Question about Cobra 29 LTD CB Radio
Cobra 29 ltd classic ant light
I done a peek and tune on my cobra 29 ltd classic and upgraded finals now the ant light comes on when I talk on it but the swr is fine. how do I fix this?
    Guru:
  • 773 Answers
Your SWR is probably NOT fine. You need to use an external meter if you have had work done to the radio. Especially if you have had a swing mod done to the radio. When you do this, the dead key of the radio is lower then the calibration knob on the radio can adjust for. It will always come up lower then it actually is.
Your radio might have been fine before the work was done on it because it was putting out very little power. Now you are most likely putting out 50 watts or more. Big jump from 4 watts.
When your raise the power in a radio, you will notice more when the antenna is not properly tuned.
In most cases with a stock CB, even when the antenna is not even near tuned, you will get a reading less then 1.5 anyway.
the more power you put out, the more important it is to have a good match.
But an external SWR meter, and check it. be careful if the ANT light is on.
You might also want to check your coax, connections to it, and your antenna for anything wrong.
Posted on Apr 24, 2009
  • Steve Tompkins
    Steve Tompkins Jul 22, 2013
    Its just that the power level is double by changing the final to C1969
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 98 Answers
Don't worry about that I had the same thing on my Cobra 29ltd classic. It does that when you are running around 40 watts power out with Swr 1.3(its just a red light that shows you are talking after you have the mod done to it. Mine would talk to Oklahoma from Kentucky on USB Ch # 39 Amazing how much it improves it to have mod & upper channels installed.
Posted on Apr 01, 2013
Ant light comes on all the time
you have high SWR on antenna .get the ant. tuned or go to a cb shop and have it tuned .i'm hoping it is on a vehicle .if its a base ant. you need to tune it.
Mar 02, 2014 | Cobra 29 LTD CB Radio
Red lights come on tx n rx and antenna come on when I key up the cb radio and the swr meter doesn't move
if a mod has been done to the cobra 29 (all 29,s)the light will come on just find vr6 audio the radio as it comes on adjust vr6 untill it goes away,,,,always trust your watt meter(s.w.r scale)over the flashing light its really easy to do it beats paying a shop $10-$15
Jan 13, 2013 | Cobra 29 LTD CB Radio
I just purchased a cobra 29 LTD Classic mobile CB radio.Pro tuned high performance Mosfet Final I have a palomar 450 LD mosfet linear.will i have any problems?
Not if the power output from radio to amp is set correct and the jumper for coax is correct length and there is absolute perfect match between them and the antenna used. Afterthought: also the amp better be connected to something big enough to power it.
Apr 29, 2012 | Cobra 29 LTD CB Radio
Problem while matching CB
You need to understand how to tune an antenna and how the antenna works.
read this article
How to tune your antenna
and here is a list of causes for high SWR
Oct 28, 2009 | Cobra 29 LTD CB Radio
Cobra 29 NW LTD Classic wont calibrate and red antenna light keeps coming on
The calibrate knob only calibrates the radios SWR meter, the owners manual will show you the procedure for that. If your ANT light is coming on, it is telling you that your SWR is to high, and may cause damage to the radio from reflected power. You should purchase an in line meter as the radios internal meter may be somewhat unreliable. You need to tune the antenna to the lowest SWR possible. Typically anything under 2.0:1 is acceptable. Radio Shack sells a meter for about $50, and is pretty accurate. Antenna mounting can also cause high reflection if it is to close to other objects. Google "CB antenna tuning" or read the instruction manual for you antenna, and you should be able to figure out how to properly tune the antenna.
Jul 07, 2009 | Cobra 25 NW LTD 40-Channels Base CB Radio
Cobra 29 ltd classic side mic
First off I dont believe anyone to peek and tune but anyways. Make sure your mike is for the radio wiring. Next the guy that rigged it up might have gave you all the channels do all your knobs work??? usually you can tall as you get someone to talk with you a few blocks away and start, start turning and flipping switches till you can hear him most likely the guy that did the work on it messed it up. for a filter use a farite choke from radioshack on the mike wire.
Mar 17, 2009 | Cobra 29 LTD CB Radio
Cobra 29 LTD Classic not transmitting or receiving
ant. light should only come on if you have a high vswr a bad thing did you check that cb/pa switch is set to cb check your swr this is not a good place to mount ant. as it is close to metal of back of cab
Dec 20, 2008 | Cobra 29 LTD CB Radio
As I understand from a tech friend of mine, most truck beds are not grounded well enough. Perhaps you could borrow/purchase a magnet mount antenna and locate it on the roof, for testing. Then you would have it narrowed down to the location.
Dec 05, 2008 | Cobra 29 LTD CB Radio
Cobra classic 29 ltd
Had fixed the same problem yesterday. My cobra worked when it wanted to, when it didn't it looked like you explained. I found out that on my cobra the blue wire on the mike connector was broken. When it disconnects, no sound. after soldering, everything works fine.
Dec 04, 2008 | Cobra 29 LTD CB Radio
I have just bought a cobra 29 ltd classic with a scanner ant and it worked befor on the turck it was on but now that iv installed it on my truck im not able to talk to other nor hear them
sounds like a mic problem if a wire is broken in the mic it will not let you receive or transmit common..or not to common an audio chip...
Aug 17, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
1,020 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
