Question about Zenith C27A24T 27" TV
We are unable to get video (picture) on our TV, when we hook up to our new DVD/VCR combo. The combo doesn't have an S-video port and our TV does. We get perfect sound though.
We bought a Dvd/Vcr combo and we are unable to hook it up to our Zenith TV. The problem is that the new combo unit doesn't have a S-video or wire, and our TV does. Our previous DVD player did and it worked fine. "S-video" is the only option on the menu when switching from cable. Now we are unable to get a picture on the TV. We have perfect sound, just no video.
  • jpcogar Apr 22, 2009
    We did that & still got no picture. It's like the TV won't do video without the S-wire. We even mixed & matched wires, attaching different ones to the TV & the cable box. We attached the s-wire from the TV to the cable box, thinking that somehow, since the DVD player was also attached to the cable box, that it would operate through the box. No go.
    President:
  • 2,992 Answers
Your TV should also have a regular composite video input jack (yellow) in addition to the s-video input. Use that input instead of the s-video. The video won't be quite as clear as with s-video, but you have to work with what the combo gives you.
Posted on Apr 22, 2009
  • Apr 22, 2009
    Now I'm a little confused. A cable box may have RCA jacks for audio and video on the back, but they are outputs for a TV or recorder. I've never seen a box which takes an input, so I don't know why your old DVD would have been connected to the box.
    All the Zenith sets I've worked on offered both normal video and s-video inputs as choices when they had those connections. I'm wondering now if there's something wrong with the TV itself. It's a pain not being able to see the setup for myself.
    Have you tried unplugging the TV, letting it sit for a few minutes, then plugging it back in? This resets the computer in the TV and sometimes that can clear up funny behavior. Also check the setup menus and see if there is anything controlling normal or s-video selection.
    As a last-ditch solution, you can use an RF converter. This takes the a/v signals from the player and produces a channel 3 or 4 output signal that you can tune in on the TV. It won't give the same quality picture and sound, but it would work.
    Sorry. I guess I'm striking out on this one.
Compatability with magnavox combo dvd and vcr
the back of the vcr/dvd player will have some rca plugs that are red,yellow,white,they will be labeled out putthe yellow is video,the red and white are left and right audio,the back of your tv should have the same thing,it should say input,get a rca cable with plugs on both ends and match the plugs to the colors,if you tv or dvd player,doesnt have these,then you will need to plug your cable box into the dvd player and run a coaxial from the dvd player and tv,use channel 3 or 4 on the dvd player and 3 or 4 on the tv
May 08, 2015 | Magnavox Televison & Video
I hooked up a DVD player to my RCA Tv/ VCR Combo. I get sound, but no picture. All connections are tight. Cables are hooked up in the order they should be. I get cable from TWC. There are red yellow &...
The red and white are the audio, and the yellow is the video, check the back of the tv to make sure the yellow jack states input, if yes make sure the tv is set to aux/or video.
Dec 22, 2010 | RCA T20TF667 20 in. TV/VCR Combo
I have my Samsung model dvd V9800 hooked up to my RCA RT2906. The dvd side is showing a picture but the video side is not. The RCA RT2906 has have a hook up for a vcr player by it's self but I do not think...
VCR video signal wont come out from Component Video Out of combo unit, it is low resolution signal so you need to hook yellow-red-white video cable in tv for VCR output.
Make sure to select VCR as source in combo while playback of VHS tape and select DVD as source when playing dvd disc in combo.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Dec 04, 2010 | Samsung DVD-V9800 DVD Player/VCR
I have a dvd/vcr combo and I need to know how to hook it up with a cable box and my new tv
need to know what type of tv, but ususally hook up your cable to your video in on the dvd/vcr and your video out from the vide/dvd to the tv
Nov 25, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Poor viewing with VCR
how do you have the combo connection and dish network hooked to the tv ? if you have an s-video , yellow RCA jack video or component video hooked to the same input then it will act this way, because two inputs cannot be on the same video input # on the tv.
is this what is happening? or how are you connecting it?
Jan 04, 2009 | Samsung DVD-V4600 DVD Player/VCR
Magnavox dv225mg9 dvd/vcr player. Hooked it up to TV/Cable receiver/combo and I get great dvd reception sound and picture, but on the vcr I get only sound
I had the same issue. You probably have your unit connected with the newer cables that are red, blue and green. These are more sophisticated and offer better quality for the DVD portion. However, they will not carry the video for the VCR, only the audio.
You need to connect a *yellow* Video Out cable from your DVD/VCR to the Video In on your TV, this should carry the video for the VCR! Hope this helps!
Sep 30, 2008 | GoVideo Go Video DVD/VCR Combo
Cable/ant. hook-up
If you have a yellow/white jack on your DVD/VCR unit you can connect it to the TV using composite cables. If you only have the coax output on the DVD player you can buy an RF modulator that will convert the coax to composite also. But if you have two ports on thhe DVD player as most combos do the top is usually an input source such as cable and the bottom is the output that goes to the back of the tv. You could also buy a "splitter" and attach the cable and dvd coaxs to each of the out ports(they will be side by side) and on the opposite end, which is the in run a coax from that port to the tv coax port.
I hope this helps you out. If you need assistance you can visit me on the chat portion of this website.
Sep 09, 2008 | Philips Magnavox DVD/VCR Dual Player
I need help with my tv and dvd/vcr combo
Hmmmm...I dont understand exactly what you are saying, but it sounds like your TV doesnt have RCA ports and you want to hook up a newer DVD player that uses RCA ports. If you have only a cable port (silver threads with a hole sticking out of back) on TV and RCA ports on DVD player, you have to buy a converter. You can get one at Wal-Mart for 20-30 dollars. Or you can just update your TV which it sounds like you badly need to do! :)
Dec 24, 2007 | Sanyo DVW-7200 DVD/VCR
I can't hook it back up
Is your DVD player a DVD/VCR combo? If so, hook the "tv out" (sometimes called "ant out" ) to the "ant in" on the DVD/VCR, then hook the "ant out" of the DVD/VCR to the "ant in" on the tv. Then make sure the DVD/VCR and TV are on the appropriate channel (3 or 4).
If it's NOT a combo, or these instructions don't work for you, i will need pictures of the inputs/outputs of the devices.
Nov 08, 2007 | DISH Network DVR-625 DTV Receiver /...
Zenith C27A24T 27" TV Logo
320 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
