Question about Dacor Epicure ERD48 Dual Fuel (Electric and Gas) Kitchen Range
Flame coming out of Dacor oven during broiling
The oven is 9 years old, running on propane. Twice, in the last two months, we set the oven to broil and then, when we opened the door to put food in, flames came out at the top of the door. Then, it settled down and worked as normal. Seems like I have a pilot light or incomplete combustion problem. The oven has not been cleaned in a long time, so I'm thinking that running it through the self-cleaning cycle might fix this problem (burning away some residue that is impacting its operation). Any thoughts?
  • 1 more comment
  • gene_bowles Apr 23, 2009
    Well, I put the oven thru the self-clean cycle, which worked just fine and cleaned it up nicely. Now, the broiler unit (which uses propane) just doesn't work at all. When I set the oven in broil mode, I can see a small brightly lit electric heating element go on in the back ( I assume is a pilot light), but the main broiler unit does not heat up. Seems like the earlier problems were an indication of pending failure.
    What next? Is there some way for me to diagnose this problem further myself?
    Your proposed solution appears to apply to a broiler with an electrical heating element. Mine is a propane gas fueled element.
  • gene_bowles May 01, 2009
    No. I had to leave town for a few days. Also, I was waiting for a reply from you as to whether the igniter is reasonably modular and easily replaced or is it complicated and requires a professional.
    Gene
  • 3,037 Answers
The igniter for the broiler is bad and needs to be replaced. They will do this after so many uses.
You should be able to get a new one locally or cheaper at a website like appliancepartspros.com
Let me know if you have any more questions on this or need help finding the part.
Benjamin
Posted on Apr 23, 2009
  • Benjamin Patri
    Benjamin Patri May 01, 2009
    Did you ever get around to replacing the igniter?
  • Benjamin Patri
    You should be able to replace it. It doesn't require too much work or skills
    Brigadier General:
  • 8,619 Answers
Hi
The first thing that should be done is self-cleaning. If it still gives you the same issue then this is probably the most common way for an oven element to go bad....a spot in the element gets weak ( may even glow brighter in that spot before the element actually quits ) and blows a hole through itself and the outer shell.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 22, 2009
  • Rylee Smith
    Rylee Smith Apr 23, 2009
    Hi!
    You need to check the element first for which remove the element from the oven, check across the terminals of the element for continuity. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms, with an ohm meter. To see if the element is grounded, read between each side of the element terminals to the sheath of the element. If you read continuity, the element is grounded and should be replaced.
    To replace element please disconnect the power first.
    Then remove oven racks by removing the mounting screws from the element mounting plate which are located against the back wall of the oven liner.
    Now pull defective element away from the back of the oven wall as far as the wire will allow and if the wires too short, disconnect the wires from the element at the back of the oven.
    Remove wire lead screws from the element.
    Replace the element and reconnect the leads ( if only two wires going to the element, it does not matter which goes on left or right wire terminal ).
    Tuck surplus wire behind insulation.
    Line up holes and reinstall new element using existing screws.
    Thanks
    Rylee
Our new home has a GE XL44 gas stove the top works fine but when I use the oven it smokes and sets off the smoke alarms.The stove is over 3 years old Any ideas before I have to call the repairman in?
A gas stove shouldn't smoke. Is is clean? There is some grease that has eluded your cleaning efforts of interior surface?
Here are some tips that may help you resolve this problem:
Check the broiler flame. If the broiler flame is not adjusted properly, you could be creating soot from the burner flame.
Position the items that your are broiling lower so that they do not splatter grease up onto the broiler baffle.
Use a broiler pan that will drain grease and drippings down below the top surface.
Broiling many items will naturally produce some smoke. If you have the oven door closed when broiling then the only place that the smoke can go is up and out of the oven vent. If you partially open the oven door, some of the smoke will come out of the door opening.
You may have residue on the top walls of the inner oven cavity. Do you have self-clean feature on your range to clean the oven? Follow all of the procedures in your owner's manual to properly clean the oven using the self-clean cycle. This may clear out any undetected residue that could be causing excessive smoke during broiling.
Aug 26, 2015 | GE Kitchen Ranges
I have an old Modern Maid double oven. DK 0757. Broiler comes on everytime I try to heat for baking. Any suggestions
It was common for the broil element to come on during the preheat time on older oven controls. When the oven reaches temperature the broil should shut off. If this just started then the points in the broil switch section are welded together and the oven thermostat will need replacing
Mar 20, 2015 | Ovens
My GE gas XL44 oven will not broil (upper flame burner). It worked as recently as last night. The Broil indicator is lit when selected. The upper broil burners do not flame-on. Thanks, Jeremy
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Feb 02, 2011 | Ovens
Do you use lava rocks or just use propane flame?
Hello, There should be vaporizer tents over each burner. As a reference you can got to website: http://www.charbroil.com/bps/char-broil/char-broil/knowledge/7001189_463453306_english_37f8ef8b-0_.pdf
and refer to the bottom of page 9 or find your model number and enter it into the search bar at the top right of the Char-Broil website: http://www.charbroil.com/
You can order needed parts from there or from Sears which I have found to be quite competitive on their prices.
If you found this helpful please vote yes. Thank You!!
Apr 07, 2010 | Char-Broil Advantage 463453306
Problem with my Char-Broil Grill
Rest asurred your igniter is made to excite the customer that buys the unit. However, in realltiy use a common (extended) Bic type grill lighter sraight up. No listening for nothing, just look for flame. If no no flame RUN LIKE HELL!!!
Mar 19, 2010 | Char-Broil Designer 463261106 Grill
DACOR IS A PEICE ****
The hi limit thermostat probably tripped during self clean. It can be manually reset. Turn off the power and remove the grill under the control panel. There is a two wire switch behind the door latch press in the red button on the switch. Reassemble and turn on the power. If it works you can reset the cooling fan to run longer which could cure your problem. Press and release upper broil button, press and release the up arrow, then hold down the broil button until it reads COOL 000. Press the up arrow until it reads COOL 200. Press cancel. Done.
Jul 01, 2009 | Dacor ECD230 Epicure Electric Double Oven
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works
I also have a Dacor Model PCS130. This solution worked AND saved me from spending $50-$105 for a service technician to come out just to look at the problem. The high temperature sensor tripped when I kept the door open part way while broiling (never listen to friends who don't have the same oven as yours). Afterwards, I couldn't get the oven to go above the prebake temperature of 135°F using any of the settings (bake, broil, convection bake, etc...). I called Dacor customer service and they told me about the high temperature sensor but wouldn't say how to reset it. They suggested I call a third party technical service company and gave me their numbers. But, I'm glad I found this site... All you have to do is open the oven door and you'll see the grille/grate/steel cover plate where the door latch sticks out of. If you look inside, you can see the electronics that operate the door latch as well as the temperature sensor unit a little farther back. You can even see the RED reset button. But, it's a little too far back for you to press it without removing the cover plate. 6 screws is what holds my cover plate in place. Once that's off, you can reach in and press the RED reset button (I pressed it twice just to make sure) and you'll hear it click. Screw the cover plate back in place. Close the oven door and test it out. It took my oven about 5 minutes to heat up past 135°F so I was unsure if the problem was fixed or not during that time. But, once the oven heated up sufficiently, the temperature began climbing fairly quickly and I was able to breath a sigh of relief. It works! This is such an easy fix, I don't know why Dacor customer support doesn't just tell us how to do it ourselves instead of paying for a service tech to come out and do the same thing. Even better, maybe they should make the reset button more easily accessible (like on the control panel) if they're concerned about people getting in and messing up the other electrical connections when trying to reset the high temperature switch. Computers are far more technically advanced than your oven and THEY have reset/reboot buttons right in front.
Nov 11, 2006 | Dacor ECS127 Epicure Stainless Steel...
Open Questions:
Dacor Epicure ERD48 Dual Fuel (Electric and Gas) Kitchen Range Logo
82 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
240cpa
Jaime Hernandez
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
