Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
The lights are on as Normal
It does not fill with water and does not seem to run at all. It is just a year old??? The hot water pressure seems good.
  • 1,869 Answers
Remove power at the dishwasher go to the breakerbox and, flip the dishwasher breaker off
then when you know the power is off (the lights are off) remove the philips screws on the front top inside door this is the locking lever the cherry switch pins must be pushed in (click) to allow the dishwasher to work you should see the problem easily (burned door switch, broken lever etc).
Posted on Apr 22, 2009
    President:
  • 1,489 Answers
It could be the solenoid valve on the water line. If the pressure is good, and there is no water, either the solenoid valve is stuck closed or it's not getting the siganl to open. Lack of a signal could be loose connections or a bad chip/board. If it's a bad board, I fear a service call is in order.
Duet. What does F8E1 code indicate needs to be done to restore operation?
Check out the Link and the info below.
Question: Front Load Washer - Error Code - F8 E1 or LO FL Answer Product Symptom:
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. The washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Whirlpool recommends that appliances be direct connected to the water supply for optimum machine performance.
If a "flood saver" device is being considered:
  • Check with the manufacturer of the device to ensure it will not affect the performance of the appliance.
  • Whirlpool has experienced that "flood safety" devices can interfere with the performance of the appliance. Whirlpool typically does not recommend these devices.
Two types of "flood-saver" devices, hoses and valves are illustrated below. anti%20flood%20hose%202.jpeg floodsafe%203.jpeg Whirlpool Duet Washer F8 Code Appliance Repair Forum
Jan 19, 2016 | Whirlpool Washing Machines
My washing machine is a Whirlpool Model LA5800XS. It came with our condo unit. Its probably about 20 years old and gets only about three month's use each year. Mechanically it runs fine but the cold...
hmmm..that's really odd...is the pressure from the cold water the same as the hot? you can test this first, then we can look at the cold /hot mix system
Mar 10, 2008 | Washing Machines
Temperature gauge goes to hot and shortly later goes back to normal though car does not seem to run badly even while needle is at hot . reserve tank seems to draw antifreeze
you need a new thermostat, its sticking and causing you problems, soon it will just stay stuck, the reason the reserve keeps filling up is because of heat and pressure in the radiator
Jul 01, 2010 | 1994 Chrysler Concorde
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
Kenmore 90 series Water pressure turning up and down
it will switch from hot to cold and back and forth trying to regulate the temp. You probrbly have more pressure in your cold water line than your hot or vise versa. This will cause it to seem to pulse. Dave www.washermd.com
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Magic Chef washer 15 years old, fills slow no hot water
Pull the hot /cold hoses off and clean out the 2 screens in the valve.Put the hoses back on and re try washer .Problem solved?If still no hot water ,replace your water valve. Please Rate This !!!!
Jun 19, 2008 | Magic Chef CAV2000AWW Top Load Washer
Washer does not fill with water
, did you try changing water temps switch to different settings, hot cold amd warm alll no good?? do you even hear a slight humm when trying to fill???, how about trying to put into spin cycle, does it do anything??? if you listen closly (put your ear to the timer knob assy)can oyu hear anything??? if not its quite oossible that you have a power issue, check your incoming power for 110 volts.
Mar 25, 2008 | Kenmore 24032\24036 Top Load Washer
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
194 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
