value causing the voltage trap.Check also all electrolytic capacitor for leak. Hope it may help you;;
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
Panasonic Dvd stereo system model number SA-VK960 power supply is defective. is it possible to repair?
Your Panasonic SA-VX uses a Switch Mode Power Supply ( SMPS ). Do not ever attempt to fix it yourself unless you are well versed in electronics. ou can damage the system seriously. Seek professional help.
Mar 10, 2011 | Audio Players & Recorders
My dvd stereo system panasonic model SA DK2 , F61 error,and immediately power down, comes on when turned on and then powers back off. please help
F61 usually means the amp has detected a short.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Feb 21, 2011 | Panasonic sa-ht800V Home Theater Audio...
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
My panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Feb 05, 2008 | Panasonic SC-AK33 CD Shelf System
Panasonic sa-ak25
the problem is F61 is speaker protection mode on.
fault with your audio power amp section.
i can help you.
nuwan.
Oct 09, 2007 | Sony MHC-G100 Shelf System
How do I solve Panasonic SA-HT800V error code F61?
unplugged a Panasonic HDTV plasma for four minutes, plugged back in and Now the DVD does not work.
How to reset?
Aug 28, 2007 | Panasonic sa-ht800V Home Theater Audio...
262 people viewed this question
 Grubhead
Grubhead
