Question about Yamaha NS-A327 Speaker
Speaker act more like tweeter only, not mid range + tweeter
These speakers (Yamah NS-A327) were sold to me as being stereo speakers covering mid range and tweeter function and should be used in conjunction with a subwoofer. They act more like tweeters only and, when checking the resistance of the voice coil it looks like there is a capacitor in series with the voice coil. Can anyone tell me what these speakers are really supposed to be - or provide the Yamaha specifications for them?
  • Gwynne Spencer Sep 28, 2007
    These speakers are SEALED with no obvious way to get in. The case is some kind of very hard plastic.
    Gwynne Spencer
    Problem Solver:
  • 9 Answers
They are mid Hi speakers.1st Open them and check if the mid speakers are ok maybe they are defected or the protection is open. Good Luck Toufic Malek
Posted on Sep 28, 2007
  • Toufic Malek
    Toufic Malek Oct 02, 2007
    There is some type of speaker that you can access them by removing the front grill .try to remove the front grill carefully by using a flat screw driver with some pressure.
    Good Luck
    Toufic Malek
SOURCE:
Hi,i hear alot about bi wireing could someone explain what it actually is used for and what's it meant to do could I'm thinking bout trying it on my speakers?
It's a big job, but the results are great. Bi amp-ing is where the tweeters and mid range speakers are separated and connected to separate amplifiers. You'll need to have the correct gear before messing inside your speakers. You'll need to have another amplifier. Not knowing what amp you have now, getting a stereo signal into the second amp may be a problem since you'll need a line level signal into the second amp. An external crossover is best. Technically, you could use the ones in the speakers, since you'll be removing them anyway. Now for the speaker mods: On the panel where the posts for the speaker wires are you'll need to install another set of binding posts. We're assuming you have separate subs. Open the speakers and remove the cross over. The wires from the original posts should now connect to the mid range speaker. Add wires from the second set of posts and wire it to the tweeters. Now connect the output of the amp to the removed cross over and wire the mid range out on the cross over to the posts that connect to the mid range speaker. Do the same for the tweeters.If you have three way speakers, you'll have to run a 3rd set of wires from the crossover to the woofers in the cabinet using another set of binding posts. Controlling the volume on the second amp will be difficult since you'll have to adjust it manually. Remote control volume level will be lost on the second amp.
Aug 08, 2015 | Audio Players & Recorders
Hooking up speakers
first off stock wiring for speakers,and or amp are with minimal wiring.Rewire system for better sound quality,also use noise suppresors if needed.
Jan 18, 2014 | Toyota Cars & Trucks
Front speaker passenger not working mid range or tweeter where is the amplifier located tested speaker mid range with another stereo works fine
Have you tired another speaker on that deck? I'd check the connection to that speaker from the deck.
Sep 08, 2011 | Car Audio & Video
Only bass driver working on the pair. tweeter and mid range cones not working.
hi,
check the tweeter and mid range. its coil may become faulty.
for checking the speakers carefully remove the speakers one by one, remove its connections.
and check the speakers with a AAA cell. is it producing cracking sound. if not the speakers coils are burned.
ok
Feb 01, 2011 | Mission 782 Main / Stereo Speaker
The tweeter and upper mid-range speaker quit working in one of my JBL s412p speakers. All wires are connected. Would this be a cross-over assembly problem? If so, where can I purchase a replacement?
Remove the speaker wire from your amplifier. Using a 1.5v battery place the wire on both ends of the battery. Observe if you can hear a cracking sound on the tweeter and the mid-range. If there is no sound., your speaker is busted and needs to be rewind or replaced.
Dec 06, 2010 | JBL S412P Main / Stereo Speaker
Stock audio wiring diagram
Car Radio Battery Constant 12v+ Wire: Green
Car Radio Accessory Switched 12v+ Wire: Green/Orange
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Under the Driver Seat.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Tweeter Speaker Positive Wire (+): Blue
Left Front Tweeter Speaker Negative Wire (-): Brown/Red
Left Front Mid Speaker Positive Wire (+): Black
Left Front Mid Speaker Negative Wire (-): White
Left Front Low Speaker Positive Wire (+): Yellow
Left Front Low Speaker Negative Wire (-): Blue
Right Front Tweeter Speaker Positive Wire (+): Blue/Orange
Right Front Tweeter Speaker Negative Wire (-): Green/Orange
Right Front Mid Speaker Positive Wire (+): Black
Right Front Mid Speaker Negative Wire (-): Brown/Red
Right Front Low Speaker Positive Wire (+): Black
Right Front Low Speaker Negative Wire (-): White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Yellow
Right Rear Speaker Negative Wire (-): Blue
pls rate
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
May 11, 2010 | 2003 Kia Sorento
Just the tweeter is playing and not the mid
It's a midrange component speaker. Possibly your midrange speaker is blown. Check your wiring.
You hear the tweeters i am assuming because the vehicle has tweeter component speakers that are separate from the midrange and low components.
Apr 19, 2010 | VIFA P17WJ-00-08 Car Mid-Range Speaker
How to install 4 way speakers
Exactly the same way, you would for a normal speaker.
Four-ways combine a woofer, a mid-range, a tweeter, and a "super tweeter" into one speaker. But it should still only have one positive and one negative.
Jan 13, 2010 | Sony Xplod 240 Watt 6" x 9" 4-Way Speaker...
Subwoofers not working but tweeter and mid-range do
Try jumping the sub by connecting the speaker cable directly to the speaker , not just the connector on the back
May 25, 2009 | Kenwood Radio Communications
Car stereo crossovers
you should be able to remove the passive in-line crossover, but since it is blocking everything below 3500 hz, there is no need. leaving the passive crossover in place will also help protect the tweeters if something fails in your setup as any amped frequency below 3500 can seriously damage them.
Nov 11, 2007 | Infinity Kappa 10.7t 1'' M.M.D. Dome...
Yamaha NS-A327 Speaker Logo
278 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
