Question about Toshiba Satellite M35X-S149 Notebook
Toshiba laptop power cable won't charge battery
It has to be moved to a 'certain' position as if there is a short in the cord. Now no amount of jiggling will work. It's as if the cord isn't plugged in at all.
This is a replacement Kensington Cord.
  • trisha751 Apr 22, 2009
    I am not sure I understand...the power unit in the laptop is potentially bad. Or is it the cord that is bad?
  • 184 Answers
I had the same problem with my HP laptop some years ago. you have a broken cable/cord and it is the part that is permanently attached with your power pack. If you look at the cord that plugs into your laptop, you can be able to see the faulty part of it. it is usually very flexible or swollen. You can either take it to an electrical technician to change that part of the cord. Your power pack is still ok, but have the technician to check it out first before you change the cord. Else, you may have to get another power pack. below is the full specification of the power pack that is recommended for your laptop.
This Toshiba Global AC Adapter is a 65W external AC adapter designed to work with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers. Get an extra AC adapter to be kept at home, in the office or in your travel case.
Specifications:
* Power: 100-240V/ 50-60Hz Frequency (Universal) input voltage; 19V x 3.42A output voltage
* Dimensions: 4.25" W x 1.34" D x 1.85" H
* Weight: 0.67 lbs
* Power cord included
* Compatible with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers
* One year limited warranty
Note: This AC Adapter is the direct replacement for Toshiba 60W AC Adapter (Mfr. Part#: PA3097U-1ACA) and Toshiba 65W Global AC Adapter (Mfr. Part#: PA3396U-1ACA)
Posted on Apr 22, 2009
    Scholar:
  • 69 Answers
I am not sure what will cost you less,
byuing a new power unit or give the actual one for replacement of the cord.
Do not try to do it by yourself - it might be dangerous for you or for the laptop !
Regards.
  • Zarko Ristevski Apr 22, 2009
    Let's hope the power unit is O.K. but the cord is broken!
    there are two cords, one to plug to the AC wall outlet, and other to plug to the laptop!
    Which one do you think is broken?
    If AC cord is broken, than it is easy and will not cost you more than 2 EURO to replace it, but if it is the other one, than moving it to 'certan' position to work, might make your power unit to break.
    That is why i suggest first to check if the power unit is working, and (if not) to replace with a new one !
    This should be done by a qualified person, it might be dangerous to play with 220V.
Toshiba satellite l305d-s5934 Won't charge battery dont power On
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 25, 2012 | Toshiba Satellite L305D-S5934 Notebook
Screen and system freezes when AC is disconnected, I changed the battery but the problem still. Laptop is a Toshiba satellite l635
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Aug 01, 2012 | Computers & Internet
Power cord issues due to moving it while plugged in
Jun 02, 2012 | Sony VPCF13UFX/H PC Notebook
How to tell if a105-s4074 satellite battery is bad
Apr 28, 2012 | Toshiba Satellite A105-S4074 Notebook
How do i get my laptop to power on? Have new power cord but still will not power up
There is a possibility that if the battery is shorting out it won't hold the charge or let it power up.
Mar 30, 2012 | Toshiba Satellite L455D-S5976 Series...
Hi I have a Toshiba laptop model no.psl2xu-ookoof and it doesn't charge anymore so what do I do
If the laptop works only off the Power Cord and the battery is not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let the latop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in and remove the power cord. If it won't boot or shuts down then the battery is dead and needs to be replaced if the power cord is ok.
Mar 26, 2012 | Toshiba Computers & Internet
Agptek replacement battery not working
Nov 20, 2011 | Toshiba Satellite M115-S1061 Notebook
With a battery charged in a different laptop, this one will work. Included AC cord as well as other compatible (19V 3.42A) cords will NOT power the device OR charge attached battery. My deduction is that...
It is probably the protection fuse link that has failed. It is on the motherboard near the power input, or the onboard power supply has failed.
Consult an authorised Toshiba repair service.
Jan 11, 2011 | Toshiba Satellite A100-S8111TD Notebook
Laptop will not power up
The internal solder points for the power connector have broken. Hope it's under warranty
Apr 30, 2009 | Toshiba Satellite M45-S165 Notebook
Toshiba Satellite M35X-S149 Notebook Logo
2,737 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
