Question about HP Pavilion dv8235nr Notebook
Xp won't load to hard Disk
I believe it is more complicated than that. I have two of these DV8235 computers. I was able to install Xp on the other computer clean as a whistle. I took that hard drive and installed it in the one that won't load Windows. I get the message of Windows config system is missing or corrupt restart windows with installation disk in place and use R to recover. when I do that and the CD Rom starts , it initally reads the disk and start loading. Sometines at F6 it stops. Sometimes at F2 it stops. Sometimes it starts loading windows and then stops. No matter what hard drive what format what installation, it will not follow all the way thru. this is the only computer I have ever had that would not load a program. I do hear two beeps at post. Even tried to rest the BIOS. It has F24 listed in the setup. Everything in set up looks good, the hard drive checks out. Just won't load windows.
  • HP Master
  • 32,281 Answers
Your RAM modules could be faulty or needs reseating. If reseating doesn't work, try swapping them around from the other laptop to see if that works.
Posted on Apr 22, 2009
I get a disk read erroroccurred after I have installed a new hard disk. How can I get my computer going again?
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 15, 2012 | HP Compaq nx6325 Notebook
HARD DRIVE NOT EXIST ERROR!!!
If you installed Linux successfully on your hard disk then the hard disk is OK.
If you are installing Windows Xp and it does not detect the hard disk but the BIOS detects the hard disk then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
May 01, 2012 | HP Computers & Internet
Can not install os, computer says no hard disk installed
This laptop has a SATA hard drive.
Feb 23, 2012 | Panasonic Toughbook CF-30 Notebook
New hard drive operating system not found
The reason why you cannot install Windows on your hard drive is this model Sony has a SATA disk controller.
Feb 17, 2012 | Sony VAIO VPCEA36FX PC Notebook
Hi i purchased a dell 1318 laptop from china suddenly i cont install xp it,s support only win7 while trying to install xp it will display the error message like this
Your laptop may have a SATA hard drive.
Nov 13, 2011 | Dell Inspiron 1318 Laptop Computer PC...
We cannot seem to load win XP on DG43NB motherboard with SATA drives. Is there a way to do so?
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Sep 08, 2011 | Intel DG43NB Motherboard
Old hard drive died so now have a western digital wd5000aakx. have pins 5&6 jumpered but cannot instal windows xp as no drive is recognised even after loading the sata drivers that camw with the...
Jun 09, 2011 | Computers & Internet
Install windows XP
You sure your HD isn't bad? You could try a low-level format and then try to install, I am assuming you don't mind loosing any data already on the disk.
Sep 09, 2009 | Computers & Internet
Set up did not find any hard disk drivers installed on computer
Your notebook has SATA hdd. Got into the bios (keep pressing F2 key on startup) then in the bios screen find HDD and press enter. Select IDE mode. Press f10 to save changes and exit. When this is done install XP.
Alternatively connect external usb floppy drive and unzip sata drivers into that. When booting from xp cd press f6 to load drivers.Follow onscreen instructions to load drivers and continue xp installation.
Please let me know if issue not solved for futher ts steps.
thanx
May 28, 2009 | Fujitsu LIFEBOOK P1510D Tablet PC
Just purchased IBM Intelistation 6221..installing windows????
hi! try this. reboot your cpu, then press the CMOS setup key (del), then select load default setting, then go to hard disk detection settings, select the LBA setup. I believe you know how to manipulate the CMOS setup configuration. if still doesn't work out, bring it to the service center near you and ask for assistance, Im sure they would love to help you. Have a nice day!
Dec 20, 2008 | IBM IntelliStation Z Pro 6221 PC Desktop
Computers & Internet Logo
50 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
